    Add JS Code to the Mirror
    33 Posts 5 Posters 18.1k Views 5 Watching
      dnj0104
      @sdetweil said in Add JS Code to the Mirror:
      mod_client
      errors folder and file config.js (mmm-mpd) renamed to mod:
      [2020-10-24 00:03:42.600] [ERROR]  WARNING! Could not validate config file. Starting with default configuration. Please correct syntax errors at or above this line: ReferenceError: NodeHelper is not defined
          at Object.<anonymous> (/home/pi/MagicMirror/modules/mod_client/node_helper.js:4:18)
          at Module._compile (internal/modules/cjs/loader.js:786:30)
          at Object.Module._extensions..js (internal/modules/cjs/loader.js:798:10)
          at Module.load (internal/modules/cjs/loader.js:645:32)
          at Function.Module._load (internal/modules/cjs/loader.js:560:12)
          at Module.require (internal/modules/cjs/loader.js:685:19)
          at require (internal/modules/cjs/helpers.js:16:16)
          at loadModule (/home/pi/MagicMirror/js/app.js:134:17)
          at loadNextModule (/home/pi/MagicMirror/js/app.js:169:5)
          at /home/pi/MagicMirror/js/app.js:171:6
      [2020-10-24 00:03:42.601] [LOG]    Loading module helpers ...
      [2020-10-24 00:03:42.602] [LOG]    No helper found for module: alert.
      [2020-10-24 00:03:42.603] [LOG]    Initializing new module helper ...
      [2020-10-24 00:03:42.604] [LOG]    Module helper loaded: updatenotification
      [2020-10-24 00:03:42.605] [LOG]    No helper found for module: clock.
      [2020-10-24 00:03:42.616] [LOG]    Initializing new module helper ...
      [2020-10-24 00:03:42.617] [LOG]    Module helper loaded: calendar
      [2020-10-24 00:03:42.618] [LOG]    No helper found for module: .
      [2020-10-24 00:03:42.619] [LOG]    No helper found for module: currentweather.
      [2020-10-24 00:03:42.620] [LOG]    No helper found for module: weatherforecast.
      [2020-10-24 00:03:42.621] [LOG]    Initializing new module helper ...
      [2020-10-24 00:03:42.621] [LOG]    Module helper loaded: newsfeed
      [2020-10-24 00:03:42.623] [ERROR]  App threw an error during load
      [2020-10-24 00:03:42.625] [ERROR]  ReferenceError: NodeHelper is not defined
      [2020-10-24 00:03:42.627] [ERROR]  Whoops! There was an uncaught exception...
      [2020-10-24 00:03:42.628] [ERROR]  ReferenceError: NodeHelper is not defined
      ------result---- dark—screen electron just showed black----------
      roll back, Folder named to mod-client and in config.js and mpd_client.js to mod_client.
      Result; electron start with no error all my modules shows, but not mod_client aka mpd_client
        sdetweil @dnj0104
        @dnj0104 what MM version are you running on? this problem was fixed in 2.10
        do this
        from the MM folder
        git checkout modules/node_modules/node_helper/index.js
          dnj0104
          I got version 20.13.0
          from your git command i get output
          pi@raspberrypi:~/MagicMirror $ git checkout modules/node_modules/node_helper/index.js
          error: pathspec 'modules/node_modules/node_helper/index.js' did not match any file(s) known to git
            sdetweil @dnj0104
            @dnj0104 can you do
            grep version package.json
              dnj0104
              yes and and result is
              pi@raspberrypi:~/MagicMirror $ grep version package.json
              	"version": "2.13.0",
                @dnj0104 yeh, mess
                this module should be installed like this to make up for the name problem
                cd ~/ MagicMirror/modules
                git clone https://github.com/timjong93/MMM-MPD.git mpd_client
                cd mpd_client
                npm install
                then everything matches
                D 1 Reply Last reply
                  sdetweil @dnj0104
                  @dnj0104 thanks… so the git checkout would not have worked, sorry…
                  try the install as I suggest above
                    dnj0104 @sdetweil
                    so then i throw mpd client folder in trash and follow your
                    install instructions?
                    because I believe there have been a problem when I first installed mpd_client, I did not been clear where the npm install should been placed, if you read in mpd-client readme.md maybe you understand, english is not my first language, and my linux-fu is below first grade :)
                      sdetweil @dnj0104
                      @dnj0104 is ok, he didn’t do the instructions correctly…
                      yes, start over
                      cd ~/MagicMirror/modules
                      rm -rf mod_client
                      then do the install as I suggested
                        dnj0104
                        and then change folder name to mod-client ?
