    Add JS Code to the Mirror
    33 Posts 5 Posters 17.8k Views 5 Watching
      sdetweil @stro
      @stro MagicMirror is a web page.
      It displays html. The modules generate a small section matching their requirements, and mm injects that onto the page in the configured position.
      The module can get it’s data from anywhere. API, file system, database.
      You have an API, which returns data, not html. Some code has to convert the data into displayable html
        stro
        @sdetweil thanks for helping me.
        I have the code (pastebin) who put the data, i‘m looking for, in a HTML Output. If i open the html file like this
        file:///home/pi/MagicMirror/modules/test/mopidy.html
        everything is okay.
        But if open this HTML File with the Mirrorpath like this:
        localhost:8080/modules/test/mopidy.html
        It shows me nothing. And i wonder why.
          sdetweil @stro
          @stro open the developers window, ctrl-shift-i, select the console tab and scroll up to see any errors
            stacywebb
            Check your
            mopidy.conf
            located at:
            ~/.config/mopidy/mopidy.conf
            Look for this section:
            [http]
            enabled = true
            hostname = 127.0.0.1
            port = 6680
            static_dir =
            zeroconf = Mopidy HTTP server on $hostname
            allowed_origins =
            csrf_protection = true
            Take note of the hostname part.
            If your’s looks like the above instead of using localhost in the url, use the ip address or host name of the mirror.
            Examples:
            mirror.local:8080/modules/test/mopidy.html
            or
            10.x.x.x:8080/modules/test/mopidy.html
            I tested the code you posted on pastebin and it works as expected for me.
            Only tested using the hostname of the Mirror from external browser. Not locally on the machine.
              stro
              I was able to solve that problem.
              MPD port was double busy. Apparently 2 instances of Mopidy were running.
              Now the module MMM-MPD runs under a few specials:
              During the installation the folder name has to be changed according to the config file.
              The config file value maxRows must not be 0!
              The display will only update after a song change!
              It was hard to find this specifics, but I thank everyone for the help!
              • L Offline
                Leobo
                Thank You @stro, This work great. Im rename folder MMM-MPD to mod_client and move to MagicMirror module, From MagicMirror/module/mpd_client npm install and work.
                  dnj0104 @Leobo
                  @Leobo said in Add JS Code to the Mirror:
                  Something like this happens to me, but my module is from user coderpussy @github , pretty new fork, maybe I got some failure from moodeaudio devs, but I dont think, so anyway here is some of my errors.
                  if change folder name mmm-mpd to mpd_client errors in MM startup:
                  alerts in MagicMirror startup:
                  WARNING! Could not validate config file. Starting with default configuration. Please correct syntax errors at or above this line: ReferenceError: NodeHelper is not defined
                      at Object.<anonymous> (/home/pi/MagicMirror/modules/mpd_client/node_helper.js:4:18)
                      at Module._compile (internal/modules/cjs/loader.js:786:30)
                      at Object.Module._extensions..js (internal/modules/cjs/loader.js:798:10)
                      at Module.load (internal/modules/cjs/loader.js:645:32)
                      at Function.Module._load (internal/modules/cjs/loader.js:560:12)
                      at Module.require (internal/modules/cjs/loader.js:685:19)
                      at require (internal/modules/cjs/helpers.js:16:16)
                      at loadModule (/home/pi/MagicMirror/js/app.js:134:17)
                      at loadNextModule (/home/pi/MagicMirror/js/app.js:169:5)
                      at /home/pi/MagicMirror/js/app.js:171:6
                  change folder name from mmm-mpd to mpd-client:
                  Result: No errors in MM-startup but mpd-module does not start.
                  **Looking for errors in MM-dev tools with folder named to mpd-module>**
                  Errors:
                  Load script: modules/mpd_client//mpd_client.js
                  :8080/modules/mpd_cl…nt//mpd_client.js:1 Failed to load resource: the server responded with a status of 404 (Not Found)
                  loader.js:186 Error on loading script: modules/mpd_client//mpd_client.js
                  module in mm-config array looks like
                  this.
                  		module: "mpd_client",
                  		position: "top_right",	// This can be any of the regions.
                  			hostname:"mpd@moodeaudio@rpi3b+=IPnumber)",
                  			port:6600
                    sdetweil @dnj0104
                    @dnj0104 there is probably more to the error message this also happens when there is some library required by a module not found at startup
                    u can also run
                    npm run config:check
                    to review any syntax errors in the config.js file
                      dnj0104 @sdetweil
                      @sdetweil said in Add JS Code to the Mirror:
                      in magicmirror/modules
                      or in magicmirror/modules/mpd-module ?
