    Compliments - Multi Line not working?
    13 Posts 4 Posters 5.3k Views 3 Watching
      sdetweil @broberg
      @broberg said in Compliments - Multi Line not working?:
      The \n gets converted to a whitespace in the textNode
      I see a \n presented on the screen. whenever there is a \n in the compliment string.
      as in “Hey there\n sexy!”
      using the backtics, are supposed to allow line continuation across muiltiple lines AND encode a hex 10 (nl) char. but what a pain.
      var msg=Hey there sexy
      (note that this doesn’t show here on the forum either.)
      it MAY be that the actual newline has to be encoded , NOT the text representation of the newline
       ('\n')
      the default compliment text strings contains whitespace, where are NOT converted to breaks. so I don’t understand
      I don’t see any improvement in using the file approach, as its content rules are javascript source rules. not message by line or anything else.
      to test, I did nothing except install MM and edit the built in messages to add \n (two characters) in various places
      i see the pre-line class, and read the description, but still haven’t figured out which nl they are discussing.
      kayakbabeK 1 Reply Last reply Reply Quote 0
      • kayakbabeK Offline
        kayakbabe @sdetweil
        @sdetweil I figured out that your suggestions of encoding the new line worked for me.
        So, instead of using
        \n
        which textNode was treating literally, I tried encoding it and using this
        \u000A
        so when I tried the following it looked just like I put it into my morecompliments.json
        "roses are red\nviolets are blue\nand I need a line\nto start here anew "
        then I tried
        "roses are red\u000Aviolets are blue\u000Aand I need a line\u000Ato start here anew "
        and it displayed like I wanted it to like so…
        roses are red
        violets are blue
        and I need a line
        to start here anew
        perhaps this will help others.
          sdetweil @kayakbabe
          @kayakbabe crazy. my code splits the line with
          "\n"
          the problem was this forum changing the quote from
          '\n'
          to
          ‘\n’
          notice the curly quotes, those are bad
