    Add JS Code to the Mirror
    33 Posts 5 Posters 17.8k Views 5 Watching
      So, u need to change the HTML returned by MMM-MPD to look like the HTML in the file. But only the section that is your real user interface.
      See the getDom() function which would build the html.
        stro
        No, i want to show the current playing Track from mopidy.
        Either by MMM-MPD (i didn‘t get to work)
        Or by the Code i found on the web ( i didn‘t get to work)
          sdetweil @stro
          @stro MagicMirror is a web page.
          It displays html. The modules generate a small section matching their requirements, and mm injects that onto the page in the configured position.
          The module can get it’s data from anywhere. API, file system, database.
          You have an API, which returns data, not html. Some code has to convert the data into displayable html
            stro
            @sdetweil thanks for helping me.
            I have the code (pastebin) who put the data, i‘m looking for, in a HTML Output. If i open the html file like this
            file:///home/pi/MagicMirror/modules/test/mopidy.html
            everything is okay.
            But if open this HTML File with the Mirrorpath like this:
            localhost:8080/modules/test/mopidy.html
            It shows me nothing. And i wonder why.
              sdetweil @stro
              @stro open the developers window, ctrl-shift-i, select the console tab and scroll up to see any errors
                stacywebb
                Check your
                mopidy.conf
                located at:
                ~/.config/mopidy/mopidy.conf
                Look for this section:
                [http]
                enabled = true
                hostname = 127.0.0.1
                port = 6680
                static_dir =
                zeroconf = Mopidy HTTP server on $hostname
                allowed_origins =
                csrf_protection = true
                Take note of the hostname part.
                If your’s looks like the above instead of using localhost in the url, use the ip address or host name of the mirror.
                Examples:
                mirror.local:8080/modules/test/mopidy.html
                or
                10.x.x.x:8080/modules/test/mopidy.html
                I tested the code you posted on pastebin and it works as expected for me.
                Only tested using the hostname of the Mirror from external browser. Not locally on the machine.
                  stro
                  I was able to solve that problem.
                  MPD port was double busy. Apparently 2 instances of Mopidy were running.
                  Now the module MMM-MPD runs under a few specials:
                  During the installation the folder name has to be changed according to the config file.
                  The config file value maxRows must not be 0!
                  The display will only update after a song change!
                  It was hard to find this specifics, but I thank everyone for the help!
                  • L Offline
                    Leobo
                    Thank You @stro, This work great. Im rename folder MMM-MPD to mod_client and move to MagicMirror module, From MagicMirror/module/mpd_client npm install and work.
                      dnj0104 @Leobo
                      @Leobo said in Add JS Code to the Mirror:
                      Something like this happens to me, but my module is from user coderpussy @github , pretty new fork, maybe I got some failure from moodeaudio devs, but I dont think, so anyway here is some of my errors.
                      if change folder name mmm-mpd to mpd_client errors in MM startup:
                      alerts in MagicMirror startup:
                      WARNING! Could not validate config file. Starting with default configuration. Please correct syntax errors at or above this line: ReferenceError: NodeHelper is not defined
                          at Object.<anonymous> (/home/pi/MagicMirror/modules/mpd_client/node_helper.js:4:18)
                          at Module._compile (internal/modules/cjs/loader.js:786:30)
                          at Object.Module._extensions..js (internal/modules/cjs/loader.js:798:10)
                          at Module.load (internal/modules/cjs/loader.js:645:32)
                          at Function.Module._load (internal/modules/cjs/loader.js:560:12)
                          at Module.require (internal/modules/cjs/loader.js:685:19)
                          at require (internal/modules/cjs/helpers.js:16:16)
                          at loadModule (/home/pi/MagicMirror/js/app.js:134:17)
                          at loadNextModule (/home/pi/MagicMirror/js/app.js:169:5)
                          at /home/pi/MagicMirror/js/app.js:171:6
                      change folder name from mmm-mpd to mpd-client:
                      Result: No errors in MM-startup but mpd-module does not start.
                      **Looking for errors in MM-dev tools with folder named to mpd-module>**
                      Errors:
                      Load script: modules/mpd_client//mpd_client.js
                      :8080/modules/mpd_cl…nt//mpd_client.js:1 Failed to load resource: the server responded with a status of 404 (Not Found)
                      loader.js:186 Error on loading script: modules/mpd_client//mpd_client.js
                      module in mm-config array looks like
                      this.
                      		module: "mpd_client",
                      		position: "top_right",	// This can be any of the regions.
                      			hostname:"mpd@moodeaudio@rpi3b+=IPnumber)",
                      			port:6600
                        sdetweil @dnj0104
                        @dnj0104 there is probably more to the error message this also happens when there is some library required by a module not found at startup
                        u can also run
                        npm run config:check
                        to review any syntax errors in the config.js file
                          dnj0104 @sdetweil
                          @sdetweil said in Add JS Code to the Mirror:
                          in magicmirror/modules
                          or in magicmirror/modules/mpd-module ?
