    MM won't run, blank screen with cursor showing after updating
    81 Posts 2 Posters 49.7k Views 2 Watching
      sdetweil @jmartin1009
      @jmartin1009 yes
      mine looks like
              module: 'MMM-voice',
              position: 'bottom_bar',
                    microphone: '1,0',
                    keyword:        'MAGIC MIRROR',
                    timeout:        15,
                    debug: true,
                    standByMethod: 'hide',
                    startHidden: false
      J 2 Replies Last reply Reply Quote 0
        jmartin1009 @sdetweil
        @sdetweil okay ,i will run it and see what happens.
          @sdetweil still came up saying error :(
            @jmartin1009 ok, add debug: yes,
            to the config
            run again and then look at the debug log in the modules/mmm-Voice folder
              @sdetweil when i add debug: yes, it fails and says this in the terminal:
              > magicmirror@2.6.0 start /home/pi/MagicMirror
              > sh run-start.sh
              Starting MagicMirror: v2.6.0
              Loading config ...
              WARNING! Could not validate config file. Starting with default configuration. Please correct syntax errors at or above this line: ReferenceError: yes is not defined
                  at Object.<anonymous> (/home/pi/MagicMirror/config/config.js:80:15)
                  at Object.<anonymous> (/home/pi/MagicMirror/config/config.js:123:3)
                  at Module._compile (module.js:642:30)
                  at Object.Module._extensions..js (module.js:653:10)
                  at Module.load (module.js:561:32)
                  at tryModuleLoad (module.js:504:12)
                  at Function.Module._load (module.js:496:3)
                  at Module.require (module.js:586:17)
                  at require (internal/module.js:11:18)
                  at loadConfig (/home/pi/MagicMirror/js/app.js:64:12)
              Loading module helpers ...
              No helper found for module: helloworld.
              All module helpers loaded.
              Server started ...
              Launching application.
              Shutting down server...
              Stopping module helper: updatenotification
                jmartin1009 @jmartin1009
                @jmartin1009 AH! it is debug: true, not yes haha after that, it says in debug.log, SORRY FOR LENGTH:
                INFO: pocketsphinx.c(153): Parsed model-specific feature parameters from /usr/local/share/pocketsphinx/model/en-us/en-us/feat.params
                Current configuration:
                [NAME]			[DEFLT]		[VALUE]
                -agc			none		none
                -agcthresh		2.0		2.000000e+00
                -allphone
                -allphone_ci		yes		yes
                -alpha			0.97		9.700000e-01
                -ascale			20.0		2.000000e+01
                -aw			1		1
                -backtrace		no		no
                -beam			1e-48		1.000000e-48
                -bestpath		yes		yes
                -bestpathlw		9.5		9.500000e+00
                -ceplen			13		13
                -cmn			live		batch
                -cmninit		40,3,-1		41.00,-5.29,-0.12,5.09,2.48,-4.07,-1.37,-1.78,-5.08,-2.05,-6.45,-1.42,1.17
                -compallsen		no		no
                -dict					modules/MMM-voice/MMM-voice.dic
                -dictcase		no		no
                -dither			no		no
                -doublebw		no		no
                -ds			1		1
                -fdict
                -feat			1s_c_d_dd	1s_c_d_dd
                -featparams
                -fillprob		1e-8		1.000000e-08
                -frate			100		100
                -fsg
                -fsgusealtpron		yes		yes
                -fsgusefiller		yes		yes
                -fwdflat		yes		yes
                -fwdflatbeam		1e-64		1.000000e-64
                -fwdflatefwid		4		4
                -fwdflatlw		8.5		8.500000e+00
                -fwdflatsfwin		25		25
                -fwdflatwbeam		7e-29		7.000000e-29
                -fwdtree		yes		yes
                -hmm					/usr/local/share/pocketsphinx/model/en-us/en-us
                -input_endian		little		little
                -jsgf
                -keyphrase
                -kws
                -kws_delay		10		10
                -kws_plp		1e-1		1.000000e-01
                -kws_threshold		1e-30		1.000000e-30
                -latsize		5000		5000
                -lda
                -ldadim			0		0
                -lifter			0		22
                -lm					modules/MMM-voice/MMM-voice.lm
                -lmctl
                -lmname
                -logbase		1.0001		1.000100e+00
                -logfn
                -logspec		no		no
                -lowerf			133.33334	1.300000e+02
                -lpbeam			1e-40		1.000000e-40
                -lponlybeam		7e-29		7.000000e-29
