    erro MMM-HASS
    19 Posts 2 Posters 6.6k Views 2 Watching
      sdetweil @iorifly
      @iorifly it is not a module problem, but a script problem…
      the module runs, but I don’t know how it works, so that will be next work for you
      • I Offline
        iorifly
        @sdetweil said in erro MMM-HASS:
        I understood. I will try to do it later! You don’t know how happy I am !!!
        I can get MMM-hass + spotify to work and remove the update notice from the screen I will buy the glass.
        • I Offline
          iorifly @sdetweil
          #exec 3< &- # edit this line and comment out with leading #
          tee < &3 & # add this line after the line above, no space between < and &3, forum is real trouble with <
          Regardless of how I put it, I get an error.
          > magicmirror@2.10.0 start /home/pi/MagicMirror
          > ./run-start.sh
          ./run-start.sh: linha 68: 3: Descritor de arquivo inválido
          ./run-start.sh: linha 38: 3: Descritor de arquivo inválido
          Starting chromium browser now, have patience, it takes a minute
           --disable-quic --enable-tcp-fast-open --ppapi-flash-path=/usr/lib/chromium-browser/libpepflashplayer.so --ppapi-flash-args=enable_stagevideo_auto=0 --ppapi-flash-version=
          Abrindo em uma sessão de navegador existente.
          • I Offline
            iorifly
            the forum will not let me write … lol
            https://imgur.com/LoCMbrA
              sdetweil @iorifly
              @iorifly get it this way
              cd ~/MagicMirror
              curl -sL https://raw.githubusercontent.com/sdetweil/MagicMirror_scripts/master/run-start.sh >run-start.sh
              • I Offline
                iorifly
                Wait a while. I am updating with the command you directed me.
                  sdetweil @iorifly
                  @iorifly np… either way
                  • I Offline
                    iorifly
                    The modules are loading. I have no update msg. Now my fight is with MMM-HASS setup and Home assistant.
                       Thanks!! I haven’t tested the spotify model yet. But I’m happy with what I have for now.
                    You were perfect !!!
                      sdetweil @iorifly
                      @iorifly said in erro MMM-HASS:
                      it won’t fail for the run-start script problem… can’t guarantee anything beyond that
