    Getting MM running on Debian 10 not on a RPi
    1 Posts 1 Posters 2.9k Views 2 Watching
    • N Offline
      nimbu
      Hi Guys,
      I had a very specific use case where I wanted to use Debian (LXDE) with an old laptop to run Magic Mirror.
      I am by no means a linux expert! But I did some tinkering and couldnt get the install script working. The following steps might help you getting MM running on a Debian 10 machine. I used the debian-live-10.0.0-amd64-lxde.iso to install Debian.
      Once installed, log in to the system with the user you created during setup.
      Open a terminal window, and run the following:
      su
      Enter the root password when prompted and then run the following:
      apt-get update
      apt-get upgrade
      apt-get install openssh-server
      Once complete I found it easier to go back to my main machine and use putty.
      Open a Putty connection to your machine, login with the user you created during setup
      Once at the terminal, type the following:
      su
      apt-get --assume-yes install curl wget git build-essential unzip gcc g++ make
      curl -sL https://deb.nodesource.com/setup_10.x | sudo -E bash -
      apt-get update
      apt-get install -y nodejs
      apt-get install -y npm
      curl -sL https://dl.yarnpkg.com/debian/pubkey.gpg | sudo apt-key add -
      echo "deb https://dl.yarnpkg.com/debian/ stable main" | sudo tee /etc/apt/sources.list.d/yarn.list
      apt-get update
      apt-get install yarn
      exit
      This should return you to the mm user you have setup, at the command line type the following:
      git clone --depth=1 https://github.com/MichMich/MagicMirror.git
      cd MagicMirror/
      cp config/config.js.sample config/config.js
      npm install
      npm audit fix
      Close out the session and then go back to the machine and run a terminal prompt and type the following to start mm!
      cd MagicMirror
      npm start
      YMMV but hope this helps others out there trying to get this to work too.