                -lw			6.5		6.500000e+00
                -maxhmmpf		30000		30000
                -maxwpf			-1		-1
                -mdef
                -mean
                -mfclogdir
                -min_endfr		0		0
                -mixw
                -mixwfloor		0.0000001	1.000000e-07
                -mllr
                -mmap			yes		yes
                -ncep			13		13
                -nfft			512		512
                -nfilt			40		25
                -nwpen			1.0		1.000000e+00
                -pbeam			1e-48		1.000000e-48
                -pip			1.0		1.000000e+00
                -pl_beam		1e-10		1.000000e-10
                -pl_pbeam		1e-10		1.000000e-10
                -pl_pip			1.0		1.000000e+00
                -pl_weight		3.0		3.000000e+00
                -pl_window		5		5
                -rawlogdir
                -remove_dc		no		no
                -remove_noise		yes		yes
                -remove_silence		yes		yes
                -round_filters		yes		yes
                -samprate		16000		1.600000e+04
                -seed			-1		-1
                -sendump
                -senlogdir
                -senmgau
                -silprob		0.005		5.000000e-03
                -smoothspec		no		no
                -svspec					0-12/13-25/26-38
                -tmat
                -tmatfloor		0.0001		1.000000e-04
                -topn			4		4
                -topn_beam		0		0
                -toprule
                -transform		legacy		dct
                -unit_area		yes		yes
                -upperf			6855.4976	6.800000e+03
                -uw			1.0		1.000000e+00
                -vad_postspeech		50		50
                -vad_prespeech		20		20
                -vad_startspeech	10		10
                -vad_threshold		3.0		3.000000e+00
                -var
                -varfloor		0.0001		1.000000e-04
                -varnorm		no		no
                -verbose		no		no
                -warp_params
                -warp_type		inverse_linear	inverse_linear
                -wbeam			7e-29		7.000000e-29
                -wip			0.65		6.500000e-01
                -wlen			0.025625	2.562500e-02
                INFO: feat.c(715): Initializing feature stream to type: '1s_c_d_dd', ceplen=13, CMN='batch', VARNORM='no', AGC='none'
                INFO: acmod.c(162): Using subvector specification 0-12/13-25/26-38
                INFO: mdef.c(518): Reading model definition: /usr/local/share/pocketsphinx/model/en-us/en-us/mdef
                INFO: mdef.c(531): Found byte-order mark BMDF, assuming this is a binary mdef file
                INFO: bin_mdef.c(336): Reading binary model definition: /usr/local/share/pocketsphinx/model/en-us/en-us/mdef
                INFO: bin_mdef.c(516): 42 CI-phone, 137053 CD-phone, 3 emitstate/phone, 126 CI-sen, 5126 Sen, 29324 Sen-Seq
                INFO: tmat.c(149): Reading HMM transition probability matrices: /usr/local/share/pocketsphinx/model/en-us/en-us/transition_matrices
                INFO: acmod.c(113): Attempting to use PTM computation module
                INFO: ms_gauden.c(127): Reading mixture gaussian parameter: /usr/local/share/pocketsphinx/model/en-us/en-us/means
                INFO: ms_gauden.c(242): 42 codebook, 3 feature, size:
                INFO: ms_gauden.c(244):  128x13
                INFO: ms_gauden.c(127): Reading mixture gaussian parameter: /usr/local/share/pocketsphinx/model/en-us/en-us/variances
                INFO: ms_gauden.c(304): 222 variance values floored
                INFO: ptm_mgau.c(475): Loading senones from dump file /usr/local/share/pocketsphinx/model/en-us/en-us/sendump
                INFO: ptm_mgau.c(499): BEGIN FILE FORMAT DESCRIPTION
                INFO: ptm_mgau.c(562): Rows: 128, Columns: 5126
                INFO: ptm_mgau.c(594): Using memory-mapped I/O for senones
                INFO: ptm_mgau.c(837): Maximum top-N: 4
                INFO: phone_loop_search.c(114): State beam -225 Phone exit beam -225 Insertion penalty 0
                INFO: dict.c(320): Allocating 4130 * 20 bytes (80 KiB) for word entries
                INFO: dict.c(333): Reading main dictionary: modules/MMM-voice/MMM-voice.dic
                INFO: dict.c(213): Dictionary size 29, allocated 0 KiB for strings, 0 KiB for phones
                INFO: dict.c(336): 29 words read
                INFO: dict.c(358): Reading filler dictionary: /usr/local/share/pocketsphinx/model/en-us/en-us/noisedict
                INFO: dict.c(213): Dictionary size 34, allocated 0 KiB for strings, 0 KiB for phones
                INFO: dict.c(361): 5 words read
                INFO: dict2pid.c(396): Building PID tables for dictionary
                INFO: dict2pid.c(406): Allocating 42^3 * 2 bytes (144 KiB) for word-initial triphones
                INFO: dict2pid.c(132): Allocated 21336 bytes (20 KiB) for word-final triphones