                        is it mod-client (folder) and mod_client in config.js in config array. do I also change name in mpd-client.js file?
                          sdetweil @dnj0104
                          @dnj0104 everythign should be named mpd_client
                          look at the files list in the module
                          all mpd_client
                          no, do NOT change the folder name, change the config.js to match
                          module: 'mpd_client',
                            dnj0104 @sdetweil
                            mpd_client
                            ok then
                            fresh install and download after your instructions:
                            [[ERROR]  WARNING! Could not validate config file. Starting with default configuration. Please correct syntax errors at or above this line: ReferenceError: NodeHelper is not defined
                                at Object.<anonymous> (/home/pi/MagicMirror/modules/mpd_client/node_helper.js:4:18)
                            [2020-10-24 01:33:46.979] [LOG]    Loading module helpers ...
                            [2020-10-24 01:33:46.980] [LOG]    No helper found for module: alert.
                            [2020-10-24 01:33:46.981] [LOG]    Initializing new module helper ...
                            [2020-10-24 01:33:46.982] [LOG]    Module helper loaded: updatenotification
                            [2020-10-24 01:33:46.983] [LOG]    No helper found for module: clock.
                            [2020-10-24 01:33:46.984] [LOG]    Initializing new module helper ...
                            [2020-10-24 01:33:46.985] [LOG]    Module helper loaded: calendar
                            [2020-10-24 01:33:46.986] [LOG]    No helper found for module: .
                            [2020-10-24 01:33:46.988] [LOG]    No helper found for module: currentweather.
                            [2020-10-24 01:33:46.990] [LOG]    No helper found for module: weatherforecast.
                            [2020-10-24 01:33:46.991] [LOG]    Initializing new module helper ...
                            [2020-10-24 01:33:46.992] [LOG]    Module helper loaded: newsfeed
                            [2020-10-24 01:33:46.994] [ERROR]  App threw an error during load
                            [2020-10-24 01:33:47.003] [ERROR]  ReferenceError: NodeHelper is not defined
                            [2020-10-24 01:33:47.006] [ERROR]  Whoops! There was an uncaught exception...
                            [2020-10-24 01:33:47.007] [ERROR]  ReferenceError: NodeHelper is not defined
                            [2020-10-24 01:33:47.014] [ERROR]  MagicMirror will not quit, but it might be a good idea to check why this happened. Maybe no internet connection?
                            [2020-10-24 01:33:47.014] [ERROR]  If you think this really is an issue, please open an issue on GitHub: https://github.com/MichMich/MagicMirror/issues
                            [2020-10-24 01:33:49.707] [LOG]    Launching application.]
                            something wrong with nodehelper I believe.
                            Or maybe I have wrong port and IP to my mpd.
                              sdetweil @dnj0104
                              @dnj0104 bad module,
                              edit the node_helper.js
                              and add this as the 1st line
                              const NodeHelper = require("node_helper");
                                dnj0104
                                I added your code snippet in 1st line after
                                var mpd = require('mpd'),
                                and output
                                [2020-10-24 01:56:54.490] [ERROR]  WARNING! Could not validate config file. Starting with default configuration. Please correct syntax errors at or above this line: /home/pi/MagicMirror/modules/mpd_client/node_helper.js:1
                                var mpd = require('mpd'),const NodeHelper = require("node_helper");
                                SyntaxError: Unexpected token const
                                    at Module._compile (internal/modules/cjs/loader.js:722:23)
                                    at Class.loaded (/home/pi/MagicMirror/js/node_helper.js:18:3)
                                  sdetweil @dnj0104
                                  @dnj0104 no, I want it to be a line BEFORE the stuff in the file already
                                    dnj0104
                                    AH! Sorry!
                                    Changed it now your snippet in 1st Line
                                    And we have Success!!! Finally!!
                                    Thanks Alot @sdetweil
