    Error performing TLS handshake: An unexpected TLS packet was received
    22 Posts 2 Posters 6.3k Views 2 Watching
    • K Offline
      Keudn @sdetweil
      @sdetweil Both commands get it to “Ready to go! Please point your browser…”, but it is immediately followed by
      ~/MagicMirror $ node serveronly
      [23:41:39.439] [LOG]    Starting MagicMirror: v2.10.0-develop
      [23:41:39.530] [LOG]    Loading config ...
      [23:41:39.604] [LOG]    Loading module helpers ...
      [23:41:39.617] [LOG]    No helper found for module: alert.
      [23:41:39.624] [LOG]    No helper found for module: clock.
      [23:41:42.789] [LOG]    Initializing new module helper ...
      [23:41:42.795] [LOG]    Module helper loaded: calendar
      [23:41:45.193] [LOG]    Initializing new module helper ...
      [23:41:45.198] [LOG]    Module helper loaded: MMM-Weather-Now
      [23:41:45.224] [LOG]    Initializing new module helper ...
      [23:41:45.236] [LOG]    Module helper loaded: MMM-3Day-Forecast
      [23:41:45.247] [LOG]    Initializing new module helper ...
      [23:41:45.254] [LOG]    Module helper loaded: MMM-MoonPhase
      [23:41:45.269] [LOG]    Initializing new module helper ...
      [23:41:45.274] [LOG]    Module helper loaded: MMM-MyScoreboard
      [23:41:45.279] [LOG]    All module helpers loaded.
      [23:41:45.289] [LOG]    Starting server on port 8080 ...
      [23:41:45.338] [INFO]   You're using a full whitelist configuration to allow for all IPs
      [23:41:45.394] [LOG]    Server started ...
      [23:41:45.401] [LOG]    Connecting socket for: calendar
      [23:41:45.407] [LOG]    Starting node helper for: calendar
      [23:41:45.412] [LOG]    Connecting socket for: MMM-Weather-Now
      [23:41:45.418] [LOG]    MMM-Weather-Now helper, started...
      [23:41:45.424] [LOG]    Connecting socket for: MMM-3Day-Forecast
      [23:41:45.429] [LOG]    MMM-3Day-Forecast helper, started...
      [23:41:45.434] [LOG]    Connecting socket for: MMM-MoonPhase
      [23:41:45.438] [LOG]    Starting module helper: MMM-MoonPhase
      [23:41:45.443] [LOG]    Connecting socket for: MMM-MyScoreboard
      [23:41:45.448] [LOG]    Starting node_helper for module [MMM-MyScoreboard]
      [23:41:50.375] [LOG]    Sockets connected & modules started ...
      [23:41:50.381] [LOG]
      Ready to go! Please point your browser to: http://0.0.0.0:8080
      [23:41:50.456] [LOG]    Whoops! There was an uncaught exception...
      [23:41:50.462] [ERROR]  { Error: listen EADDRINUSE: address already in use 0.0.0.0:8080
          at Server.setupListenHandle [as _listen2] (net.js:1279:14)
          at listenInCluster (net.js:1327:12)
          at doListen (net.js:1460:7)
          at process._tickCallback (internal/process/next_tick.js:63:19)
          at Function.Module.runMain (internal/modules/cjs/loader.js:832:11)
          at startup (internal/bootstrap/node.js:283:19)
          at bootstrapNodeJSCore (internal/bootstrap/node.js:622:3)
        code: 'EADDRINUSE',
        errno: 'EADDRINUSE',
        syscall: 'listen',
        address: '0.0.0.0',
        port: 8080 }
      [23:41:50.528] [LOG]    MagicMirror will not quit, but it might be a good idea to check why this happened. Maybe no internet connection?
      [23:41:50.533] [LOG]    If you think this really is an issue, please open an issue on GitHub: https://github.com/MichMich/MagicMirror/issues
      I’m not sure why there would be the address already in use unless it already started correctly. In that case why would the browser not open?
        sdetweil @Keudn
        @Keudn because the pm2 instance is running…
        • K Offline
          Keudn @sdetweil
          @sdetweil Yeah, I just don’t understand why running “bash -x run-start.sh” would give the exact same output as “node serveronly” and not open the browser once it sees it is ready. The run-start.sh script doesn’t get to the #start chromium section.