                INFO: dict2pid.c(196): Allocated 21336 bytes (20 KiB) for single-phone word triphones
                INFO: ngram_model_trie.c(354): Trying to read LM in trie binary format
                INFO: ngram_model_trie.c(365): Header doesn't match
                INFO: ngram_model_trie.c(177): Trying to read LM in arpa format
                INFO: ngram_model_trie.c(193): LM of order 3
                INFO: ngram_model_trie.c(195): #1-grams: 25
                INFO: ngram_model_trie.c(195): #2-grams: 46
                INFO: ngram_model_trie.c(195): #3-grams: 23
                INFO: lm_trie.c(474): Training quantizer
                INFO: lm_trie.c(482): Building LM trie
                INFO: ngram_search_fwdtree.c(74): Initializing search tree
                INFO: ngram_search_fwdtree.c(101): 28 unique initial diphones
                INFO: ngram_search_fwdtree.c(186): Creating search channels
                INFO: ngram_search_fwdtree.c(323): Max nonroot chan increased to 157
                INFO: ngram_search_fwdtree.c(333): Created 28 root, 29 non-root channels, 5 single-phone words
                INFO: ngram_search_fwdflat.c(157): fwdflat: min_ef_width = 4, max_sf_win = 25
                INFO: continuous.c(307): pocketsphinx_continuous COMPILED ON: Sep 29 2019, AT: 15:24:41
                Error opening audio device plughw:1 for capture: Invalid argument
                FATAL: "continuous.c", line 245: Failed to open audio device
                -agc			none		none
                -allphone
                -aw			1		1
                -backtrace		no		no
                -bestpath		yes		yes
                -ceplen			13		13
                -cmn			live		batch
                -compallsen		no		no
                -dictcase		no		no
                -dither			no		no
                -doublebw		no		no
                -ds			1		1
                -fdict
                -featparams
                -frate			100		100
                -fsg
                -fwdflat		yes		yes
                -fwdflatefwid		4		4
                -fwdflatsfwin		25		25
                -fwdtree		yes		yes
                -jsgf
                -keyphrase
                -kws
                -kws_delay		10		10
                -latsize		5000		5000
                -lda
                -ldadim			0		0
                -lifter			0		22
                -lmctl
                -lmname
                -logfn
                -logspec		no		no
                -maxwpf			-1		-1
                -mdef
                -mean
                -mfclogdir
                -min_endfr		0		0
                -mixw
                -mllr
                -mmap			yes		yes
                -ncep			13		13
                -nfft			512		512
                -nfilt			40		25
                -pl_window		5		5
                -rawlogdir
                -remove_dc		no		no
                -seed			-1		-1
                -sendump
                -senlogdir
                -senmgau
                -smoothspec		no		no
                -tmat
                -topn			4		4
                -topn_beam		0		0
                -toprule
                -unit_area		yes		yes
                -var
                -varnorm		no		no
                -verbose		no		no
                -warp_params
                Error opening audio device plughw:1,0 for capture: Invalid argument
                    @jmartin1009 ok, in the hopes that the mmm-voice author published the fix I gave him,
                    Change mic: ‘1,0’ to mic: ‘hw:1,0’
                    And try again
                      @sdetweil still an error, here is the new debug.log:
                      -agc			none		none
                      -allphone
                      -aw			1		1
                      -backtrace		no		no
                      -bestpath		yes		yes
                      -ceplen			13		13
                      -cmn			live		batch
                      -compallsen		no		no
                      -dictcase		no		no
                      -dither			no		no
                      -doublebw		no		no
                      -ds			1		1
                      -fdict
                      -featparams
                      -frate			100		100
                      -fsg
                      -fwdflat		yes		yes
                      -fwdflatefwid		4		4
                      -fwdflatsfwin		25		25
                      -fwdtree		yes		yes
                      -jsgf
                      -keyphrase
                      -kws
                      -kws_delay		10		10
                      -latsize		5000		5000
                      -lda
                      -ldadim			0		0
                      -lifter			0		22
                      -lmctl
                      -lmname
                      -logfn
                      -logspec		no		no
                      -maxwpf			-1		-1
