    Can't Install: Segmentation Fault when Installing Fonts
    13 Posts 3 Posters 2.9k Views 3 Watching
      mdub
      I am trying to install MagicMirror on a Raspberry Pi virtual machine. I am using the Raspberry Pi distribution 2019-09-25-rpd-x86-buster.iso running with Oracle VirtualBox on a MacBook Pro running OS X 10.12.6.
      The install fails when npm experiences a segmentation fault when installing fonts.
      Here is the error output:
      We’ll remove from the repository the css/custom.css
      This script apply git update-index --skip-worktree css/custom.css
      rm ‘css/custom.css’
      MagicMirror installation successful!
      magicmirror@2.9.0 install-fonts /home/pi/MagicMirror
      cd fonts && npm install
      Segmentation fault.] \ extract:roboto-fontface: verb lock using /home/pi/.npm/
      npm ERR! code ELIFECYCLE
      npm ERR! errno 139
      npm ERR! magicmirror@2.9.0 install-fonts: cd fonts && npm install
      npm ERR! Exit status 139
      npm ERR!
      npm ERR! Failed at the magicmirror@2.9.0 install-fonts script.
      npm ERR! /home/pi/.npm/_logs/2019-12-27T23_47_49_618Z-debug.log
      npm ERR! errno 139
      npm ERR! magicmirror@2.9.0 postinstall: sh untrack-css.sh && sh installers/postinstall/postinstall.sh && npm run install-fonts
      npm ERR!
      npm ERR! Failed at the magicmirror@2.9.0 postinstall script.
      npm ERR! /home/pi/.npm/_logs/2019-12-27T23_47_49_670Z-debug.log
      I am new to Magic Mirror and I’m not sure how to move past this failure. Any advice that you can offer would be greatly appreciated.
      Thanks!
        sdetweil
        @mdub ok, not sure why the problem… can u try the updated installer…
        see here https://forum.magicmirror.builders/topic/10171/anyone-want-to-try-updated-installer
        this will be in the next version release
        you will need to rename MagicMirror folder to something else
        also I might suggest to rm -rf ~/.npm to clean up the npm folder
          jg3
          I’m having the exact same problem:
          Segmentation fault.] \ extract:roboto-fontface: verb lock using /home/pi/.npm/_locks/staging-0ff2d9730ff2850b.lock for /home/pi/MagicMirror/fonts/node_modules/.stagi
          npm ERR! errno 139
          …and so on.
          I have a fresh new & updated RPI install into an ESXi VM, and I’m following the instructions on https://docs.magicmirror.builders/getting-started/installation.html#manual-installation
          (plus: sudo apt-get -y install npm && sudo npm i -g npm).
          I have tried to remove and re-clone the MagicMirror dist, same effect.
          Here’s a little more from the npm log, in case it is helpful…
          28887 silly postinstall valid-url@1.0.9
          28888 info lifecycle valid-url@1.0.9~postinstall: valid-url@1.0.9
          28889 verbose unlock done using /home/pi/.npm/_locks/staging-f4a655787a5bf4d3.lock for /home/pi/MagicMirror/node_modules/.staging
          28890 silly install runPostinstallTopLevelLifecycles
          28891 silly build magicmirror@2.11.0
          28892 info linkStuff magicmirror@2.11.0
          28893 silly linkStuff magicmirror@2.11.0 has /home/pi as its parent node_modules
          28894 verbose linkBins magicmirror@2.11.0
          28895 verbose linkMans magicmirror@2.11.0
          28896 silly install magicmirror@2.11.0
          28897 info lifecycle magicmirror@2.11.0~install: magicmirror@2.11.0
          28898 verbose lifecycle magicmirror@2.11.0~install: unsafe-perm in lifecycle true
          28899 verbose lifecycle magicmirror@2.11.0~install: PATH: /usr/share/npm/node_modules/npm-lifecycle/node-gyp-bin:/home/pi/MagicMirror/node_modules/.bin:/usr/local/sbi
