    Add JS Code to the Mirror
    33 Posts 5 Posters 18.1k Views 5 Watching
    • L
      Leobo
      Thank You @stro, This work great. Im rename folder MMM-MPD to mod_client and move to MagicMirror module, From MagicMirror/module/mpd_client npm install and work.
      D 1 Reply Last reply
        dnj0104 @Leobo
        @Leobo said in Add JS Code to the Mirror:
        Something like this happens to me, but my module is from user coderpussy @github , pretty new fork, maybe I got some failure from moodeaudio devs, but I dont think, so anyway here is some of my errors.
        if change folder name mmm-mpd to mpd_client errors in MM startup:
        alerts in MagicMirror startup:
        WARNING! Could not validate config file. Starting with default configuration. Please correct syntax errors at or above this line: ReferenceError: NodeHelper is not defined
            at Object.<anonymous> (/home/pi/MagicMirror/modules/mpd_client/node_helper.js:4:18)
            at Module._compile (internal/modules/cjs/loader.js:786:30)
            at Object.Module._extensions..js (internal/modules/cjs/loader.js:798:10)
            at Module.load (internal/modules/cjs/loader.js:645:32)
            at Function.Module._load (internal/modules/cjs/loader.js:560:12)
            at Module.require (internal/modules/cjs/loader.js:685:19)
            at require (internal/modules/cjs/helpers.js:16:16)
            at loadModule (/home/pi/MagicMirror/js/app.js:134:17)
            at loadNextModule (/home/pi/MagicMirror/js/app.js:169:5)
            at /home/pi/MagicMirror/js/app.js:171:6
        change folder name from mmm-mpd to mpd-client:
        Result: No errors in MM-startup but mpd-module does not start.
        **Looking for errors in MM-dev tools with folder named to mpd-module>**
        Errors:
        Load script: modules/mpd_client//mpd_client.js
        :8080/modules/mpd_cl…nt//mpd_client.js:1 Failed to load resource: the server responded with a status of 404 (Not Found)
        loader.js:186 Error on loading script: modules/mpd_client//mpd_client.js
        module in mm-config array looks like
        this.
        		module: "mpd_client",
        		position: "top_right",	// This can be any of the regions.
        			hostname:"mpd@moodeaudio@rpi3b+=IPnumber)",
        			port:6600
          sdetweil @dnj0104
          @dnj0104 there is probably more to the error message this also happens when there is some library required by a module not found at startup
          u can also run
          npm run config:check
          to review any syntax errors in the config.js file
            dnj0104 @sdetweil
            @sdetweil said in Add JS Code to the Mirror:
            in magicmirror/modules
            or in magicmirror/modules/mpd-module ?
            Thinks the whole module has to be rebuilt…
              sdetweil @dnj0104
              @dnj0104 in MagicMirror
                dnj0104 @sdetweil
                then I got
                [2020-10-23 23:46:08.836] [INFO]   Checking file...  /home/pi/MagicMirror/config/config.js
                [2020-10-23 23:46:09.049] [INFO]   Your configuration file doesn't contain syntax errors :)
                  sdetweil @dnj0104
                  @dnj0104 ok, so the error that causes the default config to load is caused by some other problem.
                  missing module, or some other failure
                  can u show the MM startup messages (from the window where you do npm start)
                  a module consists of the folder name
                  MMM-MPD
                  and its main js file
                  MMM-MPD.js
                  and inside MMM-MPD.js is the module register statement
                  Module.register("MMM-MPD", {
                  and in config.js
                       module: 'MMM-MPD',
                  this causes MM to look for the folder, filename and file contents in that order
                  SO, it SOUNDS like from a prior post, that the REAL name is
                  mod_client
                  (so there must be the right folder name, file name and file contents of
                  mod_client
                  if so, you can rename the folder (mv is the rename command on linux)
                  then in config.js you need
                    module:'mod_client',
                  see the topic ‘How to add modules’ in my signature
                    dnj0104
                    mod_client
                    errors folder and file config.js (mmm-mpd) renamed to mod:
                    [2020-10-24 00:03:42.600] [ERROR]  WARNING! Could not validate config file. Starting with default configuration. Please correct syntax errors at or above this line: ReferenceError: NodeHelper is not defined
                        at Object.<anonymous> (/home/pi/MagicMirror/modules/mod_client/node_helper.js:4:18)
                    [2020-10-24 00:03:42.601] [LOG]    Loading module helpers ...
                    [2020-10-24 00:03:42.602] [LOG]    No helper found for module: alert.
                    [2020-10-24 00:03:42.603] [LOG]    Initializing new module helper ...
                    [2020-10-24 00:03:42.604] [LOG]    Module helper loaded: updatenotification
                    [2020-10-24 00:03:42.605] [LOG]    No helper found for module: clock.
                    [2020-10-24 00:03:42.616] [LOG]    Initializing new module helper ...
                    [2020-10-24 00:03:42.617] [LOG]    Module helper loaded: calendar
                    [2020-10-24 00:03:42.618] [LOG]    No helper found for module: .
                    [2020-10-24 00:03:42.619] [LOG]    No helper found for module: currentweather.
                    [2020-10-24 00:03:42.620] [LOG]    No helper found for module: weatherforecast.
                    [2020-10-24 00:03:42.621] [LOG]    Initializing new module helper ...