                          Thinks the whole module has to be rebuilt…
                            sdetweil @dnj0104
                            @dnj0104 in MagicMirror
                              dnj0104 @sdetweil
                              then I got
                              [2020-10-23 23:46:08.836] [INFO]   Checking file...  /home/pi/MagicMirror/config/config.js
                              [2020-10-23 23:46:09.049] [INFO]   Your configuration file doesn't contain syntax errors :)
                                sdetweil @dnj0104
                                @dnj0104 ok, so the error that causes the default config to load is caused by some other problem.
                                missing module, or some other failure
                                can u show the MM startup messages (from the window where you do npm start)
                                a module consists of the folder name
                                MMM-MPD
                                and its main js file
                                MMM-MPD.js
                                and inside MMM-MPD.js is the module register statement
                                Module.register("MMM-MPD", {
                                and in config.js
                                     module: 'MMM-MPD',
                                this causes MM to look for the folder, filename and file contents in that order
                                SO, it SOUNDS like from a prior post, that the REAL name is
                                mod_client
                                (so there must be the right folder name, file name and file contents of
                                mod_client
                                if so, you can rename the folder (mv is the rename command on linux)
                                then in config.js you need
                                  module:'mod_client',
                                see the topic ‘How to add modules’ in my signature
                                  dnj0104
                                  mod_client
                                  errors folder and file config.js (mmm-mpd) renamed to mod:
                                  [2020-10-24 00:03:42.600] [ERROR]  WARNING! Could not validate config file. Starting with default configuration. Please correct syntax errors at or above this line: ReferenceError: NodeHelper is not defined
                                      at Object.<anonymous> (/home/pi/MagicMirror/modules/mod_client/node_helper.js:4:18)
                                  [2020-10-24 00:03:42.601] [LOG]    Loading module helpers ...
                                  [2020-10-24 00:03:42.602] [LOG]    No helper found for module: alert.
                                  [2020-10-24 00:03:42.603] [LOG]    Initializing new module helper ...
                                  [2020-10-24 00:03:42.604] [LOG]    Module helper loaded: updatenotification
                                  [2020-10-24 00:03:42.605] [LOG]    No helper found for module: clock.
                                  [2020-10-24 00:03:42.616] [LOG]    Initializing new module helper ...
                                  [2020-10-24 00:03:42.617] [LOG]    Module helper loaded: calendar
                                  [2020-10-24 00:03:42.618] [LOG]    No helper found for module: .
                                  [2020-10-24 00:03:42.619] [LOG]    No helper found for module: currentweather.
                                  [2020-10-24 00:03:42.620] [LOG]    No helper found for module: weatherforecast.
                                  [2020-10-24 00:03:42.621] [LOG]    Initializing new module helper ...
                                  [2020-10-24 00:03:42.621] [LOG]    Module helper loaded: newsfeed
                                  [2020-10-24 00:03:42.623] [ERROR]  App threw an error during load
                                  [2020-10-24 00:03:42.625] [ERROR]  ReferenceError: NodeHelper is not defined
                                  [2020-10-24 00:03:42.627] [ERROR]  Whoops! There was an uncaught exception...
                                  [2020-10-24 00:03:42.628] [ERROR]  ReferenceError: NodeHelper is not defined
                                  ------result---- dark—screen electron just showed black----------
                                  roll back, Folder named to mod-client and in config.js and mpd_client.js to mod_client.
                                  Result; electron start with no error all my modules shows, but not mod_client aka mpd_client
                                    sdetweil @dnj0104
                                    @dnj0104 what MM version are you running on? this problem was fixed in 2.10
                                    do this
                                    from the MM folder
                                    git checkout modules/node_modules/node_helper/index.js
                                      dnj0104
                                      I got version 20.13.0
                                      from your git command i get output
                                      pi@raspberrypi:~/MagicMirror $ git checkout modules/node_modules/node_helper/index.js
                                      error: pathspec 'modules/node_modules/node_helper/index.js' did not match any file(s) known to git
                                        sdetweil @dnj0104
                                        @dnj0104 can you do
                                        grep version package.json
                                          dnj0104
                                          yes and and result is
                                          pi@raspberrypi:~/MagicMirror $ grep version package.json
                                          	"version": "2.13.0",
                                            @dnj0104 yeh, mess
                                            this module should be installed like this to make up for the name problem
                                            cd ~/ MagicMirror/modules
                                            git clone https://github.com/timjong93/MMM-MPD.git mpd_client
                                            cd mpd_client
                                            npm install
                                            then everything matches
