    MM won't run, blank screen with cursor showing after updating
    81 Posts 2 Posters 38.6k Views 2 Watching
      @sdetweil also, in the node_modules/pocketsphinx_continuous/index.js
      show me this
       var pc = spawn('pocketsphinx_continuous', [
          '-adcdev',
          'plughw:' + this.microphone,
          '-inmic',
          'yes',
          '-lm',
          'modules/MMM-voice/' + this.setId + '.lm',
          '-dict',
          'modules/MMM-voice/' + this.setId + '.dic'
      also check for the two files in the mmm-voice folder MMM-voice.lm and MMM-voice.dic
        jmartin1009 @sdetweil
        @sdetweil this is the entire index file, didn’t see that anywhere
        const spawn = require('child_process').spawn;
        const EventEmitter = require('events').EventEmitter;
        const util = require('util');
        const reservedEvents = {
          close: true,
          error: true,
          data: true,
          end: true,
          readable: true,
          drain: true,
          finish: true,
          pipe: true,
          unpipe: true
        function PocketSphinxContinuous(config) {
          this.setId = config.setId;
          this.verbose = config.verbose;
          this.microphone = config.microphone;
          this.autostart = config.autostart;
          if (!config.hasOwnProperty('autostart') || config.autostart === true) {
            this.start();
          EventEmitter.call(this);
        PocketSphinxContinuous.prototype.start = function() {
          if (!this.isListening()) {
            let mic = this.microphone;
            // if name starts with number
            if (typeof this.microphone === 'number' || this.microphone.match(/^\d/)) {
              mic = `plughw:${this.microphone}`;
            this._psc = spawn('pocketsphinx_continuous', [
              '-adcdev',
              mic,
              '-inmic',
              'yes',
              '-lm',
              `modules/${this.setId}/${this.setId}.lm`,
              '-dict',
              `modules/${this.setId}/${this.setId}.dic`
            this._psc.stdout.on('data', data => {
              const output = data.toString().trim();
              if (output) {
                this.emit('data', output);
              // Also try to emit an event for the actual data, unless of course the
              // event is a reserved one.
              const eventName = output.toLowerCase();
              if (!reservedEvents[eventName]) {
                this.emit(eventName, output);
            this._psc.stderr.on('data', data => {
              if (this.verbose && output) {
                this.emit('debug', data);
            this._psc.on('close', code => {
              this.emit('error', code);
            this._psc.on('error', err => {
              this.emit('error', err);
        PocketSphinxContinuous.prototype.stop = function() {
          if (this.isListening()) {
            this._psc.kill();
        PocketSphinxContinuous.prototype.isListening = function() {
          return this._psc && !this._psc.killed;
        util.inherits(PocketSphinxContinuous, EventEmitter);
        module.exports = PocketSphinxContinuous;
        also, both of those files are there.
          sdetweil @jmartin1009
          @jmartin1009 said in MM won't run, blank screen with cursor showing after updating:
          from your response
          >       '-adcdev',
          >       mic,
          >       '-inmic',
          >       'yes',
          >       '-lm',
          >       '-dict',
          so, only the path to the files can be wrong…
          so, change them to (assume u are running as user pi)
                 '-adcdev',
                 mic,
                 '-inmic',
                 'yes',
                 '-lm',
                 `/home/pi/MagicMirror/modules/${this.setId}/${this.setId}.lm`,
                 '-dict',
                 `/home/pi/MagicMirror/modules/${this.setId}/${this.setId}.dic`
            @jmartin1009 you have the file with my fixes in it… btw
              @sdetweil which file? and i’ll go change those right now
                @jmartin1009
                ~/MagicMirror/modules/MMM-voice/node_modules/pocketsphinx_continuous/index.js
                same file u just showed me
                J 2 Replies Last reply Reply Quote 0
                  @sdetweil oh yeah, im going to change the file paths in it right now in the one you sent last.