                      Thinks the whole module has to be rebuilt…
                        sdetweil @dnj0104
                        @dnj0104 in MagicMirror
                          dnj0104 @sdetweil
                          then I got
                          [2020-10-23 23:46:08.836] [INFO]   Checking file...  /home/pi/MagicMirror/config/config.js
                          [2020-10-23 23:46:09.049] [INFO]   Your configuration file doesn't contain syntax errors :)
                            sdetweil @dnj0104
                            @dnj0104 ok, so the error that causes the default config to load is caused by some other problem.
                            missing module, or some other failure
                            can u show the MM startup messages (from the window where you do npm start)
                            a module consists of the folder name
                            MMM-MPD
                            and its main js file
                            MMM-MPD.js
                            and inside MMM-MPD.js is the module register statement
                            Module.register("MMM-MPD", {
                            and in config.js
                                 module: 'MMM-MPD',
                            this causes MM to look for the folder, filename and file contents in that order
                            SO, it SOUNDS like from a prior post, that the REAL name is
                            mod_client
                            (so there must be the right folder name, file name and file contents of
                            mod_client
                            if so, you can rename the folder (mv is the rename command on linux)
                            then in config.js you need
                              module:'mod_client',
                            see the topic ‘How to add modules’ in my signature
                              dnj0104
                              mod_client
                              errors folder and file config.js (mmm-mpd) renamed to mod:
                              [2020-10-24 00:03:42.600] [ERROR]  WARNING! Could not validate config file. Starting with default configuration. Please correct syntax errors at or above this line: ReferenceError: NodeHelper is not defined
                                  at Object.<anonymous> (/home/pi/MagicMirror/modules/mod_client/node_helper.js:4:18)
                              [2020-10-24 00:03:42.601] [LOG]    Loading module helpers ...
                              [2020-10-24 00:03:42.602] [LOG]    No helper found for module: alert.
                              [2020-10-24 00:03:42.603] [LOG]    Initializing new module helper ...
                              [2020-10-24 00:03:42.604] [LOG]    Module helper loaded: updatenotification
                              [2020-10-24 00:03:42.605] [LOG]    No helper found for module: clock.
                              [2020-10-24 00:03:42.616] [LOG]    Initializing new module helper ...
                              [2020-10-24 00:03:42.617] [LOG]    Module helper loaded: calendar
                              [2020-10-24 00:03:42.618] [LOG]    No helper found for module: .
                              [2020-10-24 00:03:42.619] [LOG]    No helper found for module: currentweather.
                              [2020-10-24 00:03:42.620] [LOG]    No helper found for module: weatherforecast.
                              [2020-10-24 00:03:42.621] [LOG]    Initializing new module helper ...
                              [2020-10-24 00:03:42.621] [LOG]    Module helper loaded: newsfeed
                              [2020-10-24 00:03:42.623] [ERROR]  App threw an error during load
                              [2020-10-24 00:03:42.625] [ERROR]  ReferenceError: NodeHelper is not defined
                              [2020-10-24 00:03:42.627] [ERROR]  Whoops! There was an uncaught exception...
                              [2020-10-24 00:03:42.628] [ERROR]  ReferenceError: NodeHelper is not defined
                              ------result---- dark—screen electron just showed black----------
                              roll back, Folder named to mod-client and in config.js and mpd_client.js to mod_client.
                              Result; electron start with no error all my modules shows, but not mod_client aka mpd_client
                                sdetweil @dnj0104
                                @dnj0104 what MM version are you running on? this problem was fixed in 2.10
                                do this
                                from the MM folder
                                git checkout modules/node_modules/node_helper/index.js
                                  dnj0104
                                  I got version 20.13.0
                                  from your git command i get output
                                  pi@raspberrypi:~/MagicMirror $ git checkout modules/node_modules/node_helper/index.js
                                  error: pathspec 'modules/node_modules/node_helper/index.js' did not match any file(s) known to git
                                    sdetweil @dnj0104
                                    @dnj0104 can you do
                                    grep version package.json
                                      dnj0104
                                      yes and and result is
                                      pi@raspberrypi:~/MagicMirror $ grep version package.json
                                      	"version": "2.13.0",
                                        @dnj0104 yeh, mess
                                        this module should be installed like this to make up for the name problem
                                        cd ~/ MagicMirror/modules
                                        git clone https://github.com/timjong93/MMM-MPD.git mpd_client
                                        cd mpd_client
                                        npm install
                                        then everything matches
                                          sdetweil @dnj0104
                                          @dnj0104 thanks… so the git checkout would not have worked, sorry…
                                          try the install as I suggest above
                                            dnj0104 @sdetweil
                                            so then i throw mpd client folder in trash and follow your
                                            install instructions?
                                            because I believe there have been a problem when I first installed mpd_client, I did not been clear where the npm install should been placed, if you read in mpd-client readme.md maybe you understand, english is not my first language, and my linux-fu is below first grade :)