          When I run “bash -x run-start.sh” this is the output I get
          $ bash -x run-start.sh
          + ./untrack-css.sh
          + '[' -z '' ']'
          + export DISPLAY=:0
          + DISPLAY=:0
          ++ uname -m
          + arch=armv6l
          ++ awk '{print tolower($2)}'
          ++ tr -d ',"'\'''
          ++ grep -i serveronly: config/config.js
          + serveronly=
          + serveronly=false
          ++ pgrep Xorg
          + xorg=
          ++ uname
          + mac=Linux
          + '[' false. '!=' false. -o armv6l == armv6l ']'
          + '[' false. == true. -o . == . ']'
          + node serveronly
          [23:50:08.974] [LOG]    Starting MagicMirror: v2.10.0-develop
          [23:50:09.097] [LOG]    Loading config ...
          [23:50:09.217] [LOG]    Loading module helpers ...
          [23:50:09.236] [LOG]    No helper found for module: alert.
          [23:50:09.245] [LOG]    No helper found for module: clock.
          [23:50:13.447] [LOG]    Initializing new module helper ...
          [23:50:13.458] [LOG]    Module helper loaded: calendar
          [23:50:16.551] [LOG]    Initializing new module helper ...
          [23:50:16.568] [LOG]    Module helper loaded: MMM-Weather-Now
          [23:50:16.610] [LOG]    Initializing new module helper ...
          [23:50:16.649] [LOG]    Module helper loaded: MMM-3Day-Forecast
          [23:50:16.685] [LOG]    Initializing new module helper ...
          [23:50:16.694] [LOG]    Module helper loaded: MMM-MoonPhase
          [23:50:16.725] [LOG]    Initializing new module helper ...
          [23:50:16.734] [LOG]    Module helper loaded: MMM-MyScoreboard
          [23:50:16.740] [LOG]    All module helpers loaded.
          [23:50:16.754] [LOG]    Starting server on port 8080 ...
          [23:50:16.822] [INFO]   You're using a full whitelist configuration to allow for all IPs
          [23:50:16.899] [LOG]    Server started ...
          [23:50:16.910] [LOG]    Connecting socket for: calendar
          [23:50:16.918] [LOG]    Starting node helper for: calendar
          [23:50:16.924] [LOG]    Connecting socket for: MMM-Weather-Now
          [23:50:16.932] [LOG]    MMM-Weather-Now helper, started...
          [23:50:16.937] [LOG]    Connecting socket for: MMM-3Day-Forecast
          [23:50:16.944] [LOG]    MMM-3Day-Forecast helper, started...
          [23:50:16.951] [LOG]    Connecting socket for: MMM-MoonPhase
          [23:50:16.956] [LOG]    Starting module helper: MMM-MoonPhase
          [23:50:16.965] [LOG]    Connecting socket for: MMM-MyScoreboard
          [23:50:16.970] [LOG]    Starting node_helper for module [MMM-MyScoreboard]
          [23:50:23.495] [LOG]    Sockets connected & modules started ...
          [23:50:23.506] [LOG]
          [23:50:23.607] [LOG]    Whoops! There was an uncaught exception...
          [23:50:23.615] [ERROR]  { Error: listen EADDRINUSE: address already in use 0.0.0.0:8080
            code: 'EADDRINUSE',
            syscall: 'listen',
            address: '0.0.0.0',
            port: 8080 }
          [23:50:23.702] [LOG]    MagicMirror will not quit, but it might be a good idea to check why this happened. Maybe no internet connection?
          [23:50:23.706] [LOG]    If you think this really is an issue, please open an issue on GitHub: https://github.com/MichMich/MagicMirror/issues
            sdetweil @Keudn
            @Keudn right, but the run failed, cause of the address in use problem… need to stop the other instance to test…
            pm2 stop MagicMirror
              @Keudn do this
              should return a null line
                sdetweil
                its stuck cause the script didn’t find xorg running
                pgrep Xorg returned ‘’
                edit the run-start.sh script and change line
                if [ "$serveronly." == "true." -o "$xorg." == "." ]; then
                to
                if [ "$serveronly." == "true." -a "$xorg." == "." ]; then
                  @sdetweil are u running in text mode on the pi 0? no… cause u expect browser to open
                  can u post output of
                  ps -ef
                  thx
                  • K Offline
                    Keudn @sdetweil
                    @sdetweil Stopping the magic mirror process before running bash -x run-start.sh just hangs on the line “Ready to go…” and never goes further.
                    grep -i serveronly: config/config.js does in fact return nothing.
