    Error performing TLS handshake: An unexpected TLS packet was received
    22 Posts 2 Posters 7.7k Views 2 Watching
    • K Offline
      Keudn
      Hi all,
      I am trying to set Magic Mirror 2 up on my Pi Zero W following Emmanuel Contreras’s guide found here http://emmanuelcontreras.com/how-to/how-to-create-a-magic-mirror-2-with-pi-zero-w/. I followed the instructions up until making the two start scripts, where I deviated slightly and used midori instead of chromium as in this guide https://www.magicmirrorcentral.com/magic-mirror-raspberry-pi-zero/. When I restart my Pi, Midori opens but gives me a “Error- https://localhost:8080 Error performing TLS handshake: An unexpected TLS packet was received” message. Does anyone have a solution to this? I don’t seem to be getting any errors in the console, and accessing the Mirror from my PC’s web browser opens it correctly, so it is an issue with Midori.
      • K Offline
        Keudn @sdetweil
        @sdetweil Ahh, that did it. Reverted the run-start.sh script and switched to Graphical auto-login mode and that did the trick. Thank you for your help!
          sdetweil @Keudn
          @Keudn I don’t know. But I would try the updated installer.
          See here
          https://forum.magicmirror.builders/topic/10171/anyone-want-to-try-updated-installer
          • K Offline
            Keudn @sdetweil
            @sdetweil I’m not sure how to use it, do I just run the command?
              sdetweil @Keudn
              @Keudn rename the MagicMirror folder to something else and then run the command.
              it will do all the work…
              (this is just an updated version of the same command in the MM readme and on the github site)
              it will prompt if u want to use pm2 to autostart at boot
              and ask if u want to turn off screen saver
              • K Offline
                Keudn @sdetweil
                @sdetweil I renamed the old Magic Mirror folder and ran the command. It seemed to install correctly, but when it boots I get a “Please create a config file” message even though I copied the one I had from the old folder over and installed the modules again. I am also still getting the Midori error first, so it seems like the previous install is still trying to start.
                  sdetweil @Keudn
                  @Keudn do a
                  pm2 status
                  Command. Check the paths and commands
                  My setup starts chrome for the browser on pi 0.
                  For the config, run
                  npm check:config
                  From the MagicMirror folder.
                  If that is ok
                  Then do npm start to see any node_helper errors
                  • K Offline
                    Keudn @sdetweil
                    @sdetweil pm2 status gives me two ids, MagicMirror and mmstart. I’m assuming MagicMirror is the one your script creates. When I try and run pm2 stop I just get “Process not found” error and can’t actually disable it.
                    Running npm check:config doesn’t seem to be a valid command as it gives me a usage list and asks if I meant “config”.
                    Doing npm start gives this output
                    $ npm start
                    > magicmirror@2.10.0-develop start /home/pi/MagicMirror
                    > ./run-start.sh
                    0 [LOG] Starting MagicMirror: v2.10.0-develop
                    0 [LOG] Loading config ...
                    [21:27:45.455] [ERROR]  WARNING! Could not validate config file. Starting with default configuration. Please correct syntax errors at or above this line: /home/pi/MagicMirror/config/config.js:87
                    SyntaxError: Unexpected token *
                        at Module._compile (internal/modules/cjs/loader.js:721:23)
                        at Object.Module._extensions..js (internal/modules/cjs/loader.js:787:10)
                        at Module.load (internal/modules/cjs/loader.js:653:32)
                        at tryModuleLoad (internal/modules/cjs/loader.js:593:12)
                        at Function.Module._load (internal/modules/cjs/loader.js:585:3)
                        at Module.require (internal/modules/cjs/loader.js:690:17)
                        at require (internal/modules/cjs/helpers.js:25:18)
                        at loadConfig (/home/pi/MagicMirror/js/app.js:67:12)
                        at App.start (/home/pi/MagicMirror/js/app.js:208:3)
                        at Object.<anonymous> (/home/pi/MagicMirror/serveronly/index.js:2:5)
                    [21:27:45.484] [LOG] Loading module helpers ...
                    [21:27:45.825] [LOG] Initializing new module helper ...
                    [21:27:45.836] [LOG] Module helper loaded: updatenotification
                    [21:27:45.853] [LOG] No helper found for module: helloworld.
                    0 [LOG] All module helpers loaded.
