    Please help me...........
    19 Posts 4 Posters 3.8k Views 4 Watching
      sdetweil @daegon-jjiya
      @daegon-jjiya said in Please help me...........:
      __atomic_store_8
      see this reply for the steps to recover… one of the libraries that module uses has a bug
      https://forum.magicmirror.builders/topic/11430/error-when-trying-to-run-mmm-assistantmk2/5
        daegon-jjiya @sdetweil
        @sdetweil Thank you for answer. We are going to the link you tell us.
          I tried using the link above, but when I ran Red text and Magic Mirror, the following characters were displayed and the Magic Mirror screen did not appear.
          pi@raspberrypi:~ $ cd MagicMirror
          magicmirror@2.9.0 start /home/pi/MagicMirror
          sh run-start.sh
          Starting MagicMirror: v2.9.0
          Loading config …
          Loading module helpers …
          Initializing new module helper …
          Module helper loaded: MMM-Hotword
          WARNING! Could not load config file. Starting with default configuration. Error found: Error: Failed to load gRPC binary module because it was not installed for the current system
          Expected directory: electron-v3.0-linux-arm-glibc
          Found: [node-v64-linux-arm-glibc]
          This problem can often be fixed by running “npm rebuild” on the current system
          Original error: Cannot find module ‘/home/pi/MagicMirror/modules/MMM-AssistantMk2/node_modules/grpc/src/node/extension_binary/electron-v3.0-linux-arm-glibc/grpc_node.node’
          App threw an error during load
          at Object. (/home/pi/MagicMirror/modules/MMM-AssistantMk2/node_modules/grpc/src/grpc_extension.js:53:17)
          at Object. (/home/pi/MagicMirror/modules/MMM-AssistantMk2/node_modules/grpc/src/grpc_extension.js:64:3)
          at Module._compile (internal/modules/cjs/loader.js:711:30)
          at Object.Module._extensions…js (internal/modules/cjs/loader.js:722:10)
          at Module.load (internal/modules/cjs/loader.js:620:32)
          at tryModuleLoad (internal/modules/cjs/loader.js:559:12)
          at Function.Module._load (internal/modules/cjs/loader.js:551:3)
          at Module.require (internal/modules/cjs/loader.js:658:17)
          at require (internal/modules/cjs/helpers.js:20:18)
          at Object. (/home/pi/MagicMirror/modules/MMM-AssistantMk2/node_modules/grpc/src/client_interceptors.js:144:12)
          Whoops! There was an uncaught exception…
          { Error: Failed to load gRPC binary module because it was not installed for the current system
          at Object. (/home/pi/MagicMirror/modules/MMM-AssistantMk2/node_modules/grpc/src/client_interceptors.js:144:12) code: ‘MODULE_NOT_FOUND’ }
          Launching application.
          Shutting down server…
          Stopping module helper: updatenotification
          Stopping module helper: calendar
          Stopping module helper: newsfeed
          Stopping module helper: MMM-Hotword
          I think you need to know the order in order to follow the link mentioned above.
          If you have time, can you easily arrange the order of installing Magic Mirror MMM-HOTWARD and MMM-AssistantMK2?
          For the first time, it’s all new and hard But I want to finish it.
          You can only imitate while watching YouTube videos. But I want to give me and my children a new experience.
          please …
          • raspberry pi 3+
          • Raspbian Buster with desktop and recommended software 2019-09-26
          • Work directly on the board rather than remotely
          • The above specification is the environment I am working on.
          S Mykle1M 2 Replies Last reply Reply Quote 0
            @daegon-jjiya
            did you do this step
            cd ~/MagicMirror
            npm rebuild
              Mykle1 Project Sponsor Module Developer @daegon-jjiya
              @daegon-jjiya
              Please read this. Many thanks.
              https://forum.magicmirror.builders/topic/4247/how-to-post-code-on-the-forum-for-absolute-beginners
                @sdetweil Only black screen appears. T,.T
                  daegon-jjiya @daegon-jjiya
                  @daegon-jjiya
                  thank you
                    Complete with lots of text and the same black screen appears.
                    > sh run-start.sh
                    Loading config ...
                    Loading module helpers ...
                    This problem can often be fixed by running "npm rebuild" on the current system
                    Original error: Cannot find module '/home/pi/MagicMirror/modules/MMM-AssistantMk2/node_modules/grpc/src/node/extension_binary/electron-v3.0-linux-arm-glibc/grpc_node.node'
                        at Object.<anonymous> (/home/pi/MagicMirror/modules/MMM-AssistantMk2/node_modules/grpc/src/grpc_extension.js:53:17)
                        at Object.<anonymous> (/home/pi/MagicMirror/modules/MMM-AssistantMk2/node_modules/grpc/src/grpc_extension.js:64:3)
                        at Object.Module._extensions..js (internal/modules/cjs/loader.js:722:10)
                        at Object.<anonymous> (/home/pi/MagicMirror/modules/MMM-AssistantMk2/node_modules/grpc/src/client_interceptors.js:144:12)
                        at Object.<anonymous> (/home/pi/MagicMirror/modules/MMM-AssistantMk2/node_modules/grpc/src/client_interceptors.js:144:12) code: 'MODULE_NOT_FOUND' }
                    Shutting down server...
                    It repeats even if you start from the beginning.
                    I’ll install it from the beginning though. Please let me know some notes during installation
                    Sorry and thank you
                      @daegon-jjiya sorry,I think we will have to wait for @Sean to help. He is the module author.