                    I edited the line, stopped the MagicMirror process, and re-ran run-start.sh. It now gives this output
                    + ./untrack-css.sh
                    + '[' -z '' ']'
                    + export DISPLAY=:0
                    + DISPLAY=:0
                    ++ uname -m
                    + arch=armv6l
                    ++ tr -d ',"'\'''
                    + serveronly=
                    + serveronly=false
                    ++ pgrep Xorg
                    + xorg=
                    ++ uname
                    + mac=Linux
                    + '[' false. == true. -a . == . ']'
                    + exec
                    + read line
                    ++ node serveronly
                    + case "$line" in
                    + echo 0 '[LOG]' Starting MagicMirror: v2.10.0-develop
                    0 [LOG] Starting MagicMirror: v2.10.0-develop
                    + read line
                    + case "$line" in
                    + echo 0 '[LOG]' Loading config ...
                    0 [LOG] Loading config ...
                    + read line
                    + case "$line" in
                    + echo 0 '[LOG]' Loading module helpers ...
                    0 [LOG] Loading module helpers ...
                    + read line
                    + case "$line" in
                    + echo 0 '[LOG]' No helper found for module: alert.
                    0 [LOG] No helper found for module: alert.
                    + read line
                    + case "$line" in
                    + echo 0 '[LOG]' No helper found for module: clock.
                    0 [LOG] No helper found for module: clock.
                    + read line
                    + case "$line" in
                    + echo 0 '[LOG]' Initializing new module helper ...
                    0 [LOG] Initializing new module helper ...
                    + read line
                    + case "$line" in
                    + echo 0 '[LOG]' Module helper loaded: calendar
                    0 [LOG] Module helper loaded: calendar
                    + read line
                    + case "$line" in
                    + read line
                    + case "$line" in
                    + echo 0 '[LOG]' Module helper loaded: MMM-Weather-Now
                    0 [LOG] Module helper loaded: MMM-Weather-Now
                    + read line
                    + case "$line" in
                    + read line
                    + case "$line" in
                    + echo 0 '[LOG]' Module helper loaded: MMM-3Day-Forecast
                    0 [LOG] Module helper loaded: MMM-3Day-Forecast
                    + read line
                    + case "$line" in
                    + read line
                    + case "$line" in
                    + echo 0 '[LOG]' Module helper loaded: MMM-MoonPhase
                    0 [LOG] Module helper loaded: MMM-MoonPhase
                    + read line
                    + case "$line" in
                    + read line
                    + case "$line" in
                    + echo 0 '[LOG]' Module helper loaded: MMM-MyScoreboard
                    0 [LOG] Module helper loaded: MMM-MyScoreboard
                    + read line
                    + case "$line" in
                    + echo 0 '[LOG]' All module helpers loaded.
                    0 [LOG] All module helpers loaded.
                    + read line
                    + case "$line" in
                    + echo 0 '[LOG]' Starting server on port 8080 ...
                    0 [LOG] Starting server on port 8080 ...
                    + read line
                    + case "$line" in
                    + echo 0 '[INFO]' 'You'\''re' using a full whitelist configuration to allow for all IPs
                    0 [INFO] You're using a full whitelist configuration to allow for all IPs
                    + read line
                    + case "$line" in
                    + echo 0 '[LOG]' Server started ...
                    0 [LOG] Server started ...
                    + read line
                    + case "$line" in
                    + echo 0 '[LOG]' Connecting socket for: calendar
                    0 [LOG] Connecting socket for: calendar
                    + read line
                    + case "$line" in
                    + echo 0 '[LOG]' Starting node helper for: calendar
                    0 [LOG] Starting node helper for: calendar
                    + read line
                    + case "$line" in
                    + echo 0 '[LOG]' Connecting socket for: MMM-Weather-Now
                    0 [LOG] Connecting socket for: MMM-Weather-Now
                    + read line
                    + case "$line" in
                    + echo 0 '[LOG]' MMM-Weather-Now helper, started...
                    0 [LOG] MMM-Weather-Now helper, started...