                    [21:27:45.871] [LOG] Starting server on port 8080 ...
                    0 [LOG] Server started ...
                    0 [LOG] Connecting socket for: updatenotification
                    0 [LOG] Sockets connected & modules started ...
                    0 [LOG]
                    Ready to go! Please point your browser to: http://localhost:8080
                    Starting chromium browser now, have patience, it takes a minute
                    [21:27:46.284] [ERROR]  { Error: listen EADDRINUSE: address already in use 127.0.0.1:8080
                        at Server.setupListenHandle [as _listen2] (net.js:1279:14)
                        at listenInCluster (net.js:1327:12)
                        at GetAddrInfoReqWrap.doListen [as callback] (net.js:1460:7)
                        at GetAddrInfoReqWrap.onlookup [as oncomplete] (dns.js:61:10)
                      code: 'EADDRINUSE',
                      errno: 'EADDRINUSE',
                      syscall: 'listen',
                      address: '127.0.0.1',
                      port: 8080 }
                    Created new window in existing browser session.
                      sdetweil @Keudn
                      @Keudn pm2 stop 0 or 1 ( or use there name)
                      pm2 delete 0 or 1
                      Edit the config and fix line 86 with that *
                      • K Offline
                        Keudn @sdetweil
                        @sdetweil Got the mmstart process deleted, but now the mirror hangs at the booting up screen with the command line on the top. I can access it correctly from a browser on another computer, so it looks like it just isn’t opening a web browser locally on the Pi.
                          sdetweil @Keudn
                          @Keudn the new run-start.sh script is waiting for the server process to say its ready
                          then it starts the browser
                          u should be able to test it
                          ~/MagicMirror
                          bash -x run-start.sh
                          starts mm in serveronly mode (on pi 0)
                          loops reading console output, waiting for the message
                          “point\ your\ browser”
                          then launches chromium-browser
                          but if that message doesn’t come… it will be hung…
                          so, try
                          ~/MagicMirror
                          node serveronly
                          should look like this (with your module list)
                          ~/MagicMirror$ node serveronly
                          [23:31:31.854] [LOG]    Starting MagicMirror: v2.10.0-develop
                          [23:31:31.865] [LOG]    Loading config ...
                          [23:31:31.871] [LOG]    Loading module helpers ...
                          [23:31:31.874] [LOG]    No helper found for module: alert.
                          [23:31:31.925] [LOG]    Initializing new module helper ...
                          [23:31:31.925] [LOG]    Module helper loaded: updatenotification
                          [23:31:31.927] [LOG]    No helper found for module: clock.
                          [23:31:31.928] [LOG]    No helper found for module: currentweather.
                          [23:31:31.929] [LOG]    No helper found for module: weatherforecast.
                          [23:31:32.508] [LOG]    Initializing new module helper ...
                          [23:31:32.509] [LOG]    Module helper loaded: newsfeed
                          [23:31:32.759] [LOG]    Initializing new module helper ...
                          [23:31:32.760] [LOG]    Module helper loaded: MMM-CalendarExt2
                          [23:31:32.771] [LOG]    handler helper in init
                          [23:31:32.772] [LOG]    Module helper loaded: ImageService
                          [23:31:34.273] [LOG]    scheduler helper in init
                          [23:31:34.273] [LOG]    Module helper loaded: ImageScheduler
                          [23:31:34.274] [LOG]    All module helpers loaded.
                          [23:31:34.275] [LOG]    Starting server on port 8080 ...
                          [23:31:34.281] [INFO]   You're using a full whitelist configuration to allow for all IPs
                          [23:31:34.288] [LOG]    Server started ...
                          [23:31:34.289] [LOG]    Connecting socket for: updatenotification
                          [23:31:34.290] [LOG]    Connecting socket for: newsfeed
                          [23:31:34.290] [LOG]    Starting module: newsfeed
                          [23:31:34.291] [LOG]    Connecting socket for: MMM-CalendarExt2
                          [23:31:34.291] [LOG]    Connecting socket for: ImageService
                          [23:31:34.292] [LOG]    handler helper in start
                          [23:31:34.292] [LOG]    Connecting socket for: ImageScheduler
                          [23:31:34.293] [LOG]    scheduler helper in start
                          [23:31:34.293] [LOG]    Sockets connected & modules started ...
