    MagicMirror behind a NGinx Reverse Proxy
    17 Posts 3 Posters 40.1k Views 3 Watching
    • F Offline
      fbr1969
      I’m would like to acced to MM (192.168.10.60:8080) behind a Nginx Reverse Proxy (IP:192.168.10.10 for example). I’m not an expert of Nginx and I tried :
      server {
          listen      80;
          server_name domain.com;
          return      301 https://$server_name$request_uri;
      server {
          # Setup HTTPS certificates
          listen       443 default ssl;
          ssl_certificate /etc/letsencrypt/live/domain.com/fullchain.pem; # managed by Certbot
          ssl_certificate_key /etc/letsencrypt/live/domain.com/privkey.pem; # managed by Certbot
          include /etc/letsencrypt/options-ssl-nginx.conf; # managed by Certbot
          ssl_dhparam /etc/letsencrypt/ssl-dhparams.pem; # managed by Certbot
          location /mmirror {
              proxy_bind              $server_addr;
              proxy_pass              http://192.168.10.60:8080;
              proxy_set_header        Host            $http_host;
              proxy_set_header        X-Forwarded-For $proxy_add_x_forwarded_for;
              proxy_set_header        X-Scheme        $scheme;
              proxy_set_header        X-Script-Name   /;
          location / {
              root   /var/www/html;
              index  index.html ;
      But if y want to access to : 192.168.10.10/mmirror
      I get this error : 502 Bad Gateway nginx/1.14.2
      MagicMirror is of course fully fonctionnal in direct by 192.168.10.60:8080.
      Thank for your help.
      François
        sdetweil @fbr1969
        @fbr1969 is domain.com resolved by the client system to the nginx server?
        this
        should get a 301 moved to https://domain.com/mmirror
        where-ever domain.com is…
        I might change the moved to https://$server_addr$request_url
          sdetweil @fbr1969
          @fbr1969 said in MagicMirror behind a NGinx Reverse Proxy:
          if u do
          curl http://192.168.10.10/mmirror
          (do not use -L)
          u should get a 301 response, right?
          and if u use the url in the moved, does it work? domain.com shouldn’t. proxy.domain.com might if u have a hosts entry or a dns server resolving that to 192.168.10.10
          you could also do
          curl -iL http://192.168.10.10/mmirror
          to see the full flow (-i shows the response headers)
          https://stackabuse.com/follow-redirects-in-curl/
            sdetweil
            I would also try
            https://192.168.10.10/mmirror
            and see if that works (no redirect)
            this will test the certs and the passthru config
            • E Offline
              ember1205
              Firstly, do you really want to put your mirror behind a piece of software developed by the Russians, released into Open Source, then claimed by another Russian Company as “theirs” after it was purchased out by a commercial entity (F5)? If you need a reverse proxy, you’re likely to have all that you need from a simply Apache setup.
              Second - you will need to ensure that all of your rewrite rules take into account the back-end port along with the front-end port information as well as specific host name rules.
              For example:
              If your MM is 192.168.1.10 and you have a system running reverse proxy with a VIP on 192.168.1.50, you will need to decide if you’re going to continue using port 8080 on the front-end or if you want to fall back to standard port 80 (or even tie it up with a certificate on 443 with HTTPS/SSL).
              In other words, you could be doing client to proxy as 192.168.1.100 -> http://192.168.1.50 or 192.168.1.100 -> http://192.168.1.50:8080 or 192.168.1.100 -> https://192.168.1.50 or something else entirely.
              After you have decided how you’re handling the front end, you then need to ensure that you’re rewriting ALL of that as it passes through the proxy to/from http://192.168.1.10:8080
              You ALSO need to ensure that you have updated the configuration on MM to allow connections from off-box IP’s. Specifically, unless you are forcing the use of the original source IP, connections to the mirror should be coming from the system running your proxy and THAT address needs to have access to the web server on the mirror.
              • F Offline
                fbr1969 @sdetweil
                @sdetweil @ember1205 Thank for your help.
