    erro MMM-HASS
    19 Posts 2 Posters 8.0k Views 2 Watching
    • I
      iorifly
      I have the following error when trying to use the MMM-HASS module. MM loads, but keeps all modules with loading status.
      > magicmirror@2.10.0 start /home/pi/MagicMirror
      > ./run-start.sh
      [21:04:03.127] [LOG] Starting MagicMirror: v2.10.0
      [21:04:03.163] [LOG] Loading config ...
      [21:04:03.185] [LOG] Loading module helpers ...
      [21:04:03.191] [LOG] No helper found for module: alert.
      [21:04:03.401] [LOG] Initializing new module helper ...
      [21:04:03.405] [LOG] Module helper loaded: updatenotification
      [21:04:03.408] [LOG] No helper found for module: clock.
      [21:04:04.630] [LOG] Initializing new module helper ...
      [21:04:04.633] [LOG] Module helper loaded: MMM-Screencast
      [21:04:06.010] [LOG] Initializing new module helper ...
      [21:04:06.013] [LOG] Module helper loaded: calendar
      [21:04:06.016] [LOG] No helper found for module: compliments.
      [21:04:07.345] [LOG] Initializing new module helper ...
      [21:04:07.347] [LOG] Module helper loaded: MMM-DarkSkyForecast
      [21:04:07.457] [LOG] Initializing new module helper ...
      [21:04:07.460] [LOG] Module helper loaded: newsfeed
      [21:04:07.548] [LOG] Initializing new module helper ...
      [21:04:07.553] [LOG] Module helper loaded: MMM-HASS
      [21:04:07.557] [LOG] All module helpers loaded.
      [21:04:07.563] [LOG] Starting server on port 8080 ...
      [21:04:07.688] [LOG] Server started ...
      [21:04:07.695] [LOG] Connecting socket for: updatenotification
      [21:04:07.703] [LOG] Connecting socket for: MMM-Screencast
      [21:04:07.710] [LOG] Connecting socket for: calendar
      [21:04:07.716] [LOG] Starting node helper for: calendar
      [21:04:07.721] [LOG] Connecting socket for: MMM-DarkSkyForecast
      [21:04:07.724] [LOG] ====================== Starting node_helper for module [MMM-DarkSkyForecast]
      [21:04:07.729] [LOG] Connecting socket for: newsfeed
      [21:04:07.734] [LOG] Starting module: newsfeed
      [21:04:07.740] [LOG] Connecting socket for: MMM-HASS
      [21:04:07.745] [LOG] Sockets connected & modules started ...
      [21:04:07.748] [LOG]
      Ready to go! Please point your browser to: http://localhost:8080
      Starting chromium browser now, have patience, it takes a minute
       --disable-quic --enable-tcp-fast-open --ppapi-flash-path=/usr/lib/chromium-browser/libpepflashplayer.so --ppapi-flash-args=enable_stagevideo_auto=0 --ppapi-flash-version=
      events.js:174
            throw er; // Unhandled 'error' event
      Error [ERR_STREAM_DESTROYED]: Cannot call write after a stream was destroyed
          at doWrite (_stream_writable.js:411:19)
          at writeOrBuffer (_stream_writable.js:399:5)
          at Socket.Writable.write (_stream_writable.js:299:11)
          at Console.con.(anonymous function) [as log] (/home/pi/MagicMirror/node_modules/console-stamp/main.js:150:46)
          at process. (/home/pi/MagicMirror/js/app.js:40:10)
          at process.emit (events.js:198:13)
          at process._fatalException (internal/bootstrap/node.js:497:27)
        sdetweil @iorifly
        @iorifly get it this way
        cd ~/MagicMirror
        curl -sL https://raw.githubusercontent.com/sdetweil/MagicMirror_scripts/master/run-start.sh >run-start.sh
          sdetweil @iorifly
          @iorifly I will look at this tomorrow. Send me your config via text message
          I 1 Reply Last reply
          • I
            iorifly @sdetweil
            Much! Thanks so much for helping me out! I do not know what else to do. I will send everything here to you.
            by message is not going.