                    [2020-10-24 00:03:42.621] [LOG]    Module helper loaded: newsfeed
                    [2020-10-24 00:03:42.623] [ERROR]  App threw an error during load
                    [2020-10-24 00:03:42.625] [ERROR]  ReferenceError: NodeHelper is not defined
                    [2020-10-24 00:03:42.627] [ERROR]  Whoops! There was an uncaught exception...
                    [2020-10-24 00:03:42.628] [ERROR]  ReferenceError: NodeHelper is not defined
                    ------result---- dark—screen electron just showed black----------
                    roll back, Folder named to mod-client and in config.js and mpd_client.js to mod_client.
                    Result; electron start with no error all my modules shows, but not mod_client aka mpd_client
                      sdetweil @dnj0104
                      @dnj0104 what MM version are you running on? this problem was fixed in 2.10
                      do this
                      from the MM folder
                      git checkout modules/node_modules/node_helper/index.js
                        dnj0104
                        I got version 20.13.0
                        from your git command i get output
                        pi@raspberrypi:~/MagicMirror $ git checkout modules/node_modules/node_helper/index.js
                        error: pathspec 'modules/node_modules/node_helper/index.js' did not match any file(s) known to git
                          sdetweil @dnj0104
                          @dnj0104 can you do
                          grep version package.json
                            dnj0104
                            yes and and result is
                            pi@raspberrypi:~/MagicMirror $ grep version package.json
                            	"version": "2.13.0",
                              @dnj0104 yeh, mess
                              this module should be installed like this to make up for the name problem
                              cd ~/ MagicMirror/modules
                              git clone https://github.com/timjong93/MMM-MPD.git mpd_client
                              cd mpd_client
                              npm install
                              then everything matches
                                sdetweil @dnj0104
                                @dnj0104 thanks… so the git checkout would not have worked, sorry…
                                try the install as I suggest above
                                  dnj0104 @sdetweil
                                  so then i throw mpd client folder in trash and follow your
                                  install instructions?
                                  because I believe there have been a problem when I first installed mpd_client, I did not been clear where the npm install should been placed, if you read in mpd-client readme.md maybe you understand, english is not my first language, and my linux-fu is below first grade :)
                                    sdetweil @dnj0104
                                    @dnj0104 is ok, he didn’t do the instructions correctly…
                                    yes, start over
                                    cd ~/MagicMirror/modules
                                    rm -rf mod_client
                                    then do the install as I suggested
                                      dnj0104
                                      and then change folder name to mod-client ?
                                      is it mod-client (folder) and mod_client in config.js in config array. do I also change name in mpd-client.js file?
                                        sdetweil @dnj0104
                                        @dnj0104 everythign should be named mpd_client
                                        look at the files list in the module
                                        all mpd_client
                                        no, do NOT change the folder name, change the config.js to match
                                        module: 'mpd_client',
                                          dnj0104 @sdetweil
                                          mpd_client
                                          ok then
                                          fresh install and download after your instructions:
                                          [[ERROR]  WARNING! Could not validate config file. Starting with default configuration. Please correct syntax errors at or above this line: ReferenceError: NodeHelper is not defined
                                          [2020-10-24 01:33:46.979] [LOG]    Loading module helpers ...
                                          [2020-10-24 01:33:46.980] [LOG]    No helper found for module: alert.
                                          [2020-10-24 01:33:46.981] [LOG]    Initializing new module helper ...
                                          [2020-10-24 01:33:46.982] [LOG]    Module helper loaded: updatenotification
                                          [2020-10-24 01:33:46.983] [LOG]    No helper found for module: clock.
                                          [2020-10-24 01:33:46.984] [LOG]    Initializing new module helper ...
                                          [2020-10-24 01:33:46.985] [LOG]    Module helper loaded: calendar
                                          [2020-10-24 01:33:46.986] [LOG]    No helper found for module: .
                                          [2020-10-24 01:33:46.988] [LOG]    No helper found for module: currentweather.
                                          [2020-10-24 01:33:46.990] [LOG]    No helper found for module: weatherforecast.
                                          [2020-10-24 01:33:46.991] [LOG]    Initializing new module helper ...
                                          [2020-10-24 01:33:46.992] [LOG]    Module helper loaded: newsfeed
                                          [2020-10-24 01:33:46.994] [ERROR]  App threw an error during load
                                          [2020-10-24 01:33:47.003] [ERROR]  ReferenceError: NodeHelper is not defined
                                          [2020-10-24 01:33:47.006] [ERROR]  Whoops! There was an uncaught exception...
                                          [2020-10-24 01:33:47.007] [ERROR]  ReferenceError: NodeHelper is not defined
                                          [2020-10-24 01:33:47.014] [ERROR]  MagicMirror will not quit, but it might be a good idea to check why this happened. Maybe no internet connection?
                                          [2020-10-24 01:33:47.014] [ERROR]  If you think this really is an issue, please open an issue on GitHub: https://github.com/MichMich/MagicMirror/issues
                                          [2020-10-24 01:33:49.707] [LOG]    Launching application.]
                                          something wrong with nodehelper I believe.
                                          Or maybe I have wrong port and IP to my mpd.
                                            sdetweil @dnj0104
                                            @dnj0104 bad module,
                                            edit the node_helper.js
                                            and add this as the 1st line
                                            const NodeHelper = require("node_helper");
