    erro MMM-HASS
    19 Posts 2 Posters 8.0k Views 2 Watching
    • I
      iorifly
      I look forward to something tomorrow. Thank you for not leaving me!
      • I
        iorifly
        My exit when I request browser version
        pi@raspberrypi:~/MagicMirror $ chromium-browser --version
         --disable-quic --enable-tcp-fast-open --ppapi-flash-path=/usr/lib/chromium-browser/libpepflashplayer.so --ppapi-flash-args=enable_stagevideo_auto=0 --ppapi-flash-version=
        Chromium 74.0.3729.157 Built on Raspbian , running on Raspbian 10
          @iorifly
          ok, i have found the problem… all my fault
          edit ~/MagicMirror/run-start.sh
          	#exec 3< &-           #  edit this line and comment out with leading #
          	tee < &3 &             #  add this line  after the line above, no space between < and &3, forum is real trouble with <
          I 1 Reply Last reply
          • I
            iorifly
            guy!!
            I’m not home at the moment BUT HOW HAPPY I am. Will I be able to use the module? I will return as soon as possible to you. THANK YOU FOR HELPING ME AND NOT ABANDONING THE BOAT.
              sdetweil @iorifly
              @iorifly it is not a module problem, but a script problem…
              the module runs, but I don’t know how it works, so that will be next work for you
              • I
                iorifly
                @sdetweil said in erro MMM-HASS:
                I understood. I will try to do it later! You don’t know how happy I am !!!
                I can get MMM-hass + spotify to work and remove the update notice from the screen I will buy the glass.
                • I
                  iorifly @sdetweil
                  Regardless of how I put it, I get an error.
                  > magicmirror@2.10.0 start /home/pi/MagicMirror
                  > ./run-start.sh
                  ./run-start.sh: linha 68: 3: Descritor de arquivo inválido
                  ./run-start.sh: linha 38: 3: Descritor de arquivo inválido
                  Starting chromium browser now, have patience, it takes a minute
                  Abrindo em uma sessão de navegador existente.
                  • I
                    iorifly
                    the forum will not let me write … lol
                    https://imgur.com/LoCMbrA
                      sdetweil @iorifly
                      @iorifly get it this way
                      curl -sL https://raw.githubusercontent.com/sdetweil/MagicMirror_scripts/master/run-start.sh >run-start.sh
                      • I
                        iorifly
                        Wait a while. I am updating with the command you directed me.
                          sdetweil @iorifly
                          @iorifly np… either way
                          • I
                            iorifly
                            The modules are loading. I have no update msg. Now my fight is with MMM-HASS setup and Home assistant.
                               Thanks!! I haven’t tested the spotify model yet. But I’m happy with what I have for now.
                            You were perfect !!!
                              sdetweil @iorifly
                              @iorifly said in erro MMM-HASS:
                              it won’t fail for the run-start script problem… can’t guarantee anything beyond that