                    + read line
                    + case "$line" in
                    + echo 0 '[LOG]' Connecting socket for: MMM-3Day-Forecast
                    0 [LOG] Connecting socket for: MMM-3Day-Forecast
                    + read line
                    + case "$line" in
                    + echo 0 '[LOG]' MMM-3Day-Forecast helper, started...
                    0 [LOG] MMM-3Day-Forecast helper, started...
                    + read line
                    + case "$line" in
                    + echo 0 '[LOG]' Connecting socket for: MMM-MoonPhase
                    0 [LOG] Connecting socket for: MMM-MoonPhase
                    + read line
                    + case "$line" in
                    + echo 0 '[LOG]' Starting module helper: MMM-MoonPhase
                    0 [LOG] Starting module helper: MMM-MoonPhase
                    + read line
                    + case "$line" in
                    + echo 0 '[LOG]' Connecting socket for: MMM-MyScoreboard
                    0 [LOG] Connecting socket for: MMM-MyScoreboard
                    + read line
                    + case "$line" in
                    + echo 0 '[LOG]' Starting node_helper for module '[MMM-MyScoreboard]'
                    0 [LOG] Starting node_helper for module [MMM-MyScoreboard]
                    + read line
                    + case "$line" in
                    + echo 0 '[LOG]' Sockets connected '&' modules started ...
                    0 [LOG] Sockets connected & modules started ...
                    + read line
                    + case "$line" in
                    + echo 0 '[LOG]'
                    0 [LOG]
                    + read line
                    + case "$line" in
                    + echo Ready to 'go!' Please point your browser to: http://0.0.0.0:8080
                    + break
                    + exec
                    ++ echo Ready to 'go!' Please point your browser to: http://0.0.0.0:8080
                    ++ awk -F: '{print $4}'
                    + port=8080
                    + echo 'Starting chromium browser now, have patience, it takes a minute'
                    + chromium-browser -noerrdialogs -kiosk -start_maximized --disable-infobars --app=http://localhost:8080 --ignore-certificate-errors-spki-list --ignore-ssl-errors --ignore-certificate-errors
                    + exit
                    however it doesn’t actually open the chromium browser.
                    ps -ef returns
                    ps -ef
                    UID        PID  PPID  C STIME TTY          TIME CMD
                    root         1     0  0 Dec16 ?        00:00:05 /sbin/init splash
                    root         2     0  0 Dec16 ?        00:00:00 [kthreadd]
                    root         3     2  0 Dec16 ?        00:00:00 [ksoftirqd/0]
                    root         5     2  0 Dec16 ?        00:00:00 [kworker/0:0H]
                    root         7     2  0 Dec16 ?        00:00:00 [lru-add-drain]
                    root         8     2  0 Dec16 ?        00:00:00 [kdevtmpfs]
                    root         9     2  0 Dec16 ?        00:00:00 [netns]
                    root        10     2  0 Dec16 ?        00:00:00 [khungtaskd]
                    root        11     2  0 Dec16 ?        00:00:00 [oom_reaper]
                    root        12     2  0 Dec16 ?        00:00:00 [writeback]
                    root        13     2  0 Dec16 ?        00:00:00 [kcompactd0]
                    root        14     2  0 Dec16 ?        00:00:00 [crypto]
                    root        15     2  0 Dec16 ?        00:00:00 [bioset]
                    root        16     2  0 Dec16 ?        00:00:00 [kblockd]
                    root        17     2  0 Dec16 ?        00:00:00 [watchdogd]
                    root        19     2  0 Dec16 ?        00:00:00 [rpciod]
                    root        20     2  0 Dec16 ?        00:00:00 [xprtiod]
                    root        21     2  0 Dec16 ?        00:00:00 [kswapd0]
                    root        22     2  0 Dec16 ?        00:00:00 [nfsiod]
                    root        32     2  0 Dec16 ?        00:00:00 [kthrotld]
                    root        33     2  0 Dec16 ?        00:00:00 [bioset]
