    MMM-SensorGateway
    15 Posts 6 Posters 5.8k Views 6 Watching
      mattileh @Jo-Rien
      @Jo-Rien I’m not quite sure yet what are the problems, as sdetweil mentioned the module has quite extensive setup part elaborated in the readme.md. and also that one issue I’d like to see answered if the sudo fixed it.
      I could probably try to do a “clean install” during July’s time and update the instructions if found something.
        Jo-Rien
        @mattileh
        I followed your reame.md and everything is going according the readme until i start up the ble service and check the status. It is giving me a error on the local_blegatewaykickstart.sh status is 1/Failure.
        When running ruuvitag -f it will show all ruuvitags just fine, digging in the code a little and the error it seems there is a problem with websocket and codeparser i get this as missing modules, maybe this helps to solve the problem?
          mattileh @Jo-Rien
          @Jo-Rien thanks!, yep its most likely about the missing modules - I did a “clean install” with the latest master (see merged PR#1 for details) and it seemed to install all related dependencies now with the install - script, could you try again now?
          In case its still not working, would you like to debug this together for example in Discord?
            Jo-Rien
            I’m going to try if it works now, will let you know.
              Jo-Rien
              Did a clean install and it works like a charm now, thank you very much for all the effort taken…
