    Standard calendar Determine text alignment
    16 Posts 3 Posters 7.1k Views 3 Watching
      Clubjack
      Hey.
      Here is the config from the first an second calendar. the others are created same way
                              header: "Test1",
                                      maximumEntries: "7",
                                      timeFormat: "absolute",
                                      urgency: 1,
                                      getRelative: 12,
                                      fullDayEventDateFormat: "DD.MMM",
                                      dateFormat: "DD.MMM HH:mm",
                                                      symbol: "toolbox",
                                                      url: "https://calendar.google.com/calendar/ical/.../basic.ics"   }
                              header: "Test2",
                                      urgency: 1,
                                      getRelative: 12,
                                                      symbol: "calendar-check",
        sdetweil @Clubjack
        @Clubjack said in Standard calendar Determine text alignment:
        and the other positions?
        top_right?
        do you have any custom.css entries?
        C 1 Reply Last reply
          Clubjack @sdetweil
          Oh yes.
          Calendar 4 an 5 are with the same settings, only Position is top_right.
          I have an entry in custom.css, but without the entry it is the same alignment.
           body {
          .MMM-DarkSkyForecast .module-content {
                  width: 550px;
          .calendar .module-content {
                  width: 550px;
            sdetweil @Clubjack
            @Clubjack right, .module-content doesn’t mean anything
            U are lucky most modules don’t support multiple instances like that.
            My ā€˜guess’ is that there is some padding wrap in front of the tables for the calendar.
            I would use the developers window, elements tab, to explore the css tree for each.
            Note that because they are the same module name, one css entry will affect all of them
              Clubjack
              What Do You mean with ā€œdevelopers window, elements Tabā€? Where can i find it?
                Clubjack @sdetweil
                Hey…
                I tried something.
                If one of the displayed event titles (calendar 3) gets longer, then the alignment fits.
                This means that the calendar symbol and the event title align together.
                It would be better if the calendar symbol were always aligned to the left and the event title follows it.
                  sdetweil @Clubjack
                  the developers window is opened with
                  keyboard = ctrl-shift-i (its a toggle, once, its on… next time its off)
                  at startup time = npm start dev
                  note that if you use a windows machine for development and a pi to display, you can ALSO display on your windows box, by going to http://pi_address:port (the config.js has to allow any system to connect so whitelist=[], and address= ā€œā€)
                  and then use the dev window THERE
                    Clubjack @sdetweil
                    Hey…
                    In the meantime I managed to align everything. Via the custom.css.
                    Now I installed the MMM-GoogleTasks module according to the instructions and inserted my API ID.
                    Then I restarted the MM and since then I only have a black screen in a window called electron.
                    I hope I don’t have to set everything up now. My brain is starting to smoke.
                    S S 2 Replies Last reply
                      sdetweil @Clubjack
                      @Clubjack so, when a module dies in the modulename.js file, it will usually kill the screen display.
                      so you need to open the developers window (ctrl-shift-i) and look thru the console for any errors reported
                        Clubjack @sdetweil
                        @sdetweil oh man. What would i do without You. šŸ™ˆ
                        Found the error… Suddenly the node_helper was not found.
                        I get it back with an older Thread from You.
                        Thank You for all
                          sdetweil @Clubjack
                          @Clubjack the next release has a fix so that the node_helper error should never happen anymore
                            Clubjack
                            Unfortunately, a new little question. Is it possible to change the color of today’s events in the standard calendar module?
                              sdetweil @Clubjack
                              @Clubjack looking at the code, it appears there is no distinction between today and any other day in handling the class for the event title . so no…
                              it only checks for the config option colored and titleClass
                              titleWrapper.innerHTML = this.titleTransform(event.title) + repeatingCountTitle;
                              			var titleClass = this.titleClassForUrl(event.url);
                              			if (!this.config.colored) {
                              				titleWrapper.className = "title bright " + titleClass;
                              			} else {
                              				titleWrapper.className = "title " + titleClass;
                                shiring @Clubjack
                                @clubjack
                                Can you share the Solution? Thanks
                                With your input, this post could be even better šŸ’—
