    Issues after update - restoring?
    13 Posts 2 Posters 4.3k Views 2 Watching
    • N
      nakulbende
      Hello,
      I tried @sdetweil 's script to update my MagicMirror. Priopr to that, there were some slowdowns in using ssh, but vnc was always working perfectly. After the update, ssh brings up the login request, but nothing happens after that - no bash appears. Also, is fine, but very slow. If I start MagicMirror using npm start, it shuts off after a couple of hours. It is also not starting the magicmirror service on boot.
      My question is: can I just use @sdetweil 's installation script on a fresh raspberry pi install, copy my model folder and config.jss to restore my module installation and all…
        sdetweil @nakulbende
        @nakulbende can u show me the
        ~/MagicMirror/installers/upgrade.log
        the MM app upgrade should have no effect on ssh/vnc, as we are only updating in the MM folder and below
        as for copying over… yes, but, for each module that has a package.json file, you should
        erase the node_modules folder in the module folder and then npm install again
        I would reun the pm2 part of install, using the separate script
        bash -c "$(curl -sL https://raw.githubusercontent.com/sdetweil/MagicMirror_scripts/master/fixuppm2.sh)"
        I would like to see the output of pm2 logs --lines=100 before running that script
        • N
          nakulbende
          Here is the log from npm start:
          > magicmirror@2.10.1 start /home/pi/MagicMirror
          > ./run-start.sh
          [10:59:40.101] [LOG]    Starting MagicMirror: v2.10.1
          [10:59:40.117] [LOG]    Loading config ...
          [10:59:40.153] [LOG]    Loading module helpers ...
          [10:59:40.156] [LOG]    No helper found for module: alert.
          [10:59:40.329] [LOG]    Initializing new module helper ...
          [10:59:40.332] [LOG]    Module helper loaded: updatenotification
          [10:59:40.339] [LOG]    Initializing new module helper ...
          [10:59:40.340] [LOG]    Module helper loaded: MMM-BurnIn
          [10:59:40.353] [LOG]    Initializing new module helper ...
          [10:59:40.359] [LOG]    Module helper loaded: MMM-WatchDog
          [10:59:40.559] [LOG]    Initializing new module helper ...
          [10:59:40.561] [LOG]    Module helper loaded: MMM-Remote-Control
          [10:59:40.562] [LOG]    No helper found for module: compliments.
          [10:59:40.564] [LOG]    No helper found for module: clock.
          [10:59:40.565] [LOG]    No helper found for module: calendar_monthly.
          [10:59:41.778] [LOG]    Initializing new module helper ...
          [10:59:41.780] [LOG]    Module helper loaded: calendar
          [10:59:46.210] [LOG]    Initializing new module helper ...
          [10:59:46.211] [LOG]    Module helper loaded: MMM-Buller
          [10:59:47.302] [LOG]    Initializing new module helper ...
          [10:59:47.303] [LOG]    Module helper loaded: MMM-DarkSkyForecast
          [10:59:47.305] [LOG]    No helper found for module: MMM-DailyPokemon.
          [10:59:47.320] [LOG]    Initializing new module helper ...
          [10:59:47.322] [LOG]    Module helper loaded: MMM-fitbit
          [10:59:47.388] [LOG]    Initializing new module helper ...
          [10:59:47.389] [LOG]    Module helper loaded: MMM-GoogleFit
          [10:59:47.396] [LOG]    No helper found for module: MMM-MBTA.
          [10:59:47.398] [LOG]    No helper found for module: MMM-MBTA1.
          [10:59:48.306] [LOG]    Initializing new module helper ...
          [10:59:48.307] [LOG]    Module helper loaded: MMM-MyCommute
          [10:59:48.311] [LOG]    Initializing new module helper ...
          [10:59:48.313] [LOG]    Module helper loaded: DailyXKCD
          [10:59:48.314] [LOG]    No helper found for module: MMM-pihole-stats.
          [10:59:48.315] [LOG]    All module helpers loaded.
          [10:59:48.322] [LOG]    Starting server on port 8080 ...
          [10:59:48.362] [LOG]    Server started ...
          [10:59:48.366] [LOG]    Connecting socket for: updatenotification
          [10:59:48.368] [LOG]    Connecting socket for: MMM-BurnIn
          [10:59:48.371] [LOG]    Connecting socket for: MMM-WatchDog
          [10:59:48.376] [LOG]    Starting module helper: MMM-WatchDog
          [10:59:48.378] [LOG]    Connecting socket for: MMM-Remote-Control
          [10:59:48.380] [LOG]    Starting node helper for: MMM-Remote-Control
          [10:59:48.444] [LOG]    Connecting socket for: calendar
          [10:59:48.446] [LOG]    Starting node helper for: calendar
          [10:59:48.448] [LOG]    Connecting socket for: MMM-Buller
          [10:59:48.450] [LOG]    Connecting socket for: MMM-DarkSkyForecast
          [10:59:48.451] [LOG]    ====================== Starting node_helper for module [MMM-DarkSkyForecast]
          [10:59:48.452] [LOG]    Connecting socket for: MMM-fitbit
          [10:59:48.453] [LOG]    Starting module helper: MMM-fitbit
          [10:59:48.455] [LOG]    Connecting socket for: MMM-GoogleFit
          [10:59:48.456] [LOG]    MMM-GoogleFit helper started...