                I made a mistake ! My error is 404 (Cannot GET /mmirror)
                I forgot to say :
                • My nginx server is fully fonctional with some other locations I’ve masqued in my exemple of configuration files… Like that :
                    # Proxy to the Airsonic server
                    location /airsonic {
                        proxy_set_header X-Real-IP         $remote_addr;
                        proxy_set_header X-Forwarded-Proto https;
                        proxy_set_header X-Forwarded-Host  $http_host;
                        proxy_max_temp_file_size           0;
                        proxy_pass                         http://192.168.10.30:8080/airsonic;
                        proxy_redirect                     http:// https://;
                    location /calilivre {
                        proxy_pass              http://192.168.10.20:8080;
                        proxy_set_header        X-Forwarded-Host $server_name;
                        proxy_set_header        X-Script-Name   /calilivre;  # IMPORTANT: path has NO trailing slash
                    location /calibd {
                        proxy_pass              http://192.168.10.50:8080;
                        proxy_set_header        X-Script-Name   /calibd;  # IMPORTANT: path has NO trailing slash
                    location /mmirror {
                        proxy_set_header        X-Script-Name   /;  # IMPORTANT: path has NO trailing slash
                So, airsonic, calibd or calilivre are fully fonctional in http (redirect to https) or https.
                My 'domainename (ex:domain.com) is resolved by dns.
                I can do my test on my private lan or on Internet. I’ve the same result (502 Bad Gateway).
                Look the curl result :
                HTTP/1.1 301 Moved Permanently
                Server: nginx/1.14.2
                Date: Mon, 23 Dec 2019 18:14:36 GMT
                Content-Type: text/html
                Content-Length: 185
                Connection: keep-alive
                HTTP/1.1 404 Not Found
                Content-Type: text/html; charset=utf-8
                Content-Length: 146
                X-DNS-Prefetch-Control: off
                X-Frame-Options: SAMEORIGIN
                Strict-Transport-Security: max-age=15552000; includeSubDomains
                X-Download-Options: noopen
                X-Content-Type-Options: nosniff
                X-XSS-Protection: 1; mode=block
                Content-Security-Policy: default-src 'self'
                <!DOCTYPE html>
                <html lang="en">
                <head>
                <meta charset="utf-8">
                <title>Error</title>
                </head>
                <body>
                <pre>Cannot GET /mmirror</pre>
                </body>
                </html>
                I think I have some problems with some "proxy_set_header " rules.
                Best regards
                F E 2 Replies Last reply Reply Quote 0
                • F Offline
                  fbr1969 @fbr1969
                  @fbr1969
                  And yes, Magicmirror is fonctional in direct connection with : http://192.168.10.60:8080
                  • E Offline
                    ember1205 @fbr1969
                    I forgot to say :
                    location /mmirror {
                    It appears that your X-Script-Name IS setting a trailing slash and isn’t inserting / removing mmirror. Shouldn’t that last line be
                         proxy_set_header        X-Script-Name   /mmirror;  # IMPORTANT: path has NO trailing slash
                      sdetweil @ember1205
                      @ember1205 its pretty clear tho
                      Content-Length: 185
                      Content-Length: 146
                      Error
                      Cannot GET /mmirror
                      because that is on the client issuing the curl command, url with no ip address is same as localhost
                      what is this??
                      again this should be server.mydomain
                      if u go to client and do an nslookup domain.com
                      u will get an error
                      ping domain.com will fail
                      • E Offline
                        ember1205 @sdetweil
                        @sdetweil said in MagicMirror behind a NGinx Reverse Proxy:
                        Content-Length: 185
                        Content-Length: 146
                        Error
                        Cannot GET /mmirror
                        what is this??
                        u will get an error
                        He stated that he is masking details of what he’s posting, so it’s definitely something to check.
                        However…
                        The error is delivered from nginx
                        Which means that it isn’t attempting to retrieve the URL from localhost.
                        The missing directive that I mentioned prior is where I believe the issue is… The client IS connecting and requesting /mmirror, but that is not defined on the nginx host. As a result, it’s being processed by the default host configured there which will be on a different back-end server and that server does not have a /mmirror path available to serve. So, 404.
                          sdetweil @ember1205
                          @ember1205 said in MagicMirror behind a NGinx Reverse Proxy:
                          but it is as a server entry in the nginx.conf
                          I have just set one up and see the same…
                          but the proxy doesn’t explicitly ask to pass the uri too
                            @ember1205 so, if u take off the mmirror part of the 1st server and use the / location to proxy pass it works, so you are correct… it passed the uri portion along too…
                            • E Offline
                              ember1205
                              When using a proxy server like this, it functions mostly like a content switch. In other words, you can redirect specific paths to different back-end hosts - this is commonly done when you have different servers holding different kinds of content.