                          • K Offline
                            Keudn @sdetweil
                            @sdetweil Both commands get it to “Ready to go! Please point your browser…”, but it is immediately followed by
                            ~/MagicMirror $ node serveronly
                            [23:41:39.439] [LOG]    Starting MagicMirror: v2.10.0-develop
                            [23:41:39.530] [LOG]    Loading config ...
                            [23:41:39.604] [LOG]    Loading module helpers ...
                            [23:41:39.617] [LOG]    No helper found for module: alert.
                            [23:41:39.624] [LOG]    No helper found for module: clock.
                            [23:41:42.789] [LOG]    Initializing new module helper ...
                            [23:41:42.795] [LOG]    Module helper loaded: calendar
                            [23:41:45.193] [LOG]    Initializing new module helper ...
                            [23:41:45.198] [LOG]    Module helper loaded: MMM-Weather-Now
                            [23:41:45.224] [LOG]    Initializing new module helper ...
                            [23:41:45.236] [LOG]    Module helper loaded: MMM-3Day-Forecast
                            [23:41:45.247] [LOG]    Initializing new module helper ...
                            [23:41:45.254] [LOG]    Module helper loaded: MMM-MoonPhase
                            [23:41:45.269] [LOG]    Initializing new module helper ...
                            [23:41:45.274] [LOG]    Module helper loaded: MMM-MyScoreboard
                            [23:41:45.279] [LOG]    All module helpers loaded.
                            [23:41:45.289] [LOG]    Starting server on port 8080 ...
                            [23:41:45.338] [INFO]   You're using a full whitelist configuration to allow for all IPs
                            [23:41:45.394] [LOG]    Server started ...
                            [23:41:45.401] [LOG]    Connecting socket for: calendar
                            [23:41:45.407] [LOG]    Starting node helper for: calendar
                            [23:41:45.412] [LOG]    Connecting socket for: MMM-Weather-Now
                            [23:41:45.418] [LOG]    MMM-Weather-Now helper, started...
                            [23:41:45.424] [LOG]    Connecting socket for: MMM-3Day-Forecast
                            [23:41:45.429] [LOG]    MMM-3Day-Forecast helper, started...
                            [23:41:45.434] [LOG]    Connecting socket for: MMM-MoonPhase
                            [23:41:45.438] [LOG]    Starting module helper: MMM-MoonPhase
                            [23:41:45.443] [LOG]    Connecting socket for: MMM-MyScoreboard
                            [23:41:45.448] [LOG]    Starting node_helper for module [MMM-MyScoreboard]
                            [23:41:50.375] [LOG]    Sockets connected & modules started ...
                            [23:41:50.381] [LOG]
                            Ready to go! Please point your browser to: http://0.0.0.0:8080
                            [23:41:50.456] [LOG]    Whoops! There was an uncaught exception...
                            [23:41:50.462] [ERROR]  { Error: listen EADDRINUSE: address already in use 0.0.0.0:8080
                                at doListen (net.js:1460:7)
                                at process._tickCallback (internal/process/next_tick.js:63:19)
                                at Function.Module.runMain (internal/modules/cjs/loader.js:832:11)
                                at startup (internal/bootstrap/node.js:283:19)
                                at bootstrapNodeJSCore (internal/bootstrap/node.js:622:3)
                              code: 'EADDRINUSE',
                              syscall: 'listen',
                              address: '0.0.0.0',
                              port: 8080 }
                            [23:41:50.528] [LOG]    MagicMirror will not quit, but it might be a good idea to check why this happened. Maybe no internet connection?
                            [23:41:50.533] [LOG]    If you think this really is an issue, please open an issue on GitHub: https://github.com/MichMich/MagicMirror/issues
                            I’m not sure why there would be the address already in use unless it already started correctly. In that case why would the browser not open?
                              sdetweil @Keudn
                              @Keudn because the pm2 instance is running…
                              • K Offline
                                Keudn @sdetweil
                                @sdetweil Yeah, I just don’t understand why running “bash -x run-start.sh” would give the exact same output as “node serveronly” and not open the browser once it sees it is ready. The run-start.sh script doesn’t get to the #start chromium section.
