    Calendar Doesn't Honor custom.css for Background
    16 Posts 2 Posters 5.2k Views 2 Watching
    • E Offline
      ember1205
      I attempted to add the following to my custom.css:
      .module.calendar {
        background-color:rgba(32,32,32,0.6);
        border-radius:8px;
        padding:8px;
      It did not work as expected, nor as it did for clock, currentweather, or weatherforecast. I had to insert that code into the ~/MagicMirror/modules/default/calendar/calendar.css module as:
      .calendar {
        border-radius:8px;
        padding:8px;
      This is the only way it would provide the opaque background that I wanted.
      Thoughts?
        sdetweil @ember1205
        @ember1205 right. Css for a module is the module name with a leading dot.
        Not the world module
        E 2 Replies Last reply Reply Quote 0
        • E Offline
          ember1205 @sdetweil
          In custom.css, this does not work:
          .module.calendar {
            border-radius:8px;
            padding:8px;
          Also, in custom.css, this DOES work:
          .module.currentweather {
            border-radius:8px;
            padding:8px;
          .module.weatherforecast {
            border-radius:8px;
            padding:8px;
          .module.clock {
            border-radius:8px;
            padding:8px;
          • E Offline
            ember1205 @sdetweil
            @sdetweil What does “not the world module” mean? Just seeing that now, and not following…
              sdetweil @ember1205
              @ember1205 like this custom.css
              body {
              .currentweather {
                border-radius:8px;
                padding:8px;
              .weatherforecast {
                border-radius:8px;
                padding:8px;
              .clock {
                border-radius:8px;
                padding:8px;
              you don’t do
              .module.clock
              S E 2 Replies Last reply Reply Quote 0
                @ember1205 and to change the color of the DATE of the digital clock (which uses the date class)
                .clock .date {
                   color: green;
                • E Offline
                  ember1205 @sdetweil
                  Ok. I will look into making those changes and see if I can get it working the way that I want.
                  Why does “module.currentweather” work fine, though (along with the others that I mentioned)? CSS has always been a weak spot for me…
                    sdetweil @ember1205
                    @ember1205 said in Calendar Doesn't Honor custom.css for Background:
                    no idea… css is my weakest skill
                    • E Offline
                      ember1205 @sdetweil
                      Calendar still does not pick up any CSS controls from the main custom.css file. Here is a snippet of what I added:
                      .calendar {
                        border-radius:8px;
                        padding:8px;
                      I modified the other sections to look like this:
                      .module.clock {
                        border-radius:8px;
                        padding:8px;
                        border-radius:8px;
                        padding:8px;
                        border-radius:8px;
                        padding:8px;
                      They work fine “either way”. Calendar refuses to pick up the formatting from the custom.css file it seems and I have to put the controls into the calendar.css file in the module’s directory.
                        sdetweil @ember1205
                        @ember1205 hm… custom.css should override everything… it is loaded last
                          @ember1205
                          hm…
                          .calendar .title {
                              color: blue;
                          works for me
                          from the readme
                          | `titleClass`          | Add a class to the title's cell.
                          | `timeClass`           | Add a class to the time's cell.
                          one not documented is the ‘symbolClass’
                            @ember1205 part of the other problem is calendar doesn’t have a cohesive background element… it has table rows of elements…
                            but there is a tableClass setting, which you can use in config.js to force a particular class
                            but you HAVE to do this, else no special class is applied
                            • E Offline
                              ember1205 @sdetweil
                              I found and fixed it (sort of). I had added content to my custom.css file to create a blurred background image as I was experimenting with some display options. I commented that content out (or so I thought) and placed all of these controls “after” that section in the custom.css file.
                              Through a variety of changes that I was making to try and track this down, I noticed through viewing the Developer options with a real browser and looking at the elements that whatever section came first after my blurred background section wasn’t being picked up. As I rolled the changes down to the bottom, I was seeing different sections stop working.
                              Seems to be all fixed now, and is clearly not a bug in the product but was a bug in my custom.css content. After deleting the content, all is displaying properly.
                                sdetweil @ember1205
                                @ember1205 so, this custom.css works
                                 body {
                                .clock .date {
                                	color: green;
                                .calendar .title {
                                color : blue;
                                .calendar .fribble {
                                  border-radius:8px;
                                  padding:8px;
                                with
                                   tableClass:"fribble"
                                  sdetweil @ember1205
                                  electron is a real browser, so you can do this ON the mirror,
                                  or from your desktop if the config parms allow remote system access.
                                  I always forget that I can use local browser to view developer window
                                  • E Offline
                                    ember1205 @sdetweil
                                    @sdetweil said in Calendar Doesn't Honor custom.css for Background:
                                    Now that you mention it, I have used the developer options directly on the appliance and should have remembered that. Thanks for the reminder!
