    Add JS Code to the Mirror
    33 Posts 5 Posters 17.8k Views 5 Watching
      stro
        So, u need to change the HTML returned by MMM-MPD to look like the HTML in the file. But only the section that is your real user interface.
        See the getDom() function which would build the html.
          stro
          No, i want to show the current playing Track from mopidy.
          Either by MMM-MPD (i didn‘t get to work)
          Or by the Code i found on the web ( i didn‘t get to work)
            sdetweil @stro
            @stro MagicMirror is a web page.
            It displays html. The modules generate a small section matching their requirements, and mm injects that onto the page in the configured position.
            The module can get it’s data from anywhere. API, file system, database.
            You have an API, which returns data, not html. Some code has to convert the data into displayable html
              stro
              @sdetweil thanks for helping me.
              I have the code (pastebin) who put the data, i‘m looking for, in a HTML Output. If i open the html file like this
              file:///home/pi/MagicMirror/modules/test/mopidy.html
              everything is okay.
              But if open this HTML File with the Mirrorpath like this:
              localhost:8080/modules/test/mopidy.html
              It shows me nothing. And i wonder why.
                sdetweil @stro
                @stro open the developers window, ctrl-shift-i, select the console tab and scroll up to see any errors
                  stacywebb
                  Check your
                  mopidy.conf
                  located at:
                  ~/.config/mopidy/mopidy.conf
                  Look for this section:
                  [http]
                  enabled = true
                  hostname = 127.0.0.1
                  port = 6680
                  static_dir =
                  zeroconf = Mopidy HTTP server on $hostname
                  allowed_origins =
                  csrf_protection = true
                  Take note of the hostname part.
                  If your’s looks like the above instead of using localhost in the url, use the ip address or host name of the mirror.
                  Examples:
                  mirror.local:8080/modules/test/mopidy.html
                  or
                  10.x.x.x:8080/modules/test/mopidy.html
                  I tested the code you posted on pastebin and it works as expected for me.
                  Only tested using the hostname of the Mirror from external browser. Not locally on the machine.
                    stro
                    I was able to solve that problem.
                    MPD port was double busy. Apparently 2 instances of Mopidy were running.
                    Now the module MMM-MPD runs under a few specials:
                    During the installation the folder name has to be changed according to the config file.
                    The config file value maxRows must not be 0!
                    The display will only update after a song change!
                    It was hard to find this specifics, but I thank everyone for the help!
                    • L Offline
                      Leobo
                      Thank You @stro, This work great. Im rename folder MMM-MPD to mod_client and move to MagicMirror module, From MagicMirror/module/mpd_client npm install and work.
                        dnj0104 @Leobo
                        @Leobo said in Add JS Code to the Mirror:
                        Something like this happens to me, but my module is from user coderpussy @github , pretty new fork, maybe I got some failure from moodeaudio devs, but I dont think, so anyway here is some of my errors.
                        if change folder name mmm-mpd to mpd_client errors in MM startup:
                        alerts in MagicMirror startup:
                        WARNING! Could not validate config file. Starting with default configuration. Please correct syntax errors at or above this line: ReferenceError: NodeHelper is not defined
                            at Object.<anonymous> (/home/pi/MagicMirror/modules/mpd_client/node_helper.js:4:18)
                            at Module._compile (internal/modules/cjs/loader.js:786:30)
                            at Object.Module._extensions..js (internal/modules/cjs/loader.js:798:10)
                            at Module.load (internal/modules/cjs/loader.js:645:32)
                            at Function.Module._load (internal/modules/cjs/loader.js:560:12)
                            at Module.require (internal/modules/cjs/loader.js:685:19)
                            at require (internal/modules/cjs/helpers.js:16:16)
                            at loadModule (/home/pi/MagicMirror/js/app.js:134:17)
                            at loadNextModule (/home/pi/MagicMirror/js/app.js:169:5)
                            at /home/pi/MagicMirror/js/app.js:171:6
                        change folder name from mmm-mpd to mpd-client:
                        Result: No errors in MM-startup but mpd-module does not start.
                        **Looking for errors in MM-dev tools with folder named to mpd-module>**
                        Errors:
                        Load script: modules/mpd_client//mpd_client.js
                        :8080/modules/mpd_cl…nt//mpd_client.js:1 Failed to load resource: the server responded with a status of 404 (Not Found)
                        loader.js:186 Error on loading script: modules/mpd_client//mpd_client.js
                        module in mm-config array looks like
                        this.
                        		module: "mpd_client",
                        		position: "top_right",	// This can be any of the regions.