                                When I run “bash -x run-start.sh” this is the output I get
                                $ bash -x run-start.sh
                                + ./untrack-css.sh
                                + '[' -z '' ']'
                                + export DISPLAY=:0
                                + DISPLAY=:0
                                ++ uname -m
                                + arch=armv6l
                                ++ awk '{print tolower($2)}'
                                ++ tr -d ',"'\'''
                                ++ grep -i serveronly: config/config.js
                                + serveronly=
                                + serveronly=false
                                ++ pgrep Xorg
                                + xorg=
                                ++ uname
                                + mac=Linux
                                + '[' false. '!=' false. -o armv6l == armv6l ']'
                                + '[' false. == true. -o . == . ']'
                                + node serveronly
                                [23:50:08.974] [LOG]    Starting MagicMirror: v2.10.0-develop
                                [23:50:09.097] [LOG]    Loading config ...
                                [23:50:09.217] [LOG]    Loading module helpers ...
                                [23:50:09.236] [LOG]    No helper found for module: alert.
                                [23:50:09.245] [LOG]    No helper found for module: clock.
                                [23:50:13.447] [LOG]    Initializing new module helper ...
                                [23:50:13.458] [LOG]    Module helper loaded: calendar
                                [23:50:16.551] [LOG]    Initializing new module helper ...
                                [23:50:16.568] [LOG]    Module helper loaded: MMM-Weather-Now
                                [23:50:16.610] [LOG]    Initializing new module helper ...
                                [23:50:16.649] [LOG]    Module helper loaded: MMM-3Day-Forecast
                                [23:50:16.685] [LOG]    Initializing new module helper ...
                                [23:50:16.694] [LOG]    Module helper loaded: MMM-MoonPhase
                                [23:50:16.725] [LOG]    Initializing new module helper ...
                                [23:50:16.734] [LOG]    Module helper loaded: MMM-MyScoreboard
                                [23:50:16.740] [LOG]    All module helpers loaded.
                                [23:50:16.754] [LOG]    Starting server on port 8080 ...
                                [23:50:16.822] [INFO]   You're using a full whitelist configuration to allow for all IPs
                                [23:50:16.899] [LOG]    Server started ...
                                [23:50:16.910] [LOG]    Connecting socket for: calendar
                                [23:50:16.918] [LOG]    Starting node helper for: calendar
                                [23:50:16.924] [LOG]    Connecting socket for: MMM-Weather-Now
                                [23:50:16.932] [LOG]    MMM-Weather-Now helper, started...
                                [23:50:16.937] [LOG]    Connecting socket for: MMM-3Day-Forecast
                                [23:50:16.944] [LOG]    MMM-3Day-Forecast helper, started...
                                [23:50:16.951] [LOG]    Connecting socket for: MMM-MoonPhase
                                [23:50:16.956] [LOG]    Starting module helper: MMM-MoonPhase
                                [23:50:16.965] [LOG]    Connecting socket for: MMM-MyScoreboard
                                [23:50:16.970] [LOG]    Starting node_helper for module [MMM-MyScoreboard]
                                [23:50:23.495] [LOG]    Sockets connected & modules started ...
                                [23:50:23.506] [LOG]
                                [23:50:23.607] [LOG]    Whoops! There was an uncaught exception...
                                [23:50:23.615] [ERROR]  { Error: listen EADDRINUSE: address already in use 0.0.0.0:8080
                                  code: 'EADDRINUSE',
                                  syscall: 'listen',
                                  address: '0.0.0.0',
                                  port: 8080 }
                                [23:50:23.702] [LOG]    MagicMirror will not quit, but it might be a good idea to check why this happened. Maybe no internet connection?
                                [23:50:23.706] [LOG]    If you think this really is an issue, please open an issue on GitHub: https://github.com/MichMich/MagicMirror/issues
                                  sdetweil @Keudn
                                  @Keudn right, but the run failed, cause of the address in use problem… need to stop the other instance to test…
                                  pm2 stop MagicMirror
                                    @Keudn do this
                                    should return a null line
                                      sdetweil
                                      its stuck cause the script didn’t find xorg running
                                      pgrep Xorg returned ‘’
                                      edit the run-start.sh script and change line
                                      if [ "$serveronly." == "true." -o "$xorg." == "." ]; then
                                      to
                                      if [ "$serveronly." == "true." -a "$xorg." == "." ]; then
                                        @sdetweil are u running in text mode on the pi 0? no… cause u expect browser to open
                                        can u post output of
                                        ps -ef
                                        thx
                                        • K Offline
                                          Keudn @sdetweil
                                          @sdetweil Stopping the magic mirror process before running bash -x run-start.sh just hangs on the line “Ready to go…” and never goes further.