                      -mdef
                      -mean
                      -mfclogdir
                      -min_endfr		0		0
                      -mixw
                      -mllr
                      -mmap			yes		yes
                      -ncep			13		13
                      -nfft			512		512
                      -nfilt			40		25
                      -pl_window		5		5
                      -rawlogdir
                      -remove_dc		no		no
                      -seed			-1		-1
                      -sendump
                      -senlogdir
                      -senmgau
                      -smoothspec		no		no
                      -tmat
                      -topn			4		4
                      -topn_beam		0		0
                      -toprule
                      -unit_area		yes		yes
                      -var
                      -varnorm		no		no
                      -verbose		no		no
                      -warp_params
                      -agc			none		none
                      -allphone
                      -aw			1		1
                      -backtrace		no		no
                      -bestpath		yes		yes
                      -ceplen			13		13
                      -cmn			live		batch
                      -compallsen		no		no
                      -dictcase		no		no
                      -dither			no		no
                      -doublebw		no		no
                      -ds			1		1
                      -fdict
                      -featparams
                      -frate			100		100
                      -fsg
                      -fwdflat		yes		yes
                      -fwdflatefwid		4		4
                      -fwdflatsfwin		25		25
                      -fwdtree		yes		yes
                      -jsgf
                      -keyphrase
                      -kws
                      -kws_delay		10		10
                      -latsize		5000		5000
                      -lda
                      -ldadim			0		0
                      -lifter			0		22
                      -lmctl
                      -lmname
                      -logfn
                      -logspec		no		no
                      -maxwpf			-1		-1
                      -mdef
                      -mean
                      -mfclogdir
                      -min_endfr		0		0
                      -mixw
                      -mllr
                      -mmap			yes		yes
                      -ncep			13		13
                      -nfft			512		512
                      -nfilt			40		25
                      -pl_window		5		5
                      -rawlogdir
                      -remove_dc		no		no
                      -seed			-1		-1
                      -sendump
                      -senlogdir
                      -senmgau
                      -smoothspec		no		no
                      -tmat
                      -topn			4		4
                      -topn_beam		0		0
                      -toprule
                      -unit_area		yes		yes
                      -var
                      -varnorm		no		no
                      -verbose		no		no
                      -warp_params
                      -agc			none		none
                      -allphone
                      -aw			1		1
                      -backtrace		no		no
                      -bestpath		yes		yes
                      -ceplen			13		13
                      -cmn			live		batch
                      -compallsen		no		no
                      -dictcase		no		no
                      -dither			no		no
                      -doublebw		no		no
                      -ds			1		1
                      -fdict
                      -featparams
                      -frate			100		100
                      -fsg
                      -fwdflat		yes		yes
                      -fwdflatefwid		4		4
                      -fwdflatsfwin		25		25
                      -fwdtree		yes		yes
                      -jsgf
                      -keyphrase
                      -kws
                      -kws_delay		10		10
                      -latsize		5000		5000
                      -lda
                      -ldadim			0		0
                      -lifter			0		22
                      -lmctl
                      -lmname
                      -logfn
                      -logspec		no		no
                      -maxwpf			-1		-1
                      -mdef
                      -mean
                      -mfclogdir
                      -min_endfr		0		0
                      -mixw
                      -mllr
                      -mmap			yes		yes
                      -ncep			13		13
                      -nfft			512		512
                      -nfilt			40		25
                      -pl_window		5		5
                      -rawlogdir
                      -remove_dc		no		no
                      -seed			-1		-1
                      -sendump