                    @sdetweil just changed those file paths, tried running MM, still getting “ERROR undefined” next to the little microphone
                      @jmartin1009 yeh, only care about the debug log
                        @sdetweil ```
                        INFO: pocketsphinx.c(153): Parsed model-specific feature parameters from /usr/local/share/pocketsphinx/model/en-us/en-us/feat.params
                        Current configuration:
                        [NAME] [DEFLT] [VALUE]
                        -agc none none
                        -agcthresh 2.0 2.000000e+00
                        -allphone
                        -allphone_ci yes yes
                        -alpha 0.97 9.700000e-01
                        -ascale 20.0 2.000000e+01
                        -aw 1 1
                        -backtrace no no
                        -beam 1e-48 1.000000e-48
                        -bestpath yes yes
                        -bestpathlw 9.5 9.500000e+00
                        -ceplen 13 13
                        -cmn live batch
                        -cmninit 40,3,-1 41.00,-5.29,-0.12,5.09,2.48,-4.07,-1.37,-1.78,-5.08,-2.05,-6.45,-1.42,1.17
                        -compallsen no no
                        -dict /home/pi/MagicMirror/modules/MMM-voice/MMM-voice.dic
                        -dictcase no no
                        -dither no no
                        -doublebw no no
                        -ds 1 1
                        -fdict
                        -feat 1s_c_d_dd 1s_c_d_dd
                        -featparams
                        -fillprob 1e-8 1.000000e-08
                        -frate 100 100
                        -fsg
                        -fsgusealtpron yes yes
                        -fsgusefiller yes yes
                        -fwdflat yes yes
                        -fwdflatbeam 1e-64 1.000000e-64
                        -fwdflatefwid 4 4
                        -fwdflatlw 8.5 8.500000e+00
                        -fwdflatsfwin 25 25
                        -fwdflatwbeam 7e-29 7.000000e-29
                        -fwdtree yes yes
                        -hmm /usr/local/share/pocketsphinx/model/en-us/en-us
                        -input_endian little little
                        -jsgf
                        -keyphrase
                        -kws
                        -kws_delay 10 10
                        -kws_plp 1e-1 1.000000e-01
                        -kws_threshold 1e-30 1.000000e-30
                        -latsize 5000 5000
                        -lda
                        -ldadim 0 0
                        -lifter 0 22
                        -lm /home/pi/MagicMirror/modules/MMM-voice/MMM-voice.lm
                        -lmctl
                        -lmname
                        -logbase 1.0001 1.000100e+00
                        -logfn
                        -logspec no no
                        -lowerf 133.33334 1.300000e+02
                        -lpbeam 1e-40 1.000000e-40
                        -lponlybeam 7e-29 7.000000e-29
                        -lw 6.5 6.500000e+00
                        -maxhmmpf 30000 30000
                        -maxwpf -1 -1
                        -mdef
                        -mean
                        -mfclogdir
                        -min_endfr 0 0
                        -mixw
                        -mixwfloor 0.0000001 1.000000e-07
                        -mllr
                        -mmap yes yes
                        -ncep 13 13
                        -nfft 512 512
                        -nfilt 40 25
                        -nwpen 1.0 1.000000e+00
                        -pbeam 1e-48 1.000000e-48
                        -pip 1.0 1.000000e+00
                        -pl_beam 1e-10 1.000000e-10
                        -pl_pbeam 1e-10 1.000000e-10
                        -pl_pip 1.0 1.000000e+00
                        -pl_weight 3.0 3.000000e+00
                        -pl_window 5 5
                        -rawlogdir
                        -remove_dc no no
                        -remove_noise yes yes
                        -remove_silence yes yes
                        -round_filters yes yes
                        -samprate 16000 1.600000e+04
                        -seed -1 -1
                        -sendump
                        -senlogdir
                        -senmgau
                        -silprob 0.005 5.000000e-03
                        -smoothspec no no
                        -svspec 0-12/13-25/26-38
                        -tmat
                        -tmatfloor 0.0001 1.000000e-04
                        -topn 4 4
                        -topn_beam 0 0
                        -toprule
                        -transform legacy dct
                        -unit_area yes yes
                        -upperf 6855.4976 6.800000e+03
                        -uw 1.0 1.000000e+00
                        -vad_postspeech 50 50
                        -vad_prespeech 20 20
                        -vad_startspeech 10 10
                        -vad_threshold 3.0 3.000000e+00
                        -var
