    erro MMM-HASS
    19 Posts 2 Posters 7.7k Views 2 Watching
      sdetweil @iorifly
      @iorifly I will look at this tomorrow. Send me your config via text message
      • I Offline
        iorifly @sdetweil
        Much! Thanks so much for helping me out! I do not know what else to do. I will send everything here to you.
        by message is not going.
        /* Magic Mirror Config Sample
         * MIT Licensed.
        var config = {
            port: 8080,
            language: "pt",
            timeFormat: 24,
            units: "metric",
                         // false, default for all  NON-armv6l devices
                    module: "alert",
                    module: "updatenotification",
                    position: "top_bar"
                    module: "clock",
                    position: "top_left"
                    header: "Feriados",
                                symbol: "calendar-check",
                                url: "https://www.calendarlabs.com/ical-calendar/ics/37/Brazil_Holidays.ics"                    }
                    module: "compliments",
                    position: "lower_third"
                               module: "MMM-DarkSkyForecast",
                               header: "Tempo em Duque de Caxias",
                               classes: "default everyone",
                               disabled: false,
                                 apikey: "****",
                                 latitude: "-22.787860",
                                 longitude: "-43.303140",
                                 iconset: "4c",
                                 units: "si",
                                 concise: false,
                                 forecastLayout: "table"
                        module: 'MMM-Screencast',
                        position: 'middle_center', // This position is for a hidden <div /> and not the screencast window
                            position: 'center',
                            height: 300,
                            width: 500,
                            module: "newsfeed",
                            position: "bottom_bar",
                                feeds: [
                                        title: "Noticias R7",
                                        url: "https://noticias.r7.com/rio-de-janeiro/feed.xml"
                                showSourceTitle: true,
                                showPublishDate: true,
                                broadcastNewsFeeds: true,
                                broadcastNewsUpdates: true
                        module: "MMM-HASS",
                        position: "middle_center",
                                host: "192.168.1.158",
                                port: "8123",
                                apipassword: "jeure3027",
                                hassiotoken: false,
                                https: false,
                                devices: [
                                { deviceLabel: "Exterior",
                                        deviceReadings: [
                                        { sensor: "sensor.disk_free", icon: "wi wi-thermometer", suffix: "%"}
          sdetweil @iorifly
          @iorifly I can recreate the failure, but if I remove the MMM-HASS module, it doesn’t fail…
          debugging, but not sure yet…
          if I run serverOnly mode and and access the system from a browser on another system, that browser doesn’t report any unexpected errors…
          pi0, raspian jessie,
          node -v v10.17.0
          npm -v 6.11.3
          MM 2.10.0
          chromium-browser --version
          Chromium 56.0.2924.84 Built on Ubuntu 14.04, running on Raspbian 8.0
          • I Offline
            iorifly @sdetweil
            @sdetweil said in erro MMM-HASS:
            When I remove HASS it also works.
            But I did not understand. You think there’s no way. Still debugging?
              sdetweil @iorifly
              @iorifly yes, not home now. Will try to spend some time tomorrow
              • I Offline
                iorifly
                I look forward to something tomorrow. Thank you for not leaving me!
                • I Offline
                  iorifly
                  My exit when I request browser version
                  pi@raspberrypi:~/MagicMirror $ chromium-browser --version
                   --disable-quic --enable-tcp-fast-open --ppapi-flash-path=/usr/lib/chromium-browser/libpepflashplayer.so --ppapi-flash-args=enable_stagevideo_auto=0 --ppapi-flash-version=
                  Chromium 74.0.3729.157 Built on Raspbian , running on Raspbian 10
                    @iorifly
                    ok, i have found the problem… all my fault
                    edit ~/MagicMirror/run-start.sh
                    	#exec 3< &-           #  edit this line and comment out with leading #
                    	tee < &3 &             #  add this line  after the line above, no space between < and &3, forum is real trouble with <
                    • I Offline
                      iorifly
                      guy!!
                      I’m not home at the moment BUT HOW HAPPY I am. Will I be able to use the module? I will return as soon as possible to you. THANK YOU FOR HELPING ME AND NOT ABANDONING THE BOAT.
                        sdetweil @iorifly
                        @iorifly it is not a module problem, but a script problem…
                        the module runs, but I don’t know how it works, so that will be next work for you
                        • I Offline
                          iorifly
                          I understood. I will try to do it later! You don’t know how happy I am !!!
                          I can get MMM-hass + spotify to work and remove the update notice from the screen I will buy the glass.
                          • I Offline
                            iorifly @sdetweil
                            Regardless of how I put it, I get an error.
                            > magicmirror@2.10.0 start /home/pi/MagicMirror
                            > ./run-start.sh
                            ./run-start.sh: linha 68: 3: Descritor de arquivo inválido
                            ./run-start.sh: linha 38: 3: Descritor de arquivo inválido
                            Starting chromium browser now, have patience, it takes a minute
                            Abrindo em uma sessão de navegador existente.
                            • I Offline
                              iorifly
                              the forum will not let me write … lol
                              https://imgur.com/LoCMbrA
                                sdetweil @iorifly
                                @iorifly get it this way
                                curl -sL https://raw.githubusercontent.com/sdetweil/MagicMirror_scripts/master/run-start.sh >run-start.sh
                                • I Offline
                                  iorifly
                                  Wait a while. I am updating with the command you directed me.
                                    sdetweil @iorifly
                                    @iorifly np… either way
                                    • I Offline
                                      iorifly
                                      The modules are loading. I have no update msg. Now my fight is with MMM-HASS setup and Home assistant.
                                         Thanks!! I haven’t tested the spotify model yet. But I’m happy with what I have for now.
                                      You were perfect !!!
                                        sdetweil @iorifly
                                        @iorifly said in erro MMM-HASS:
                                        it won’t fail for the run-start script problem… can’t guarantee anything beyond that