                      -senlogdir
                      -senmgau
                      -smoothspec		no		no
                      -tmat
                      -topn			4		4
                      -topn_beam		0		0
                      -toprule
                      -unit_area		yes		yes
                      -var
                      -varnorm		no		no
                      -verbose		no		no
                      -warp_params
                      -agc			none		none
                      -allphone
                      -aw			1		1
                      -backtrace		no		no
                      -bestpath		yes		yes
                      -ceplen			13		13
                      -cmn			live		batch
                      -compallsen		no		no
                      -dictcase		no		no
                      -dither			no		no
                      -doublebw		no		no
                      -ds			1		1
                      -fdict
                      -featparams
                      -frate			100		100
                      -fsg
                      -fwdflat		yes		yes
                      -fwdflatefwid		4		4
                      -fwdflatsfwin		25		25
                      -fwdtree		yes		yes
                      -jsgf
                      -keyphrase
                      -kws
                      -kws_delay		10		10
                      -latsize		5000		5000
                      -lda
                      -ldadim			0		0
                      -lifter			0		22
                      -lmctl
                      -lmname
                      -logfn
                      -logspec		no		no
                      -maxwpf			-1		-1
                      -mdef
                      -mean
                      -mfclogdir
                      -min_endfr		0		0
                      -mixw
                      -mllr
                      -mmap			yes		yes
                      -ncep			13		13
                      -nfft			512		512
                      -nfilt			40		25
                      -pl_window		5		5
                      -rawlogdir
                      -remove_dc		no		no
                      -seed			-1		-1
                      -sendump
                      -senlogdir
                      -senmgau
                      -smoothspec		no		no
                      -tmat
                      -topn			4		4
                      -topn_beam		0		0
                      -toprule
                      -unit_area		yes		yes
                      -var
                      -varnorm		no		no
                      -verbose		no		no
                      -warp_params
                      Error opening audio device hw:1,0 for capture: Invalid argument
                        @jmartin1009 yeh. Fix not published.
                        Can u try the arecord -D hw:1,0 test.wav
                          @sdetweil i tried that but with duration 10, then did aplay test.wav and it said no file or directory, so it may be my mic or something, but it shows up in arecord -l.
                            @jmartin1009 make sure the filename was right.
                            ls
                              pi@raspberrypi:~ $ arecord -D hw:1,0 --duration=10 test.wav
                              Recording WAVE 'test.wav' : Unsigned 8 bit, Rate 8000 Hz, Mono
                              arecord: set_params:1299: Sample format non available
                              Available formats:
                              - S16_LE
                              pi@raspberrypi:~ $ aplay test.wav
                              test.wav: No such file or directory
                              pi@raspberrypi:~ $
                                @jmartin1009 ok. Can’t help.mic not working.
                                But plughw vs hw
                                Go to MagicMirror/modules/mmm-voice/node_modules/pocketsphinx_continuous
                                Edit index J’s and change ‘plughw’ to ‘hw’
                                Only one place.
                                  @sdetweil done, will try now.
                                    @sdetweil same error, should a corsair headset mic work to check it? I’m currently using a blue yeti but the connection is a bit iffy, but it appears to be working. Just don’t know what the issue is here.
                                      @jmartin1009 but it should say hw:1,0 can’t be opened
                                        @sdetweil what? I’m not sure what you’re referring to
                                          @jmartin1009 the error in the log is can’t open plughw:1,0
                                          But we changed it… To force hw:1,0
                                            sdetweil
                                            What does the debug log say
                                            • 2 / 5