                                          grep -i serveronly: config/config.js does in fact return nothing.
                                          I edited the line, stopped the MagicMirror process, and re-ran run-start.sh. It now gives this output
                                          + ./untrack-css.sh
                                          + '[' -z '' ']'
                                          + export DISPLAY=:0
                                          + DISPLAY=:0
                                          ++ uname -m
                                          + arch=armv6l
                                          ++ tr -d ',"'\'''
                                          + serveronly=
                                          + serveronly=false
                                          ++ pgrep Xorg
                                          + xorg=
                                          ++ uname
                                          + mac=Linux
                                          + '[' false. == true. -a . == . ']'
                                          + exec
                                          + read line
                                          ++ node serveronly
                                          + case "$line" in
                                          + echo 0 '[LOG]' Starting MagicMirror: v2.10.0-develop
                                          + read line
                                          + case "$line" in
                                          + echo 0 '[LOG]' Loading config ...
                                          + read line
                                          + case "$line" in
                                          + echo 0 '[LOG]' Loading module helpers ...
                                          0 [LOG] Loading module helpers ...
                                          + read line
                                          + case "$line" in
                                          + echo 0 '[LOG]' No helper found for module: alert.
                                          0 [LOG] No helper found for module: alert.
                                          + read line
                                          + case "$line" in
                                          + echo 0 '[LOG]' No helper found for module: clock.
                                          0 [LOG] No helper found for module: clock.
                                          + read line
                                          + case "$line" in
                                          + echo 0 '[LOG]' Initializing new module helper ...
                                          0 [LOG] Initializing new module helper ...
                                          + read line
                                          + case "$line" in
                                          + echo 0 '[LOG]' Module helper loaded: calendar
                                          0 [LOG] Module helper loaded: calendar
                                          + read line
                                          + case "$line" in
                                          + read line
                                          + case "$line" in
                                          + echo 0 '[LOG]' Module helper loaded: MMM-Weather-Now
                                          0 [LOG] Module helper loaded: MMM-Weather-Now
                                          + read line
                                          + case "$line" in
                                          + read line
                                          + case "$line" in
                                          + echo 0 '[LOG]' Module helper loaded: MMM-3Day-Forecast
                                          0 [LOG] Module helper loaded: MMM-3Day-Forecast
                                          + read line
                                          + case "$line" in
                                          + read line
                                          + case "$line" in
                                          + echo 0 '[LOG]' Module helper loaded: MMM-MoonPhase
                                          0 [LOG] Module helper loaded: MMM-MoonPhase
                                          + read line
                                          + case "$line" in
                                          + read line
                                          + case "$line" in
                                          + echo 0 '[LOG]' Module helper loaded: MMM-MyScoreboard
                                          0 [LOG] Module helper loaded: MMM-MyScoreboard
                                          + read line
                                          + case "$line" in
                                          + echo 0 '[LOG]' All module helpers loaded.
                                          + read line
                                          + case "$line" in
                                          + echo 0 '[LOG]' Starting server on port 8080 ...
                                          0 [LOG] Starting server on port 8080 ...
                                          + read line
                                          + case "$line" in
                                          + echo 0 '[INFO]' 'You'\''re' using a full whitelist configuration to allow for all IPs
                                          0 [INFO] You're using a full whitelist configuration to allow for all IPs
                                          + read line
                                          + case "$line" in
                                          + echo 0 '[LOG]' Server started ...
                                          + read line
                                          + case "$line" in
                                          + echo 0 '[LOG]' Connecting socket for: calendar
                                          0 [LOG] Connecting socket for: calendar
                                          + read line
                                          + case "$line" in
                                          + echo 0 '[LOG]' Starting node helper for: calendar
                                          0 [LOG] Starting node helper for: calendar
                                          + read line
                                          + case "$line" in
                                          + echo 0 '[LOG]' Connecting socket for: MMM-Weather-Now
                                          0 [LOG] Connecting socket for: MMM-Weather-Now
                                          + read line
                                          + case "$line" in
                                          + echo 0 '[LOG]' MMM-Weather-Now helper, started...
                                          0 [LOG] MMM-Weather-Now helper, started...
