    MMM.RTSPStream
    15 Posts 2 Posters 5.2k Views 3 Watching
    • BKeyportB Offline
      BKeyport Module Developer
      Have you tried the other players? OMXPlayer or FFMPeg?
      if you’re using PM2 to launch the mirror - you can run a second terminal window and use the command “PM2 Logs” in that window to catch the logs realtime as well to see any errors you get.
      • T Offline
        tanvir586
        Hi thanks for reply.
        Both vlc and omxplayer not working. Maybe i made mistake on installing the module. I just install
        bash -c “$(curl -s https://raw.githubusercontent.com/shbatm/MMM-RTSPStream/develop/scripts/installer.sh)”
        Using my terminal.
        Do i need to install any dependency?
        And i don’t use pm2.
        • BKeyportB Offline
          If you followed the instructions exactly, it should be working… It does look like you did as far as the bash command goes. Did you use the configuration builder tool or build the config manually?
          • T Offline
            tanvir586
            Ive used config tool
            • T Offline
              tanvir586
              I tried everything. Its not working
              • BKeyportB Offline
                I think at this point, we need to perform some voodoo and call up the author… @shbatm
                Wanna help us out?
                • BKeyportB Offline
                  FWIW, VLC don’t work for me. I have to use OMX Player or FFMPeg… running on a Pi 4
                  • BKeyportB Offline
                    I did some checking, and testing and found out a couple of things:
                    1. I was on the develop branch, not the master branch.
                    2. I’m now on the master branch, which neither VLC or OMXPlayer works, but FFMPeg does.
                    So, maybe the solution is to switch to FFMpeg for you, too.
                    • T Offline
                      tanvir586
                      Thanks, i think that’s the solution. Im on master branch. Will check and let you know. Many thanks for help.
                      • T Offline
                        tanvir586
                        Hi sorry for late reply. I was away for couple of days.
                        Ok i tried both brunch but no luck. Tried ffmpeg as well. But not working.
