    Client only - Do I need the MM software again?
    2 Posts 2 Posters 635 Views 2 Watching
      Seppelicous
      I am running MM on my NAS with docker in server-only mode.
      I like to use my Raps Zero W as a client only, but I have a problem following the instructions on Github.
      Error: Failed to find Electron v3.0.13 for linux-armv6l at https://github.com/electron/electron/releases/download/v3.0.13/electron-v3.0.13-linux-armv6l.zip
          at Request.<anonymous> (/home/pi/MagicMirror/node_modules/nugget/index.js:169:61)
      Why do I need the MM software on my Zero? Is the chromium browser not enough to just display the MM page from my Nas?
      best regards
        sdetweil @Seppelicous
        @Seppelicous yes, chromium is enough…
        in the past , chromium wasn’t on the pi…
        my installer actually uses chromium for the pi0 now as electron won’t run on the armv6l at the higher node levels.