                                          + read line
                                          + case "$line" in
                                          + echo 0 '[LOG]' Connecting socket for: MMM-3Day-Forecast
                                          0 [LOG] Connecting socket for: MMM-3Day-Forecast
                                          + read line
                                          + case "$line" in
                                          + echo 0 '[LOG]' MMM-3Day-Forecast helper, started...
                                          0 [LOG] MMM-3Day-Forecast helper, started...
                                          + read line
                                          + case "$line" in
                                          + echo 0 '[LOG]' Connecting socket for: MMM-MoonPhase
                                          0 [LOG] Connecting socket for: MMM-MoonPhase
                                          + read line
                                          + case "$line" in
                                          + echo 0 '[LOG]' Starting module helper: MMM-MoonPhase
                                          0 [LOG] Starting module helper: MMM-MoonPhase
                                          + read line
                                          + case "$line" in
                                          + echo 0 '[LOG]' Connecting socket for: MMM-MyScoreboard
                                          0 [LOG] Connecting socket for: MMM-MyScoreboard
                                          + read line
                                          + case "$line" in
                                          + echo 0 '[LOG]' Starting node_helper for module '[MMM-MyScoreboard]'
                                          0 [LOG] Starting node_helper for module [MMM-MyScoreboard]
                                          + read line
                                          + case "$line" in
                                          + echo 0 '[LOG]' Sockets connected '&' modules started ...
                                          + read line
                                          + case "$line" in
                                          + echo 0 '[LOG]'
                                          0 [LOG]
                                          + read line
                                          + case "$line" in
                                          + echo Ready to 'go!' Please point your browser to: http://0.0.0.0:8080
                                          + break
                                          + exec
                                          ++ echo Ready to 'go!' Please point your browser to: http://0.0.0.0:8080
                                          ++ awk -F: '{print $4}'
                                          + port=8080
                                          + echo 'Starting chromium browser now, have patience, it takes a minute'
                                          + chromium-browser -noerrdialogs -kiosk -start_maximized --disable-infobars --app=http://localhost:8080 --ignore-certificate-errors-spki-list --ignore-ssl-errors --ignore-certificate-errors
                                          + exit
                                          however it doesn’t actually open the chromium browser.
                                          ps -ef returns
                                          ps -ef
                                          UID        PID  PPID  C STIME TTY          TIME CMD
                                          root         1     0  0 Dec16 ?        00:00:05 /sbin/init splash
                                          root         2     0  0 Dec16 ?        00:00:00 [kthreadd]
                                          root         3     2  0 Dec16 ?        00:00:00 [ksoftirqd/0]
                                          root         5     2  0 Dec16 ?        00:00:00 [kworker/0:0H]
                                          root         7     2  0 Dec16 ?        00:00:00 [lru-add-drain]
                                          root         8     2  0 Dec16 ?        00:00:00 [kdevtmpfs]
                                          root         9     2  0 Dec16 ?        00:00:00 [netns]
                                          root        10     2  0 Dec16 ?        00:00:00 [khungtaskd]
                                          root        11     2  0 Dec16 ?        00:00:00 [oom_reaper]
                                          root        12     2  0 Dec16 ?        00:00:00 [writeback]
                                          root        13     2  0 Dec16 ?        00:00:00 [kcompactd0]
                                          root        14     2  0 Dec16 ?        00:00:00 [crypto]
                                          root        15     2  0 Dec16 ?        00:00:00 [bioset]
                                          root        16     2  0 Dec16 ?        00:00:00 [kblockd]
                                          root        17     2  0 Dec16 ?        00:00:00 [watchdogd]
                                          root        19     2  0 Dec16 ?        00:00:00 [rpciod]
                                          root        20     2  0 Dec16 ?        00:00:00 [xprtiod]
                                          root        21     2  0 Dec16 ?        00:00:00 [kswapd0]
                                          root        22     2  0 Dec16 ?        00:00:00 [nfsiod]