                        -varfloor 0.0001 1.000000e-04
                        -varnorm no no
                        -verbose no no
                        -warp_params
                        -warp_type inverse_linear inverse_linear
                        -wbeam 7e-29 7.000000e-29
                        -wip 0.65 6.500000e-01
                        -wlen 0.025625 2.562500e-02
                        INFO: feat.c(715): Initializing feature stream to type: ‘1s_c_d_dd’, ceplen=13, CMN=‘batch’, VARNORM=‘no’, AGC=‘none’
                        INFO: acmod.c(162): Using subvector specification 0-12/13-25/26-38
                        INFO: mdef.c(518): Reading model definition: /usr/local/share/pocketsphinx/model/en-us/en-us/mdef
                        INFO: mdef.c(531): Found byte-order mark BMDF, assuming this is a binary mdef file
                        INFO: bin_mdef.c(336): Reading binary model definition: /usr/local/share/pocketsphinx/model/en-us/en-us/mdef
                        INFO: bin_mdef.c(516): 42 CI-phone, 137053 CD-phone, 3 emitstate/phone, 126 CI-sen, 5126 Sen, 29324 Sen-Seq
                        INFO: tmat.c(149): Reading HMM transition probability matrices: /usr/local/share/pocketsphinx/model/en-us/en-us/transition_matrices
                        INFO: acmod.c(113): Attempting to use PTM computation module
                        INFO: ms_gauden.c(127): Reading mixture gaussian parameter: /usr/local/share/pocketsphinx/model/en-us/en-us/means
                        INFO: ms_gauden.c(242): 42 codebook, 3 feature, size:
                        INFO: ms_gauden.c(244): 128x13
                        INFO: ms_gauden.c(127): Reading mixture gaussian parameter: /usr/local/share/pocketsphinx/model/en-us/en-us/variances
                        INFO: ms_gauden.c(304): 222 variance values floored
                        INFO: ptm_mgau.c(475): Loading senones from dump file /usr/local/share/pocketsphinx/model/en-us/en-us/sendump
                        INFO: ptm_mgau.c(499): BEGIN FILE FORMAT DESCRIPTION
                        INFO: ptm_mgau.c(562): Rows: 128, Columns: 5126
                        INFO: ptm_mgau.c(594): Using memory-mapped I/O for senones
                        INFO: ptm_mgau.c(837): Maximum top-N: 4
                        INFO: phone_loop_search.c(114): State beam -225 Phone exit beam -225 Insertion penalty 0
                        INFO: dict.c(320): Allocating 4130 * 20 bytes (80 KiB) for word entries
                        INFO: dict.c(333): Reading main dictionary: /home/pi/MagicMirror/modules/MMM-voice/MMM-voice.dic
                        INFO: dict.c(213): Dictionary size 29, allocated 0 KiB for strings, 0 KiB for phones
                        INFO: dict.c(336): 29 words read
                        INFO: dict.c(358): Reading filler dictionary: /usr/local/share/pocketsphinx/model/en-us/en-us/noisedict
                        INFO: dict.c(213): Dictionary size 34, allocated 0 KiB for strings, 0 KiB for phones
                        INFO: dict.c(361): 5 words read
                        INFO: dict2pid.c(396): Building PID tables for dictionary
                        INFO: dict2pid.c(406): Allocating 42^3 * 2 bytes (144 KiB) for word-initial triphones
                        INFO: dict2pid.c(132): Allocated 21336 bytes (20 KiB) for word-final triphones
                        INFO: dict2pid.c(196): Allocated 21336 bytes (20 KiB) for single-phone word triphones
                        INFO: ngram_model_trie.c(354): Trying to read LM in trie binary format
                        INFO: ngram_model_trie.c(365): Header doesn’t match
                        INFO: ngram_model_trie.c(177): Trying to read LM in arpa format
                        INFO: ngram_model_trie.c(193): LM of order 3
                        INFO: ngram_model_trie.c(195): #1-grams: 25
                        INFO: ngram_model_trie.c(195): #2-grams: 46
                        INFO: ngram_model_trie.c(195): #3-grams: 23
                        INFO: lm_trie.c(474): Training quantizer
                        INFO: lm_trie.c(482): Building LM trie
                        INFO: ngram_search_fwdtree.c(74): Initializing search tree
                        INFO: ngram_search_fwdtree.c(101): 28 unique initial diphones
                        INFO: ngram_search_fwdtree.c(186): Creating search channels
                        INFO: ngram_search_fwdtree.c(323): Max nonroot chan increased to 157
                        INFO: ngram_search_fwdtree.c(333): Created 28 root, 29 non-root channels, 5 single-phone words
                        INFO: ngram_search_fwdflat.c(157): fwdflat: min_ef_width = 4, max_sf_win = 25
                        INFO: continuous.c(307): pocketsphinx_continuous COMPILED ON: Sep 29 2019, AT: 15:24:41
                        Error opening audio device plughw:1,0 for capture: Invalid argument
                        FATAL: “continuous.c”, line 245: Failed to open audio device
                        • 6
                        • 7
                        • 8
                        • 9
                        • 7 / 9