                    root        34     2  0 Dec16 ?        00:00:00 [bioset]
                    root        35     2  0 Dec16 ?        00:00:00 [bioset]
                    root        36     2  0 Dec16 ?        00:00:00 [bioset]
                    root        37     2  0 Dec16 ?        00:00:00 [bioset]
                    root        38     2  0 Dec16 ?        00:00:00 [bioset]
                    root        39     2  0 Dec16 ?        00:00:00 [bioset]
                    root        40     2  0 Dec16 ?        00:00:00 [bioset]
                    root        41     2  0 Dec16 ?        00:00:00 [bioset]
                    root        42     2  0 Dec16 ?        00:00:00 [bioset]
                    root        43     2  0 Dec16 ?        00:00:00 [bioset]
                    root        44     2  0 Dec16 ?        00:00:00 [bioset]
                    root        45     2  0 Dec16 ?        00:00:00 [bioset]
                    root        46     2  0 Dec16 ?        00:00:00 [bioset]
                    root        47     2  0 Dec16 ?        00:00:00 [bioset]
                    root        48     2  0 Dec16 ?        00:00:00 [bioset]
                    root        49     2  0 Dec16 ?        00:00:00 [bioset]
                    root        50     2  0 Dec16 ?        00:00:00 [bioset]
                    root        51     2  0 Dec16 ?        00:00:00 [bioset]
                    root        52     2  0 Dec16 ?        00:00:00 [bioset]
                    root        53     2  0 Dec16 ?        00:00:00 [bioset]
                    root        54     2  0 Dec16 ?        00:00:00 [bioset]
                    root        55     2  0 Dec16 ?        00:00:00 [bioset]
                    root        56     2  0 Dec16 ?        00:00:00 [bioset]
                    root        57     2  0 Dec16 ?        00:00:00 [iscsi_eh]
                    root        58     2  0 Dec16 ?        00:00:00 [dwc_otg]
                    root        59     2  0 Dec16 ?        00:00:00 [DWC Notificatio]
                    root        60     2  0 Dec16 ?        00:00:00 [VCHIQ-0]
                    root        61     2  0 Dec16 ?        00:00:00 [VCHIQr-0]
                    root        62     2  0 Dec16 ?        00:00:00 [VCHIQs-0]
                    root        63     2  0 Dec16 ?        00:00:00 [VCHIQka-0]
                    root        64     2  0 Dec16 ?        00:00:00 [SMIO]
                    root        65     2  0 Dec16 ?        00:00:00 [kworker/0:2]
                    root        66     2  0 Dec16 ?        00:00:00 [irq/86-mmc1]
                    root        68     2  0 Dec16 ?        00:00:00 [bioset]
                    root        69     2  0 Dec16 ?        00:00:02 [mmcqd/0]
                    root        70     2  0 Dec16 ?        00:00:00 [jbd2/mmcblk0p2-]
                    root        71     2  0 Dec16 ?        00:00:00 [ext4-rsv-conver]
                    root        72     2  0 Dec16 ?        00:00:00 [ipv6_addrconf]
                    root        89     2  0 Dec16 ?        00:00:00 [kworker/u2:1]
                    root       105     2  0 Dec16 ?        00:00:00 [kworker/u2:2]
                    root       118     1  0 Dec16 ?        00:00:01 /lib/systemd/systemd-journald
                    root       120     1  0 Dec16 ?        00:00:00 /lib/systemd/systemd-udevd
                    root       187     2  0 Dec16 ?        00:00:00 [cfg80211]
                    root       191     2  0 Dec16 ?        00:00:00 [brcmf_wq/mmc1:0]
                    root       192     2  0 Dec16 ?        00:00:00 [brcmf_wdog/mmc1]
                    root       273     2  0 Dec16 ?        00:00:00 [kworker/0:1H]
                    root       356     1  0 Dec16 ?        00:00:00 /usr/sbin/ModemManager
                    avahi      357     1  0 Dec16 ?        00:00:01 avahi-daemon: running [raspberrypi.local]
                    root       367     1  0 Dec16 ?        00:00:00 /usr/sbin/rsyslogd -n
                    avahi      368   357  0 Dec16 ?        00:00:00 avahi-daemon: chroot helper
                    root       370     1  0 Dec16 ?        00:00:00 /usr/sbin/cron -f
                    message+   375     1  0 Dec16 ?        00:00:00 /usr/bin/dbus-daemon --system --address=systemd: --nofork --nopidfile --systemd-activation
