    Add JS Code to the Mirror
    33 Posts 5 Posters 17.1k Views 5 Watching
      stro
      @sdetweil thanks for helping me.
      I have the code (pastebin) who put the data, i‘m looking for, in a HTML Output. If i open the html file like this
      file:///home/pi/MagicMirror/modules/test/mopidy.html
      everything is okay.
      But if open this HTML File with the Mirrorpath like this:
      localhost:8080/modules/test/mopidy.html
      It shows me nothing. And i wonder why.
        sdetweil @stro
        @stro open the developers window, ctrl-shift-i, select the console tab and scroll up to see any errors
          stacywebb
          Check your
          mopidy.conf
          located at:
          ~/.config/mopidy/mopidy.conf
          Look for this section:
          [http]
          enabled = true
          hostname = 127.0.0.1
          port = 6680
          static_dir =
          zeroconf = Mopidy HTTP server on $hostname
          allowed_origins =
          csrf_protection = true
          Take note of the hostname part.
          If your’s looks like the above instead of using localhost in the url, use the ip address or host name of the mirror.
          Examples:
          mirror.local:8080/modules/test/mopidy.html
          or
          10.x.x.x:8080/modules/test/mopidy.html
          I tested the code you posted on pastebin and it works as expected for me.
          Only tested using the hostname of the Mirror from external browser. Not locally on the machine.
            stro
            I was able to solve that problem.
            MPD port was double busy. Apparently 2 instances of Mopidy were running.
            Now the module MMM-MPD runs under a few specials:
            During the installation the folder name has to be changed according to the config file.
            The config file value maxRows must not be 0!
            The display will only update after a song change!
            It was hard to find this specifics, but I thank everyone for the help!
            • L Offline
              Leobo
              Thank You @stro, This work great. Im rename folder MMM-MPD to mod_client and move to MagicMirror module, From MagicMirror/module/mpd_client npm install and work.
                dnj0104 @Leobo
                @Leobo said in Add JS Code to the Mirror:
                Something like this happens to me, but my module is from user coderpussy @github , pretty new fork, maybe I got some failure from moodeaudio devs, but I dont think, so anyway here is some of my errors.
                if change folder name mmm-mpd to mpd_client errors in MM startup:
                alerts in MagicMirror startup:
                WARNING! Could not validate config file. Starting with default configuration. Please correct syntax errors at or above this line: ReferenceError: NodeHelper is not defined
                    at Object.<anonymous> (/home/pi/MagicMirror/modules/mpd_client/node_helper.js:4:18)
                    at Module._compile (internal/modules/cjs/loader.js:786:30)
                    at Object.Module._extensions..js (internal/modules/cjs/loader.js:798:10)
                    at Module.load (internal/modules/cjs/loader.js:645:32)
                    at Function.Module._load (internal/modules/cjs/loader.js:560:12)
                    at Module.require (internal/modules/cjs/loader.js:685:19)
                    at require (internal/modules/cjs/helpers.js:16:16)
                    at loadModule (/home/pi/MagicMirror/js/app.js:134:17)
                    at loadNextModule (/home/pi/MagicMirror/js/app.js:169:5)
                    at /home/pi/MagicMirror/js/app.js:171:6
                change folder name from mmm-mpd to mpd-client:
                Result: No errors in MM-startup but mpd-module does not start.
                **Looking for errors in MM-dev tools with folder named to mpd-module>**
                Errors:
                Load script: modules/mpd_client//mpd_client.js
                :8080/modules/mpd_cl…nt//mpd_client.js:1 Failed to load resource: the server responded with a status of 404 (Not Found)
                loader.js:186 Error on loading script: modules/mpd_client//mpd_client.js
                module in mm-config array looks like
                this.
                		module: "mpd_client",
                		position: "top_right",	// This can be any of the regions.
                			hostname:"mpd@moodeaudio@rpi3b+=IPnumber)",
                			port:6600
                  sdetweil @dnj0104
                  @dnj0104 there is probably more to the error message this also happens when there is some library required by a module not found at startup
                  u can also run
                  npm run config:check
                  to review any syntax errors in the config.js file
                    dnj0104 @sdetweil
                    @sdetweil said in Add JS Code to the Mirror:
                    in magicmirror/modules
                    or in magicmirror/modules/mpd-module ?
                    Thinks the whole module has to be rebuilt…
                      sdetweil @dnj0104
                      @dnj0104 in MagicMirror
                        dnj0104 @sdetweil
                        then I got
                        [2020-10-23 23:46:08.836] [INFO]   Checking file...  /home/pi/MagicMirror/config/config.js
                        [2020-10-23 23:46:09.049] [INFO]   Your configuration file doesn't contain syntax errors :)
                          sdetweil @dnj0104
                          @dnj0104 ok, so the error that causes the default config to load is caused by some other problem.
