    MMM.RTSPStream
    15 Posts 2 Posters 6.7k Views 3 Watching
    • T Offline
      tanvir586
      Hi everyone, can anyone help me with rtspstream. My rtsp url work fine on my computer but i get following error on my pi
      Your input can’t be opened:
      VLC is unable to open the MRL ‘rtsp://admin:xxxxxxxx@192.168.1.7:554/cam/realmonitor?Channel=1&subtype=1’. Check the log for details.
      A little help will be appreciated. Thanks
      • BKeyportB Offline
        BKeyport Module Developer
        Have you tried the other players? OMXPlayer or FFMPeg?
        if you’re using PM2 to launch the mirror - you can run a second terminal window and use the command “PM2 Logs” in that window to catch the logs realtime as well to see any errors you get.
        • T Offline
          tanvir586
          Hi thanks for reply.
          Both vlc and omxplayer not working. Maybe i made mistake on installing the module. I just install
          bash -c “$(curl -s https://raw.githubusercontent.com/shbatm/MMM-RTSPStream/develop/scripts/installer.sh)”
          Using my terminal.
          Do i need to install any dependency?
          And i don’t use pm2.
          • BKeyportB Offline
            If you followed the instructions exactly, it should be working… It does look like you did as far as the bash command goes. Did you use the configuration builder tool or build the config manually?
            • T Offline
              tanvir586
              Ive used config tool
              • T Offline
                tanvir586
                I tried everything. Its not working
                • BKeyportB Offline
                  I think at this point, we need to perform some voodoo and call up the author… @shbatm
                  Wanna help us out?
                  • BKeyportB Offline
                    FWIW, VLC don’t work for me. I have to use OMX Player or FFMPeg… running on a Pi 4
                    • BKeyportB Offline
                      I did some checking, and testing and found out a couple of things:
                      1. I was on the develop branch, not the master branch.
                      2. I’m now on the master branch, which neither VLC or OMXPlayer works, but FFMPeg does.
                      So, maybe the solution is to switch to FFMpeg for you, too.
                      • T Offline
                        tanvir586
                        Thanks, i think that’s the solution. Im on master branch. Will check and let you know. Many thanks for help.
                        • T Offline
                          tanvir586
                          Hi sorry for late reply. I was away for couple of days.
                          Ok i tried both brunch but no luck. Tried ffmpeg as well. But not working.
                          • T Offline
                            tanvir586
                            How to check rtsp with ffmpeg without going to the magicmirror? Because i can see vlc on my manu but i couldn’t find ffmpeg.
                            • BKeyportB Offline
                              Just a FYI, I still can’t get VLC to work, but I did get OMXPlayer to work. turns out my URL was wrong (wrong address, “frontcam” not “FrontCam” - check your strings.
                              • T Offline
                                tanvir586
                                I couldn’t get any of the player working. Thinking to remove the module and reinstall. It might help
                                • BKeyportB Offline
                                  So, in playing with the module in the absence of the author, I’ve found the following:
                                  VLC won’t work.
                                  1. Author has syntax error on command line, so it’s trying to load local file “dummy” rather than stream. I can fix this by removing the word “dummy” in node_helper.js, along with it’s quotes and comma.
                                  2. There’s a problem with the way that VLC is called by node (the system behind magic mirror) that is blocking the video stream from flowing. If I remove the “-I” from the arguments, I can get a VLC box that runs, and when I check the stream stats, the audio is flowing freely, but the video is stuck. if I understood how it’s carving out the space for VLC, I’d try to launch it and the support pieces another way.
                                  I’m going to submit this to the author in github. hopefully he comes back sometime soon and fixes.