                                          root        32     2  0 Dec16 ?        00:00:00 [kthrotld]
                                          root        33     2  0 Dec16 ?        00:00:00 [bioset]
                                          root        34     2  0 Dec16 ?        00:00:00 [bioset]
                                          root        35     2  0 Dec16 ?        00:00:00 [bioset]
                                          root        36     2  0 Dec16 ?        00:00:00 [bioset]
                                          root        37     2  0 Dec16 ?        00:00:00 [bioset]
                                          root        38     2  0 Dec16 ?        00:00:00 [bioset]
                                          root        39     2  0 Dec16 ?        00:00:00 [bioset]
                                          root        40     2  0 Dec16 ?        00:00:00 [bioset]
                                          root        41     2  0 Dec16 ?        00:00:00 [bioset]
                                          root        42     2  0 Dec16 ?        00:00:00 [bioset]
                                          root        43     2  0 Dec16 ?        00:00:00 [bioset]
                                          root        44     2  0 Dec16 ?        00:00:00 [bioset]
                                          root        45     2  0 Dec16 ?        00:00:00 [bioset]
                                          root        46     2  0 Dec16 ?        00:00:00 [bioset]
                                          root        47     2  0 Dec16 ?        00:00:00 [bioset]
                                          root        48     2  0 Dec16 ?        00:00:00 [bioset]
                                          root        49     2  0 Dec16 ?        00:00:00 [bioset]
                                          root        50     2  0 Dec16 ?        00:00:00 [bioset]
                                          root        51     2  0 Dec16 ?        00:00:00 [bioset]
                                          root        52     2  0 Dec16 ?        00:00:00 [bioset]
                                          root        53     2  0 Dec16 ?        00:00:00 [bioset]
                                          root        54     2  0 Dec16 ?        00:00:00 [bioset]
                                          root        55     2  0 Dec16 ?        00:00:00 [bioset]
                                          root        56     2  0 Dec16 ?        00:00:00 [bioset]
                                          root        57     2  0 Dec16 ?        00:00:00 [iscsi_eh]
                                          root        58     2  0 Dec16 ?        00:00:00 [dwc_otg]
                                          root        59     2  0 Dec16 ?        00:00:00 [DWC Notificatio]
                                          root        60     2  0 Dec16 ?        00:00:00 [VCHIQ-0]
                                          root        61     2  0 Dec16 ?        00:00:00 [VCHIQr-0]
                                          root        62     2  0 Dec16 ?        00:00:00 [VCHIQs-0]
                                          root        63     2  0 Dec16 ?        00:00:00 [VCHIQka-0]
                                          root        64     2  0 Dec16 ?        00:00:00 [SMIO]
                                          root        65     2  0 Dec16 ?        00:00:00 [kworker/0:2]
                                          root        66     2  0 Dec16 ?        00:00:00 [irq/86-mmc1]
                                          root        68     2  0 Dec16 ?        00:00:00 [bioset]
                                          root        69     2  0 Dec16 ?        00:00:02 [mmcqd/0]
                                          root        70     2  0 Dec16 ?        00:00:00 [jbd2/mmcblk0p2-]
                                          root        71     2  0 Dec16 ?        00:00:00 [ext4-rsv-conver]
                                          root        72     2  0 Dec16 ?        00:00:00 [ipv6_addrconf]
                                          root        89     2  0 Dec16 ?        00:00:00 [kworker/u2:1]
                                          root       105     2  0 Dec16 ?        00:00:00 [kworker/u2:2]
                                          root       118     1  0 Dec16 ?        00:00:01 /lib/systemd/systemd-journald
                                          root       120     1  0 Dec16 ?        00:00:00 /lib/systemd/systemd-udevd
                                          root       187     2  0 Dec16 ?        00:00:00 [cfg80211]
                                          root       191     2  0 Dec16 ?        00:00:00 [brcmf_wq/mmc1:0]
                                          root       192     2  0 Dec16 ?        00:00:00 [brcmf_wdog/mmc1]
                                          root       273     2  0 Dec16 ?        00:00:00 [kworker/0:1H]
                                          root       356     1  0 Dec16 ?        00:00:00 /usr/sbin/ModemManager
                                          avahi      357     1  0 Dec16 ?        00:00:01 avahi-daemon: running [raspberrypi.local]
                                          root       367     1  0 Dec16 ?        00:00:00 /usr/sbin/rsyslogd -n
                                          avahi      368   357  0 Dec16 ?        00:00:00 avahi-daemon: chroot helper