                              When you have a VIP acting as a Content Switch, anything not explicitly defined for a particular path will be handled by the default VIP. In this case, he has not actually defined the /mmirror path, so appending that to his domain will result in the DEFAULT server getting the traffic as opposed to the mirror. That’s why the 404.
                              I believe that the directive I mentioned earlier is all that needs to be defined in order to get the nginx proxy handling that path accordingly…
                              • F Offline
                                fbr1969
                                Re: MagicMirror behind a NGinx Reverse Proxy
                                I watched my Nginx error file and found :
                                2019/12/24 10:20:45 [error] 2341#2341: *1 open() "/var/www/html/socket.io/socket.io.js" failed (2: No such file or directory), client: XX.XXX.XX.XXX, server: mydomain.com, request: "GET /socket.io/socket.io.js HTTP/1.1", host: "mydomain.com", referrer: "https://mydomain.com/mmirror/"```
                                So, I tried to modify my nginx config file.
                                Here’s the final configuration, working fine (don’t forget to change ‘mydomain.com’), and your private IP adress.
                                Magic Mirror will be avaiable by : https://mydomain.com/mmirror :
                                server {
                                    listen      80;
                                    server_name mydomain.com;
                                server {
                                    ssl_certificate /etc/letsencrypt/live/mydomain.com/fullchain.pem; # managed by Certbot
                                    ssl_certificate_key /etc/letsencrypt/live/mydomain.com/privkey.pem; # managed by Certbot
                                    # Access to Magic Mirror
                                    location /mmirror/ {
                                        proxy_pass              http://192.168.10.60:8080/;
                                        #proxy_redirect          http://192.168.10.60:8080 /mmirror;
                                        #proxy_set_header Host $http_host;
                                        #proxy_set_header X-Real-IP $remote_addr;
                                        #proxy_set_header X-Forwarded-For $proxy_add_x_forwarded_for;
                                        #proxy_set_header X-Forwarded-Proto $scheme;
                                        proxy_pass_request_headers on;
                                        proxy_set_header Host $host;
                                        proxy_set_header Upgrade $http_upgrade;
                                        proxy_set_header Connection $http_connection;
                                        # Disable buffering when the nginx proxy gets very resource heavy upon streaming
                                        proxy_buffering off;
                                        location /socket.io {
                                                # Proxy Magi Mirror Websockets traffic
                                                proxy_http_version 1.1;
                                                proxy_set_header Connection "upgrade";
                                                proxy_set_header X-Forwarded-Protocol $scheme;
                                    location / {
                                        root   /var/www/html;
                                        index  index.html ;
                                • E Offline
                                  ember1205 @fbr1969
                                  @fbr1969
                                  A couple of questions about your configuration…
                                  • It seems that you configured ONLY for access to the mirror with a /mmirror path as well - is this accurate? I can’t tell where the ‘default’ VIP might be pointing to.
                                  • It appears that you have to handle the /socket.io path independently of the of /mmirror path, and that leads me to wonder if there is javascript code being returned to the browser that ALSO needs to be rewritten inline?
                                  • F Offline
                                    fbr1969 @ember1205
                                    @ember1205
                                    With my shortcut “mmirror”, I can access directly to the default Magic Mirror page (define in my MM config.js file), at home (LAN) or at work (by Internet).
                                    And effectively, I had needed to handle the /socket.io path independently of the of /mmirror path to correct the error I found I my NGinx error log. And that worked like that.
                                    I’ sorry, but I don’t know how it works exactly…
                                    • E Offline
                                      ember1205 @fbr1969
                                      @ember1205
                                      Thanks for the extra detail - your description increases my suspicion/concern that there is likely a lot of JS content being delivered directly to the browser that is not being otherwise rewritten, hence the need for the additional path for socket.io
                                      On my mirror, with a total of five modules (all default except one), there are twenty-six JS scripts that are delivered to the browser for “local” execution. Fortunately, of them, ONLY the socket.io call has a hard path to the root of the server:
                                      < script type="text/javascript" src="/socket.io/socket.io.js"></script>
                                      Nothing else uses the leading “/” in the path which means they are all relative paths and will properly pass through a reverse proxy for access. Even though the other twenty-five scripts can be downloaded, there’s nothing to say that the content WITHIN them can execute if they make any subsequent calls using hard-coded information that isn’t being rewritten.
                                      Reverse proxy servers are awesome tools, but the configuration has to be ‘perfect’ to ensure everything will work properly now and in the future. And rewriting JS is not always trivial.
