    Chalkboard message
    9 Posts 3 Posters 2.4k Views 4 Watching
      BD0G
      How about this fork of the original compliments module?
      https://github.com/yawnsde/MMM-Compliments
      It allows one to create a remote file that contains the things that one would like to have displayed on the screen and has a feature to not use randomization. There are customization’s for morning sayings, day sayings , and evening sayings.
      Then in the custom.css file find a way to add an entry to specify the chalkboard fonts and thier size/position.
      Others more skilled in css customization’s on the forum should be able to help.
        sdetweil @BD0G
        @BD0G said in Chalkboard message:
        I just submitted a PR to enable that for the base compliments module
        also the compliments module will take a file, which could be linked remotely to a server file
        with no code change
          BD0G
          It would be neat to have the ability to change fonts and sizes and positioning natively to accomplish what the OP is intending.
          To make it look as though someone has actually written the message in chalk would require independent control of the position of each letter as we all know that nobody writes text by hand that is perfectly straight across. There are always slightly higher letters and slightly lower letters.
          This idea would be nifty for a new module development. MMM-Chalkboard. :)
            sdetweil @BD0G
            @BD0G right… i learned a little something the other day helping someone…
            u can split a text string into individual span elements < span>letter
            and they will all show side by side…
            THEN u can apply styles to EACH LETTER (alternating, some other algorithm… )
              Clubjack
              Thank You. For the first, i try it with compliments. But a nee Module would be nice 😁👍🏽
                BD0G
                Update us with how you do and your progress. :thumbsup
