    How I got my Magic Mirror working on a Raspberry Pi 0 (zero)
    raspberry pipi0zeropizeropi1
    204 Posts 47 Posters 606.4k Views 47 Watching
    • bheplerB Offline
      bhepler Module Developer @noorm91
      @noorm91 npm start is the command to start the Magic Mirror application and display the interface on the screen.
      • N Offline
        noorm91 @bhepler
        @bhepler
        I can’t seem to start MM with npm start, tried through SSH and directly on rpi with keyboard.
        pi@raspberrypi:~/MagicMirror $ DISPLAY=:0 nohup npm start &
        [1] 890
        pi@raspberrypi:~/MagicMirror $ nohup: ignoring input and appending output to ‘nohup.out’
        ^C
        [1]+ Exit 1 DISPLAY=:0 nohup npm start
        magicmirror@2.1.0 start /home/pi/MagicMirror
        electron js/electron.js
        /home/pi/MagicMirror/node_modules/electron/dist/electron: error while loading shared libraries: libgconf-2.so.4: cannot open shared object file: No such file or directory
        npm ERR! Linux 4.4.34+
        npm ERR! argv “/usr/local/bin/node” “/usr/local/bin/npm” “start”
        npm ERR! node v4.2.1
        npm ERR! npm v2.14.7
        npm ERR! file sh
        npm ERR! code ELIFECYCLE
        npm ERR! errno ENOENT
        npm ERR! syscall spawn
        npm ERR! magicmirror@2.1.0 start: electron js/electron.js
        npm ERR! spawn ENOENT
        npm ERR!
        npm ERR! Failed at the magicmirror@2.1.0 start script ‘electron js/electron.js’.
        npm ERR! This is most likely a problem with the magicmirror package,
        npm ERR! not with npm itself.
        npm ERR! electron js/electron.js
        npm ERR! You can get their info via:
        npm ERR! npm owner ls magicmirror
        npm ERR! /home/pi/MagicMirror/npm-debug.log
        • H Offline
          Hawking @noorm91
          @noorm91 said in How I got my Magic Mirror working on a Raspberry Pi 0 (zero):
          @bhepler
          Thats what I expected for the Pi Zero. Did you try the method described in the first post of this thread in the section “Setting up boot scripts”?
            Doubleve
            I took everything back with the first post everything works !!!
            H 1 Reply Last reply Reply Quote 1
            • H Offline
              Hawking @Doubleve
              @Doubleve
              Can you tell me which Linux distribution (lsb_release -a), node version ( node -v ) and version of MM you are using?
                delusional112
                Hi guys, I saw someone asked before, isn’t there anyone who has a working image for MM2 on a Pi Zero. I tried a lot of things before, cant get it to work. Now, I don’t have a lot of time to experiment with it, school and work are killing me. My mirror is lying around, unused. Please help me out here,
                Thanks!!
                • N Offline
                  noorm91 @delusional112
                  @delusional112
                  Here is an image, it has a couple of errors that needs fixing but the magicmirror starts at least.
                  If you have any solutions please keep us informed…this image is made by Sebtota.
                  https://mega.nz/#!XlIU3QjI!QSdvAE3yXp1oMsdRGNte6lt4SncgvfozSDU7xhxtbbM
                  Here is the topic I found the image at.
                  https://forum.magicmirror.builders/topic/1183/how-i-got-my-magic-mirror-working-on-a-raspberry-pi-0-zero/85?page=9
                  • N Offline
                    noorm91
                    Any clue on what is trying to start and not functioning alright here?
                    Starting MagicMirror: v2.1.0
                    Loading config ...
                    Loading module helpers ...
                    All module helpers loaded.
                    Starting server op port 8080 ...
                    Server started ...
                    Starting module: newsfeed
                    Ready to go! Please point your browser to: http://localhost:8080
                    { [Error: listen EADDRINUSE :::8080]
                      code: 'EADDRINUSE',
                      errno: 'EADDRINUSE',
                      syscall: 'listen',
                      address: '::',
                      port: 8080 }
                    (EE)
                    Fatal server error:
                    (EE) Server is already active for display 0
                            If this server is no longer running, remove /tmp/.X0-lock
                            and start again.
                    (EE)
                    (EE)
                    Please consult the The X.Org Foundation support
                             at http://wiki.x.org
                     for help.
                    (EE)
                    XIO:  fatal IO error 11 (Resource temporarily unavailable) on X server ":0"
                          after 7 requests (7 known processed) with 0 events remaining.
                    • bheplerB Offline
                      Whoops! There was an uncaught exception…
                      8080]
                      This usually means that you already have a process trying to serve up web pages on port 8080. In my experience, this happens when you do not terminate your previous attempt to run the MM process and start up another one. The new one also tries to serve up pages on port 8080 and you get that error.
                      You can use ps ax | grep node to see if node is running when you attempt to start your mirror. If it is, node is already serving up pages, so you will want to stop whatever process is running first. Alternately, if you are running a web server on port 8080 already, you can switch the port of the MM process in the config.js file.
                      • MarWindM Offline
                        MarWind
                        So did anyone get MM2 on a Pi Zero W with Raspian Stretch lite running?
                        Or is it better to stay with Jessie?
                        ~ride bikes and boards not always on top~
                        • 12
                        • 13
                        • 14
                        • 15
                        • 16
                        • 20
                        • 21
                        • 14 / 21