                          missing module, or some other failure
                          can u show the MM startup messages (from the window where you do npm start)
                          a module consists of the folder name
                          MMM-MPD
                          and its main js file
                          MMM-MPD.js
                          and inside MMM-MPD.js is the module register statement
                          Module.register("MMM-MPD", {
                          and in config.js
                               module: 'MMM-MPD',
                          this causes MM to look for the folder, filename and file contents in that order
                          SO, it SOUNDS like from a prior post, that the REAL name is
                          mod_client
                          (so there must be the right folder name, file name and file contents of
                          mod_client
                          if so, you can rename the folder (mv is the rename command on linux)
                          then in config.js you need
                            module:'mod_client',
                          see the topic ‘How to add modules’ in my signature
                            dnj0104
                            mod_client
                            errors folder and file config.js (mmm-mpd) renamed to mod:
                            [2020-10-24 00:03:42.600] [ERROR]  WARNING! Could not validate config file. Starting with default configuration. Please correct syntax errors at or above this line: ReferenceError: NodeHelper is not defined
                                at Object.<anonymous> (/home/pi/MagicMirror/modules/mod_client/node_helper.js:4:18)
                            [2020-10-24 00:03:42.601] [LOG]    Loading module helpers ...
                            [2020-10-24 00:03:42.602] [LOG]    No helper found for module: alert.
                            [2020-10-24 00:03:42.603] [LOG]    Initializing new module helper ...
                            [2020-10-24 00:03:42.604] [LOG]    Module helper loaded: updatenotification
                            [2020-10-24 00:03:42.605] [LOG]    No helper found for module: clock.
                            [2020-10-24 00:03:42.616] [LOG]    Initializing new module helper ...
                            [2020-10-24 00:03:42.617] [LOG]    Module helper loaded: calendar
                            [2020-10-24 00:03:42.618] [LOG]    No helper found for module: .
                            [2020-10-24 00:03:42.619] [LOG]    No helper found for module: currentweather.
                            [2020-10-24 00:03:42.620] [LOG]    No helper found for module: weatherforecast.
                            [2020-10-24 00:03:42.621] [LOG]    Initializing new module helper ...
                            [2020-10-24 00:03:42.621] [LOG]    Module helper loaded: newsfeed
                            [2020-10-24 00:03:42.623] [ERROR]  App threw an error during load
                            [2020-10-24 00:03:42.625] [ERROR]  ReferenceError: NodeHelper is not defined
                            [2020-10-24 00:03:42.627] [ERROR]  Whoops! There was an uncaught exception...
                            [2020-10-24 00:03:42.628] [ERROR]  ReferenceError: NodeHelper is not defined
                            ------result---- dark—screen electron just showed black----------
                            roll back, Folder named to mod-client and in config.js and mpd_client.js to mod_client.
                            Result; electron start with no error all my modules shows, but not mod_client aka mpd_client
                              sdetweil @dnj0104
                              @dnj0104 what MM version are you running on? this problem was fixed in 2.10
                              do this
                              from the MM folder
                              git checkout modules/node_modules/node_helper/index.js
                                dnj0104
                                I got version 20.13.0
                                from your git command i get output
                                pi@raspberrypi:~/MagicMirror $ git checkout modules/node_modules/node_helper/index.js
                                error: pathspec 'modules/node_modules/node_helper/index.js' did not match any file(s) known to git
                                  sdetweil @dnj0104
                                  @dnj0104 can you do
                                  grep version package.json
                                    dnj0104
                                    yes and and result is
                                    pi@raspberrypi:~/MagicMirror $ grep version package.json
                                    	"version": "2.13.0",
                                      @dnj0104 yeh, mess
                                      this module should be installed like this to make up for the name problem
                                      cd ~/ MagicMirror/modules
                                      git clone https://github.com/timjong93/MMM-MPD.git mpd_client
                                      cd mpd_client
                                      npm install
                                      then everything matches
                                        sdetweil @dnj0104
                                        @dnj0104 thanks… so the git checkout would not have worked, sorry…
                                        try the install as I suggest above
                                          dnj0104 @sdetweil
                                          so then i throw mpd client folder in trash and follow your
                                          install instructions?
                                          because I believe there have been a problem when I first installed mpd_client, I did not been clear where the npm install should been placed, if you read in mpd-client readme.md maybe you understand, english is not my first language, and my linux-fu is below first grade :)
                                            sdetweil @dnj0104
                                            @dnj0104 is ok, he didn’t do the instructions correctly…
                                            yes, start over
                                            cd ~/MagicMirror/modules
                                            rm -rf mod_client
                                            then do the install as I suggested