            /* Magic Mirror Config Sample
             * MIT Licensed.
            var config = {
                port: 8080,
                language: "pt",
                timeFormat: 24,
                units: "metric",
                             // false, default for all  NON-armv6l devices
                        module: "alert",
                        module: "updatenotification",
                        position: "top_bar"
                        module: "clock",
                        position: "top_left"
                        header: "Feriados",
                                    symbol: "calendar-check",
                                    url: "https://www.calendarlabs.com/ical-calendar/ics/37/Brazil_Holidays.ics"                    }
                        module: "compliments",
                        position: "lower_third"
                                   module: "MMM-DarkSkyForecast",
                                   header: "Tempo em Duque de Caxias",
                                   classes: "default everyone",
                                   disabled: false,
                                     apikey: "****",
                                     latitude: "-22.787860",
                                     longitude: "-43.303140",
                                     iconset: "4c",
                                     units: "si",
                                     concise: false,
                                     forecastLayout: "table"
                            module: 'MMM-Screencast',
                            position: 'middle_center', // This position is for a hidden <div /> and not the screencast window
                                position: 'center',
                                height: 300,
                                width: 500,
                                module: "newsfeed",
                                position: "bottom_bar",
                                    feeds: [
                                            title: "Noticias R7",
                                            url: "https://noticias.r7.com/rio-de-janeiro/feed.xml"
                                    showSourceTitle: true,
                                    showPublishDate: true,
                                    broadcastNewsFeeds: true,
                                    broadcastNewsUpdates: true
                            module: "MMM-HASS",
                            position: "middle_center",
                                    host: "192.168.1.158",
                                    port: "8123",
                                    apipassword: "jeure3027",
                                    hassiotoken: false,
                                    https: false,
                                    devices: [
                                    { deviceLabel: "Exterior",
                                            deviceReadings: [
                                            { sensor: "sensor.disk_free", icon: "wi wi-thermometer", suffix: "%"}
              sdetweil @iorifly
              @iorifly I can recreate the failure, but if I remove the MMM-HASS module, it doesn’t fail…
              debugging, but not sure yet…
              if I run serverOnly mode and and access the system from a browser on another system, that browser doesn’t report any unexpected errors…
              pi0, raspian jessie,
              node -v v10.17.0
              npm -v 6.11.3
              MM 2.10.0
              chromium-browser --version
              Chromium 56.0.2924.84 Built on Ubuntu 14.04, running on Raspbian 8.0
              • I
                iorifly @sdetweil
                @sdetweil said in erro MMM-HASS:
                When I remove HASS it also works.
                But I did not understand. You think there’s no way. Still debugging?
                  sdetweil @iorifly
                  @iorifly yes, not home now. Will try to spend some time tomorrow
                  • I
                    iorifly
                    I look forward to something tomorrow. Thank you for not leaving me!
                    • I
                      iorifly
                      My exit when I request browser version
                      pi@raspberrypi:~/MagicMirror $ chromium-browser --version
                      Chromium 74.0.3729.157 Built on Raspbian , running on Raspbian 10
                        sdetweil
                        @iorifly
                        ok, i have found the problem… all my fault
                        edit ~/MagicMirror/run-start.sh
                        	#exec 3< &-           #  edit this line and comment out with leading #
                        	tee < &3 &             #  add this line  after the line above, no space between < and &3, forum is real trouble with <
                        • I
                          iorifly
                          guy!!
                          I’m not home at the moment BUT HOW HAPPY I am. Will I be able to use the module? I will return as soon as possible to you. THANK YOU FOR HELPING ME AND NOT ABANDONING THE BOAT.
                            sdetweil @iorifly
                            @iorifly it is not a module problem, but a script problem…
                            the module runs, but I don’t know how it works, so that will be next work for you
                            • I
                              iorifly
                              I understood. I will try to do it later! You don’t know how happy I am !!!
                              I can get MMM-hass + spotify to work and remove the update notice from the screen I will buy the glass.
                              • I
                                iorifly @sdetweil
                                Regardless of how I put it, I get an error.
                                > ./run-start.sh
                                ./run-start.sh: linha 68: 3: Descritor de arquivo inválido
                                ./run-start.sh: linha 38: 3: Descritor de arquivo inválido
                                Abrindo em uma sessão de navegador existente.
                                • I
                                  iorifly
                                  the forum will not let me write … lol
                                  https://imgur.com/LoCMbrA
                                    sdetweil @iorifly
                                    cd ~/MagicMirror
                                    • I
                                      iorifly
                                      Wait a while. I am updating with the command you directed me.
                                        sdetweil @iorifly
                                        @iorifly np… either way
                                        • I
                                          iorifly
                                          The modules are loading. I have no update msg. Now my fight is with MMM-HASS setup and Home assistant.
                                             Thanks!! I haven’t tested the spotify model yet. But I’m happy with what I have for now.
                                          You were perfect !!!
                                            sdetweil @iorifly
                                            @iorifly said in erro MMM-HASS:
                                            it won’t fail for the run-start script problem… can’t guarantee anything beyond that
