    color MMM-newsfeed
    3 Posts 2 Posters 1.6k Views 1 Watching
    • C Offline
      chassain 0
      hello,
      Sorry for easy question but i don’t arrive to change text in other color with css :
      .MMM-newsfeed {
      color : XXXX
      Only background-color is working. thanks
        broberg Project Sponsor
        It’s because most text has other classes that overrides the “general” option that is color:
        mostly it is .bright and .dimmed that is used.
        so for an example, the title in the default newsfeed is set with the class .bright
        .newsfeed .bright {
        color: green;
        (I don’t know if there is a module named MMM-newsfeed, The default newsfeed is just .newsfeed and not .MMM-newsfeed, but if you are using a module besides the default one disregard this and use the module name as as in your example)
        C 1 Reply Last reply Reply Quote 1
        • C Offline
          chassain 0 @broberg
          @broberg said in color MMM-newsfeed:
          .newsfeed .bright {
          color: green;
          Yes, it’s newsfeed (error of me here)…and it’s working with .bright…i understand now and i will check better next modules…
          thankssssssssssssssssssssssssssss :)