          n:/usr/local/bin:/usr/sbin:/usr/bin:/sbin:/bin:/usr/local/games:/usr/games
          28900 verbose lifecycle magicmirror@2.11.0~install: CWD: /home/pi/MagicMirror
          28901 silly lifecycle magicmirror@2.11.0~install: Args: [ '-c',
          28901 silly lifecycle   'echo "Installing vendor files ...\n" && cd vendor && npm install --loglevel=error' ]
          28902 silly lifecycle magicmirror@2.11.0~install: Returned: code: 0  signal: null
          28903 silly postinstall magicmirror@2.11.0
          28904 info lifecycle magicmirror@2.11.0~postinstall: magicmirror@2.11.0
          28905 verbose lifecycle magicmirror@2.11.0~postinstall: unsafe-perm in lifecycle true
          28906 verbose lifecycle magicmirror@2.11.0~postinstall: PATH: /usr/share/npm/node_modules/npm-lifecycle/node-gyp-bin:/home/pi/MagicMirror/node_modules/.bin:/usr/local
          /sbin:/usr/local/bin:/usr/sbin:/usr/bin:/sbin:/bin:/usr/local/games:/usr/games
          28907 verbose lifecycle magicmirror@2.11.0~postinstall: CWD: /home/pi/MagicMirror
          28908 silly lifecycle magicmirror@2.11.0~postinstall: Args: [ '-c',
          28908 silly lifecycle   'npm run install-fonts && echo "MagicMirror installation finished successfully! \n"' ]
          28909 silly lifecycle magicmirror@2.11.0~postinstall: Returned: code: 139  signal: null
          28910 info lifecycle magicmirror@2.11.0~postinstall: Failed to exec postinstall script
          28911 verbose stack Error: magicmirror@2.11.0 postinstall: `npm run install-fonts && echo "MagicMirror installation finished successfully!
          28911 verbose stack "`
          28911 verbose stack Exit status 139
          28911 verbose stack     at EventEmitter.<anonymous> (/usr/share/npm/node_modules/npm-lifecycle/index.js:283:16)
          28911 verbose stack     at EventEmitter.emit (events.js:189:13)
          28911 verbose stack     at ChildProcess.<anonymous> (/usr/share/npm/node_modules/npm-lifecycle/lib/spawn.js:55:14)
          28911 verbose stack     at ChildProcess.emit (events.js:189:13)
          28911 verbose stack     at maybeClose (internal/child_process.js:970:16)
          28911 verbose stack     at Process.ChildProcess._handle.onexit (internal/child_process.js:259:5)
          28912 verbose pkgid magicmirror@2.11.0
          28913 verbose cwd /home/pi/MagicMirror
          28914 verbose Linux 4.19.0-8-amd64
          28915 verbose argv "/usr/bin/node" "/usr/bin/npm" "install"
          28916 verbose node v10.15.2
          28917 verbose npm  v5.8.0
          28918 error code ELIFECYCLE
          28919 error errno 139
          28920 error magicmirror@2.11.0 postinstall: `npm run install-fonts && echo "MagicMirror installation finished successfully!
          28920 error "`
          28920 error Exit status 139
          28921 error Failed at the magicmirror@2.11.0 postinstall script.
          28921 error This is probably not a problem with npm. There is likely additional logging output above.
          28922 verbose exit [ 139, true ]
          –jg3
            jg3 @sdetweil
            @sdetweil … I tried using the installer (it looks cool!) but it failed in the same place with apparently the same error.
            I’m new to Magic Mirror and … i guess I’m glad I tried it on a VM before I ordered hardware? … any suggestions on what’s causing this would be obliged.
              sdetweil @jg3
              @jg3 can u show me the ~/install.log
              I suspect its a downlevel npm problem… 6.13.4 is the latest on buster on my pi 3 and 4
              so, u are running and arm (pi) virtual machine, on an intel box (esx)?
                jg3 @sdetweil
                @sdetweil Hi Sam, thanks for the reply.
