    Compliments - Multi Line not working?
    13 Posts 4 Posters 5.7k Views 3 Watching
    • N Offline
      noisedoctor
      I do have that in the CSS. I haven’t made any CSS customizations. I installed everything two days ago, so I expect I have the latest code installed.
        broberg Project Sponsor @noisedoctor
        @noisedoctor Okey, so thats not the issue.
        Is the json-file saved in utf8 (and not in ascii)?
        Are you running on the mirrors electron browser or are you viewing it on a different browser?
        • N Offline
          noisedoctor @broberg
          @broberg – sorry for the lag… I did save a file as utf8 (it was ANSI before). I am simply viewing the MM on the display connected to my Raspberry Pi. Any other guess what I could be doing wrong?
            new line has no meaning in a textElement
            replace the getDom function in compliments.js with this
            	// Override dom generator.
            	getDom: function() {
            		wrapper.className = this.config.classes ? this.config.classes : "thin xlarge bright pre-line";
            		// get the compliment text
            		var complimentText = this.randomCompliment();
            		// split it into parts on newline text
            		var parts= complimentText.split('\n')
            		// create a span to hold it all
            		var compliment=document.createElement('span')
                            // process all the parts of the compliment text
            		for (part of parts){
            			// create a text element for each part
            			compliment.appendChild(document.createTextNode(part))
            			// add a break `
            			compliment.appendChild(document.createElement('BR'))
            		// remove the last break
            		compliment.lastElementChild.remove();
            		wrapper.appendChild(compliment);
            		return wrapper;
            then u can use ‘\n’ in the text to split a line like this
            		compliments: {
            			anytime: [
            				"Hey there\n sexy!"
            			morning: [
            				"Good morning, handsome!",
            				"Enjoy your day!",
            				"How was your sleep?"
            			afternoon: [
            				"Hello, \nbeauty!",
            				"You look sexy!",
            				"Looking good today!"
            			evening: [
            				"Wow, you \nlook hot!",
            				"You look nice!",
            				"Hi,\nsexy!"
            • N Offline
              noisedoctor
              so, is the documentation wrong?
              https://github.com/MichMich/MagicMirror/tree/master/modules/default/compliments
              Multi-line compliments:
              Use \n to split compliment text into multiple lines, e.g. First line.\nSecond line. will be shown as:
              First line.
              Second line.
              I’m happy making a code change, but the docs state that this should already be working. is it a factor of being an external file?
                sdetweil @noisedoctor
                @noisedoctor I do not know. I don’t see how it ever worked. The field used does not interpolate the text. Just presents it as is.
                I opened an issue, and logged the correction as a regression somewhere along the way
                N B 2 Replies Last reply Reply Quote 0
                • N Offline
                  noisedoctor @sdetweil
                  @sdetweil – thanks so much. I wanted to confirm before reporting as a defect, but I guess you did that for me :)
                    broberg Project Sponsor @sdetweil
                    @sdetweil said in Compliments - Multi Line not working?:
                    The \n gets converted to a whitespace in the textNode. And then the css pre -code converts every whitespace to a row break. It works on my setup, and probably more. Why it doesn’t on OPs setup is however beyond me.
                      sdetweil @broberg
                      @broberg said in Compliments - Multi Line not working?:
                      I see a \n presented on the screen. whenever there is a \n in the compliment string.
                      as in “Hey there\n sexy!”
                      using the backtics, are supposed to allow line continuation across muiltiple lines AND encode a hex 10 (nl) char. but what a pain.
                      var msg=Hey there sexy
                      (note that this doesn’t show here on the forum either.)
                      it MAY be that the actual newline has to be encoded , NOT the text representation of the newline
                       ('\n')
                      the default compliment text strings contains whitespace, where are NOT converted to breaks. so I don’t understand
                      I don’t see any improvement in using the file approach, as its content rules are javascript source rules. not message by line or anything else.
                      to test, I did nothing except install MM and edit the built in messages to add \n (two characters) in various places
                      i see the pre-line class, and read the description, but still haven’t figured out which nl they are discussing.
                      kayakbabeK 1 Reply Last reply Reply Quote 0
                      • kayakbabeK Offline
                        kayakbabe @sdetweil
                        @sdetweil I figured out that your suggestions of encoding the new line worked for me.
                        So, instead of using
                        \n
                        which textNode was treating literally, I tried encoding it and using this
                        \u000A
                        so when I tried the following it looked just like I put it into my morecompliments.json
                        "roses are red\nviolets are blue\nand I need a line\nto start here anew "
                        then I tried
                        "roses are red\u000Aviolets are blue\u000Aand I need a line\u000Ato start here anew "
                        and it displayed like I wanted it to like so…
                        roses are red
                        violets are blue
                        and I need a line
                        to start here anew
                        perhaps this will help others.
                          sdetweil @kayakbabe
                          @kayakbabe crazy. my code splits the line with
                          "\n"
                          the problem was this forum changing the quote from
                          '\n'
                          to
                          ‘\n’
                          notice the curly quotes, those are bad
