    erro MMM-HASS
    19 Posts 2 Posters 7.7k Views 2 Watching
      sdetweil @iorifly
      @iorifly yes, not home now. Will try to spend some time tomorrow
      • I Offline
        iorifly
        I look forward to something tomorrow. Thank you for not leaving me!
        • I Offline
          iorifly
          My exit when I request browser version
          pi@raspberrypi:~/MagicMirror $ chromium-browser --version
           --disable-quic --enable-tcp-fast-open --ppapi-flash-path=/usr/lib/chromium-browser/libpepflashplayer.so --ppapi-flash-args=enable_stagevideo_auto=0 --ppapi-flash-version=
          Chromium 74.0.3729.157 Built on Raspbian , running on Raspbian 10
            @iorifly
            ok, i have found the problem… all my fault
            edit ~/MagicMirror/run-start.sh
            	#exec 3< &-           #  edit this line and comment out with leading #
            	tee < &3 &             #  add this line  after the line above, no space between < and &3, forum is real trouble with <
            • I Offline
              iorifly
              guy!!
              I’m not home at the moment BUT HOW HAPPY I am. Will I be able to use the module? I will return as soon as possible to you. THANK YOU FOR HELPING ME AND NOT ABANDONING THE BOAT.
                sdetweil @iorifly
                @iorifly it is not a module problem, but a script problem…
                the module runs, but I don’t know how it works, so that will be next work for you
                • I Offline
                  iorifly
                  @sdetweil said in erro MMM-HASS:
                  I understood. I will try to do it later! You don’t know how happy I am !!!
                  I can get MMM-hass + spotify to work and remove the update notice from the screen I will buy the glass.
                  • I Offline
                    iorifly @sdetweil
                    Regardless of how I put it, I get an error.
                    > magicmirror@2.10.0 start /home/pi/MagicMirror
                    > ./run-start.sh
                    ./run-start.sh: linha 68: 3: Descritor de arquivo inválido
                    ./run-start.sh: linha 38: 3: Descritor de arquivo inválido
                    Starting chromium browser now, have patience, it takes a minute
                    Abrindo em uma sessão de navegador existente.
                    • I Offline
                      iorifly
                      the forum will not let me write … lol
                      https://imgur.com/LoCMbrA
                        sdetweil @iorifly
                        @iorifly get it this way
                        curl -sL https://raw.githubusercontent.com/sdetweil/MagicMirror_scripts/master/run-start.sh >run-start.sh
                        • I Offline
                          iorifly
                          Wait a while. I am updating with the command you directed me.
                            sdetweil @iorifly
                            @iorifly np… either way
                            • I Offline
                              iorifly
                              The modules are loading. I have no update msg. Now my fight is with MMM-HASS setup and Home assistant.
                                 Thanks!! I haven’t tested the spotify model yet. But I’m happy with what I have for now.
                              You were perfect !!!
                                sdetweil @iorifly
                                @iorifly said in erro MMM-HASS:
                                it won’t fail for the run-start script problem… can’t guarantee anything beyond that