                I’m running raspberry pi on an emulated x86 processor:
                pi@raspberry:~ $ uname -a
                Linux raspberry 4.19.0-8-amd64 #1 SMP Debian 4.19.98-1 (2020-01-26) x86_64 GNU/Linux
                Below is my ~/install.log. Because the error comes at the very, very end of the install things seem to work OK, but some MM modules will show the same error when they install. Also note that I had installed and updated npm before running the installer.
                pi@raspberry:~ $ more install.log
                install starting  - Sun Apr  5 02:03:49 EDT 2020
                installing on x86_64 processor system
                the os is Distributor ID: Debian Description: Debian GNU/Linux 10 (buster) Release: 10 Codename: buster
                user stopped install on x86_64 hardware
                install starting  - Sun Apr  5 02:10:26 EDT 2020
                Updating packages ...
                Hit:1 http://security.debian.org buster/updates InRelease Hit:2 https://deb.nodesource.com/node_10.x buster InRelease Hit:3 http://archive.ras
                pberrypi.org/debian buster InRelease Hit:4 http://ftp.debian.org/debian buster InRelease Hit:5 http://ftp.debian.org/debian buster-updates InR
                elease Reading package lists...
                apt-get update  completed ok
                apt-get upgrade  started
                apt upgrade result =rc=0 Reading package lists...
                Building dependency tree...
                Reading state information...
                Calculating upgrade...
                0 upgraded, 0 newly installed, 0 to remove and 0 not upgraded.
                Installing helper tools ...
                build-essential is already the newest version (12.6).
                git is already the newest version (1:2.20.1-2+deb10u1).
                unzip is already the newest version (6.0-23+deb10u1).
                wget is already the newest version (1.20.1-1.1).
                wget set to manually installed.
                curl is already the newest version (7.64.0-4+deb10u1).
                Check current Node installation ...
                Node currently installed. Checking version number.
                Minimum Node version: v10.1.0
                Installed Node version: v10.15.2
                No Node.js upgrade necessary.
                Check current NPM installation ...
                NPM currently installed. Checking version number.
                Minimum npm version: V6.0.0
                Installed npm version: V6.14.4
                No npm upgrade necessary.
                Cloning MagicMirror ...
                Cloning MagicMirror Done!
                Installing dependencies ...
                install starting  - Sun Apr  5 02:11:06 EDT 2020
                It seems like MagicMirror is already installed.
                To prevent overwriting, the installer will be aborted.
                Please rename the ~/MagicMirror folder and try again.
                If you want to upgrade your installation run upgrade-script from the ~/MagicMirror/installers directory.
                install starting  - Sun Apr  5 02:11:40 EDT 2020
                pi@raspberry:~ $
                  sdetweil @jg3
                  @jg3 hm… i would erase the ~/.npm folder (rm -rf ~/.npm) and try install again
                    jg3 @sdetweil
                    @sdetweil Because you’d recommended that to the OP I gave that a try but it didn’t make a difference.
                    Like I said, the MM is running now but I’d be a lot more comfortable if I could get to the bottom of this and a couple of other small things.
                    Thank you kindly for the replies.
                      sdetweil @jg3
                      @jg3 k, tell me how you set that up so I can try to recreate…
                      i have virtualbox, and vmware Workstation… no esx around tho
                      I run macOS catalina, Ubuntu 19.04, and Zorin vms and install MM on all of them without problem
                      (VMs under vmware). my vmware host is either windows 10 or Ubuntu Mate 18.04 (dual boot)
                      ah, i see raspian for x86… downloading now
                        sdetweil @jg3
                        @jg3 ok, this is a bug in the installer for the roboto-fontface package
                        if u edit the ~/MagicMirror/fonts/package.json, and change
                         "dependencies": {
                            "roboto-fontface": "^0.8.0"
                        to
                         "dependencies": {
                            "roboto-fontface": "latest"
                        it will work…
                        S J 2 Replies Last reply Reply Quote 1
