    Standard calendar Determine text alignment
    16 Posts 3 Posters 5.9k Views 3 Watching
      sdetweil @Clubjack
      @Clubjack so, when a module dies in the modulename.js file, it will usually kill the screen display.
      so you need to open the developers window (ctrl-shift-i) and look thru the console for any errors reported
      • C Offline
        Clubjack @sdetweil
        @sdetweil oh man. What would i do without You. 🙈
        Found the error… Suddenly the node_helper was not found.
        I get it back with an older Thread from You.
        Thank You for all
          sdetweil @Clubjack
          @Clubjack the next release has a fix so that the node_helper error should never happen anymore
          • C Offline
            Clubjack
            Unfortunately, a new little question. Is it possible to change the color of today’s events in the standard calendar module?
              sdetweil @Clubjack
              @Clubjack looking at the code, it appears there is no distinction between today and any other day in handling the class for the event title . so no…
              it only checks for the config option colored and titleClass
              titleWrapper.innerHTML = this.titleTransform(event.title) + repeatingCountTitle;
              			var titleClass = this.titleClassForUrl(event.url);
              			if (!this.config.colored) {
              				titleWrapper.className = "title bright " + titleClass;
              			} else {
              				titleWrapper.className = "title " + titleClass;
                shiring @Clubjack
                @clubjack
                Can you share the Solution? Thanks