                                          root       370     1  0 Dec16 ?        00:00:00 /usr/sbin/cron -f
                                          message+   375     1  0 Dec16 ?        00:00:00 /usr/bin/dbus-daemon --system --address=systemd: --nofork --nopidfile --systemd-activation
                                          root       382     1  0 Dec16 ?        00:00:00 /sbin/dhcpcd -q -b
                                          root       410     1  0 Dec16 ?        00:00:00 /lib/systemd/systemd-logind
                                          root       441     1  0 Dec16 ?        00:00:00 /usr/lib/policykit-1/polkitd --no-debug
                                          root       442     1  0 Dec16 ?        00:00:00 /sbin/wpa_supplicant -s -B -P /run/wpa_supplicant.wlan0.pid -i wlan0 -D nl80211,wext -c /etc/wpa_supplicant/wpa_supplicant.conf
                                          root       495     1  0 Dec16 ?        00:00:00 /usr/sbin/sshd -D
                                          root       525     2  0 Dec16 ?        00:00:00 [kworker/u3:0]
                                          root       526     2  0 Dec16 ?        00:00:00 [hci0]
                                          root       527     2  0 Dec16 ?        00:00:00 [hci0]
                                          root       528     1  0 Dec16 ?        00:00:00 /usr/bin/hciattach /dev/serial1 bcm43xx 3000000 flow - b8:27:eb:b2:57:5c
                                          root       530     2  0 Dec16 ?        00:00:00 [kworker/u3:2]
                                          nobody     536     1  0 Dec16 ?        00:00:00 /usr/sbin/thd --daemon --triggers /etc/triggerhappy/triggers.d/ --socket /var/run/thd.socket --pidfile /var/run/thd.pid --user nobody /dev/inpu
                                          root       550     1  0 Dec16 ?        00:00:00 /usr/lib/bluetooth/bluetoothd
                                          ntp        577     1  0 Dec16 ?        00:00:00 /usr/sbin/ntpd -p /var/run/ntpd.pid -g -u 106:111
                                          xrdp       583     1  0 Dec16 ?        00:00:00 /usr/sbin/xrdp
                                          root       586     1  0 Dec16 ?        00:00:00 /usr/sbin/xrdp-sesman
                                          root       607     1  0 Dec16 tty1     00:00:00 /bin/login -f
                                          pi         651     1  0 Dec16 ?        00:00:00 /lib/systemd/systemd --user
                                          pi         666   651  0 Dec16 ?        00:00:00 (sd-pam)
                                          pi         694   607  0 Dec16 tty1     00:00:01 -bash
                                          pi         735     1  2 Dec16 ?        00:00:24 PM2 v4.2.1: God Daemon (/home/pi/.pm2)
                                          root       792   495  0 Dec16 ?        00:00:00 sshd: pi [priv]
                                          pi         798   792  0 Dec16 ?        00:00:00 sshd: pi@pts/0
                                          pi         800   798  0 Dec16 pts/0    00:00:01 -bash
                                          root       905     2  0 Dec16 ?        00:00:00 [kworker/0:0]
                                          root       922     2  0 Dec16 ?        00:00:00 [kworker/0:1]
                                          root       923     2  0 00:00 ?        00:00:00 [kworker/u2:0]
                                          pi         957     1  0 00:01 pts/0    00:00:00 bash -x run-start.sh
                                          pi         958   957 19 00:01 pts/0    00:00:16 node serveronly
                                          pi         995   800  0 00:03 pts/0    00:00:00 ps -ef
                                          I am running these commands from SSH, and I have the Pi configured to boot to Console Autologin (Boot Options -> B1 Desktop/CLI -> B2 Console Autologin).
                                            sdetweil @Keudn
                                            @Keudn what desktop are u running?
                                            mine shows
                                            root       481     1  0 Dec01 ?        00:00:00 /usr/sbin/lightdm
                                            ntp        490     1  0 Dec01 ?        00:03:51 /usr/sbin/ntpd -p /var/run/ntpd.pid -g -u 106:111
                                            root       517     1  0 Dec01 tty1     00:00:00 /bin/login -f
                                            root       538   481  1 Dec01 tty7     04:07:42 /usr/lib/xorg/Xorg :0 -seat seat0 -auth /var/run/lig
                                            root       589     2  0 Dec01 ?        00:00:00 [kworker/u3:0]
                                            chromium won’t open over ssh
                                              sdetweil @Keudn
                                              @Keudn said in Error performing TLS handshake: An unexpected TLS packet was received:
                                              boot to Console
                                              ah… thats why no Xorg…
                                              then it can’t start a browser as browser requires graphical mode
                                              it must run serveronly text mode and access from a remote system…
                                              so the script was correct, pi 0 running in console (text) mode.