                        			hostname:"mpd@moodeaudio@rpi3b+=IPnumber)",
                        			port:6600
                          sdetweil @dnj0104
                          @dnj0104 there is probably more to the error message this also happens when there is some library required by a module not found at startup
                          u can also run
                          npm run config:check
                          to review any syntax errors in the config.js file
                            dnj0104 @sdetweil
                            @sdetweil said in Add JS Code to the Mirror:
                            in magicmirror/modules
                            or in magicmirror/modules/mpd-module ?
                            Thinks the whole module has to be rebuilt…
                              sdetweil @dnj0104
                              @dnj0104 in MagicMirror
                                dnj0104 @sdetweil
                                then I got
                                [2020-10-23 23:46:08.836] [INFO]   Checking file...  /home/pi/MagicMirror/config/config.js
                                [2020-10-23 23:46:09.049] [INFO]   Your configuration file doesn't contain syntax errors :)
                                  sdetweil @dnj0104
                                  @dnj0104 ok, so the error that causes the default config to load is caused by some other problem.
                                  missing module, or some other failure
                                  can u show the MM startup messages (from the window where you do npm start)
                                  a module consists of the folder name
                                  MMM-MPD
                                  and its main js file
                                  MMM-MPD.js
                                  and inside MMM-MPD.js is the module register statement
                                  Module.register("MMM-MPD", {
                                  and in config.js
                                       module: 'MMM-MPD',
                                  this causes MM to look for the folder, filename and file contents in that order
                                  SO, it SOUNDS like from a prior post, that the REAL name is
                                  mod_client
                                  (so there must be the right folder name, file name and file contents of
                                  mod_client
                                  if so, you can rename the folder (mv is the rename command on linux)
                                  then in config.js you need
                                    module:'mod_client',
                                  see the topic ‘How to add modules’ in my signature
                                    dnj0104
                                    mod_client
                                    errors folder and file config.js (mmm-mpd) renamed to mod:
                                    [2020-10-24 00:03:42.600] [ERROR]  WARNING! Could not validate config file. Starting with default configuration. Please correct syntax errors at or above this line: ReferenceError: NodeHelper is not defined
                                        at Object.<anonymous> (/home/pi/MagicMirror/modules/mod_client/node_helper.js:4:18)
                                    [2020-10-24 00:03:42.601] [LOG]    Loading module helpers ...
                                    [2020-10-24 00:03:42.602] [LOG]    No helper found for module: alert.
                                    [2020-10-24 00:03:42.603] [LOG]    Initializing new module helper ...
                                    [2020-10-24 00:03:42.604] [LOG]    Module helper loaded: updatenotification
                                    [2020-10-24 00:03:42.605] [LOG]    No helper found for module: clock.
                                    [2020-10-24 00:03:42.616] [LOG]    Initializing new module helper ...
                                    [2020-10-24 00:03:42.617] [LOG]    Module helper loaded: calendar
                                    [2020-10-24 00:03:42.618] [LOG]    No helper found for module: .
                                    [2020-10-24 00:03:42.619] [LOG]    No helper found for module: currentweather.
                                    [2020-10-24 00:03:42.620] [LOG]    No helper found for module: weatherforecast.
                                    [2020-10-24 00:03:42.621] [LOG]    Initializing new module helper ...
                                    [2020-10-24 00:03:42.621] [LOG]    Module helper loaded: newsfeed
                                    [2020-10-24 00:03:42.623] [ERROR]  App threw an error during load
                                    [2020-10-24 00:03:42.625] [ERROR]  ReferenceError: NodeHelper is not defined
                                    [2020-10-24 00:03:42.627] [ERROR]  Whoops! There was an uncaught exception...
                                    [2020-10-24 00:03:42.628] [ERROR]  ReferenceError: NodeHelper is not defined
                                    ------result---- dark—screen electron just showed black----------
                                    roll back, Folder named to mod-client and in config.js and mpd_client.js to mod_client.
                                    Result; electron start with no error all my modules shows, but not mod_client aka mpd_client
                                      sdetweil @dnj0104
                                      @dnj0104 what MM version are you running on? this problem was fixed in 2.10
                                      do this
                                      from the MM folder
                                      git checkout modules/node_modules/node_helper/index.js
                                        dnj0104
                                        I got version 20.13.0
                                        from your git command i get output
                                        pi@raspberrypi:~/MagicMirror $ git checkout modules/node_modules/node_helper/index.js
                                        error: pathspec 'modules/node_modules/node_helper/index.js' did not match any file(s) known to git
                                          sdetweil @dnj0104
                                          @dnj0104 can you do
                                          grep version package.json
                                            dnj0104
                                            yes and and result is
                                            pi@raspberrypi:~/MagicMirror $ grep version package.json
                                            	"version": "2.13.0",
