    Chalkboard message
    9 Posts 3 Posters 2.5k Views 4 Watching
    • C Offline
      Clubjack
      Hey together.
      Would it be possible to get or create a module that displays a variable text over a large area? This text should look like it was written on a blackboard with chalk.
        sdetweil @Clubjack
        @Clubjack sure… pick a font
        https://medialoot.com/blog/25-awesome-chalkboard-fonts-effects-and-mockups/
        I am sure there are more
        C 1 Reply Last reply Reply Quote 1
        • C Offline
          Clubjack @sdetweil
          Yes… I found fonts too. But with witch Module i can create this messages and Display it large fullsize?
            BD0G
            How about this fork of the original compliments module?
            https://github.com/yawnsde/MMM-Compliments
            It allows one to create a remote file that contains the things that one would like to have displayed on the screen and has a feature to not use randomization. There are customization’s for morning sayings, day sayings , and evening sayings.
            Then in the custom.css file find a way to add an entry to specify the chalkboard fonts and thier size/position.
            Others more skilled in css customization’s on the forum should be able to help.
              sdetweil @BD0G
              @BD0G said in Chalkboard message:
              I just submitted a PR to enable that for the base compliments module
              also the compliments module will take a file, which could be linked remotely to a server file
              with no code change
                BD0G
                It would be neat to have the ability to change fonts and sizes and positioning natively to accomplish what the OP is intending.
                To make it look as though someone has actually written the message in chalk would require independent control of the position of each letter as we all know that nobody writes text by hand that is perfectly straight across. There are always slightly higher letters and slightly lower letters.
                This idea would be nifty for a new module development. MMM-Chalkboard. :)
                  sdetweil @BD0G
                  @BD0G right… i learned a little something the other day helping someone…
                  u can split a text string into individual span elements < span>letter
                  and they will all show side by side…
                  THEN u can apply styles to EACH LETTER (alternating, some other algorithm… )
                  • C Offline
                    Clubjack
                    Thank You. For the first, i try it with compliments. But a nee Module would be nice 😁👍🏽
                      BD0G
                      Update us with how you do and your progress. :thumbsup