                    root       382     1  0 Dec16 ?        00:00:00 /sbin/dhcpcd -q -b
                    root       410     1  0 Dec16 ?        00:00:00 /lib/systemd/systemd-logind
                    root       441     1  0 Dec16 ?        00:00:00 /usr/lib/policykit-1/polkitd --no-debug
                    root       442     1  0 Dec16 ?        00:00:00 /sbin/wpa_supplicant -s -B -P /run/wpa_supplicant.wlan0.pid -i wlan0 -D nl80211,wext -c /etc/wpa_supplicant/wpa_supplicant.conf
                    root       495     1  0 Dec16 ?        00:00:00 /usr/sbin/sshd -D
                    root       525     2  0 Dec16 ?        00:00:00 [kworker/u3:0]
                    root       526     2  0 Dec16 ?        00:00:00 [hci0]
                    root       527     2  0 Dec16 ?        00:00:00 [hci0]
                    root       528     1  0 Dec16 ?        00:00:00 /usr/bin/hciattach /dev/serial1 bcm43xx 3000000 flow - b8:27:eb:b2:57:5c
                    root       530     2  0 Dec16 ?        00:00:00 [kworker/u3:2]
                    nobody     536     1  0 Dec16 ?        00:00:00 /usr/sbin/thd --daemon --triggers /etc/triggerhappy/triggers.d/ --socket /var/run/thd.socket --pidfile /var/run/thd.pid --user nobody /dev/inpu
                    root       550     1  0 Dec16 ?        00:00:00 /usr/lib/bluetooth/bluetoothd
                    ntp        577     1  0 Dec16 ?        00:00:00 /usr/sbin/ntpd -p /var/run/ntpd.pid -g -u 106:111
                    xrdp       583     1  0 Dec16 ?        00:00:00 /usr/sbin/xrdp
                    root       586     1  0 Dec16 ?        00:00:00 /usr/sbin/xrdp-sesman
                    root       607     1  0 Dec16 tty1     00:00:00 /bin/login -f
                    pi         651     1  0 Dec16 ?        00:00:00 /lib/systemd/systemd --user
                    pi         666   651  0 Dec16 ?        00:00:00 (sd-pam)
                    pi         694   607  0 Dec16 tty1     00:00:01 -bash
                    pi         735     1  2 Dec16 ?        00:00:24 PM2 v4.2.1: God Daemon (/home/pi/.pm2)
                    root       792   495  0 Dec16 ?        00:00:00 sshd: pi [priv]
                    pi         798   792  0 Dec16 ?        00:00:00 sshd: pi@pts/0
                    pi         800   798  0 Dec16 pts/0    00:00:01 -bash
                    root       905     2  0 Dec16 ?        00:00:00 [kworker/0:0]
                    root       922     2  0 Dec16 ?        00:00:00 [kworker/0:1]
                    root       923     2  0 00:00 ?        00:00:00 [kworker/u2:0]
                    pi         957     1  0 00:01 pts/0    00:00:00 bash -x run-start.sh
                    pi         958   957 19 00:01 pts/0    00:00:16 node serveronly
                    pi         995   800  0 00:03 pts/0    00:00:00 ps -ef
                    I am running these commands from SSH, and I have the Pi configured to boot to Console Autologin (Boot Options -> B1 Desktop/CLI -> B2 Console Autologin).
                      sdetweil @Keudn
                      @Keudn what desktop are u running?
                      mine shows
                      root       481     1  0 Dec01 ?        00:00:00 /usr/sbin/lightdm
                      ntp        490     1  0 Dec01 ?        00:03:51 /usr/sbin/ntpd -p /var/run/ntpd.pid -g -u 106:111
                      root       517     1  0 Dec01 tty1     00:00:00 /bin/login -f
                      root       538   481  1 Dec01 tty7     04:07:42 /usr/lib/xorg/Xorg :0 -seat seat0 -auth /var/run/lig
                      root       589     2  0 Dec01 ?        00:00:00 [kworker/u3:0]
                      chromium won’t open over ssh
                        sdetweil @Keudn
                        @Keudn said in Error performing TLS handshake: An unexpected TLS packet was received:
                        boot to Console
                        ah… thats why no Xorg…
                        then it can’t start a browser as browser requires graphical mode
                        it must run serveronly text mode and access from a remote system…
                        so the script was correct, pi 0 running in console (text) mode.
                        • 2 / 3