          [10:59:48.459] [LOG]    Connecting socket for: MMM-MyCommute
          [10:59:48.461] [LOG]    ====================== Starting node_helper for module [MMM-MyCommute]
          [10:59:48.463] [LOG]    Connecting socket for: DailyXKCD
          [10:59:48.465] [LOG]    Starting node helper: DailyXKCD
          [10:59:48.466] [LOG]    Sockets connected & modules started ...
          [10:59:48.695] [LOG]    Launching application.
          [10:59:55.989] [LOG]    WatchDog started. Maximum timeout: 25s.
          [10:59:56.551] [LOG]    Create new calendar fetcher for url: http://www.calendarlabs.com/ical-calendar/ics/76/US_Holidays.ics - Interval: 300000
          [10:59:56.748] [LOG]    Create new calendar fetcher for url: https://calendar.google.com/calendar/ical/kiij30c31pmgimj2fhja5dejh0%40group.calendar.google.com/private-9db55d67edd0ff1ebecddbb28201bb01/basic.ics - Interval: 300000
          [10:59:56.939] [LOG]    Set credential request recieved.
          [10:59:56.945] [LOG]    { client_id: 'XXXXXX',
            client_secret: 'XXXXXXXX' }
          [10:59:56.968] [LOG]    Whoops! There was an uncaught exception...
          [10:59:56.969] [ERROR]  TypeError: PythonShell.run is not a function
              at Class.setCreds (/home/pi/MagicMirror/modules/MMM-fitbit/node_helper.js:32:15)
              at Class.socketNotificationReceived (/home/pi/MagicMirror/modules/MMM-fitbit/node_helper.js:18:9)
              at Socket.<anonymous> (/home/pi/MagicMirror/js/node_helper.js:113:11)
              at Socket.emit (events.js:182:13)
              at /home/pi/MagicMirror/node_modules/socket.io/lib/socket.js:528:12
              at process._tickCallback (internal/process/next_tick.js:61:11)
          [10:59:56.974] [LOG]    MagicMirror will not quit, but it might be a good idea to check why this happened. Maybe no internet connection?
          [10:59:56.977] [LOG]    If you think this really is an issue, please open an issue on GitHub: https://github.com/MichMich/MagicMirror/issues
          [10:59:57.067] [LOG]    Initial run request recieved.
          [10:59:57.078] [LOG]    Running getData.py
          [10:59:57.092] [LOG]    Whoops! There was an uncaught exception...
          [10:59:57.097] [ERROR]  TypeError: PythonShell is not a constructor
              at Class.getData (/home/pi/MagicMirror/modules/MMM-fitbit/node_helper.js:43:25)
              at Class.socketNotificationReceived (/home/pi/MagicMirror/modules/MMM-fitbit/node_helper.js:22:9)
          [10:59:57.104] [LOG]    MagicMirror will not quit, but it might be a good idea to check why this happened. Maybe no internet connection?
          [10:59:57.106] [LOG]    If you think this really is an issue, please open an issue on GitHub: https://github.com/MichMich/MagicMirror/issues
          [10:59:57.590] [LOG]    Notification: GET_COMIC Payload: [object Object]
          [10:59:59.415] [LOG]    Task lists:
          [10:59:59.421] [LOG]    To read (MDMxODA0MzYxMjU2NTQyODg2NDg6MDow)
          [10:59:59.423] [LOG]    Ideas (MDMxODA0MzYxMjU2NTQyODg2NDg6NDQ5MzE4MjI0NjMwNDQzNDow)
          [10:59:59.427] [LOG]    Life (MDMxODA0MzYxMjU2NTQyODg2NDg6MTE4NzY4MDk1NTow)
          [10:59:59.436] [LOG]    Random thoughts (MDMxODA0MzYxMjU2NTQyODg2NDg6NDkzOTQyODczOjA)
          [10:59:59.443] [LOG]    HomeToDo (dXA5MVM4bGpmTmJHZnZmVg)
          [11:01:10.537] [LOG]    Whoops! There was an uncaught exception...
          [11:01:10.539] [ERROR]  TypeError: Cannot read property 'startOnMonday' of undefined
              at Class.getStats (/home/pi/MagicMirror/modules/MMM-GoogleFit/node_helper.js:134:22)
              at Request._callback (/home/pi/MagicMirror/modules/MMM-GoogleFit/node_helper.js:98:14)
              at Request.self.callback (/home/pi/MagicMirror/node_modules/request/request.js:185:22)
              at Request.emit (events.js:182:13)
              at Request.<anonymous> (/home/pi/MagicMirror/node_modules/request/request.js:1161:10)
              at IncomingMessage.<anonymous> (/home/pi/MagicMirror/node_modules/request/request.js:1083:12)
              at Object.onceWrapper (events.js:273:13)
              at IncomingMessage.emit (events.js:187:15)
              at endReadableNT (_stream_readable.js:1090:12)
          [11:01:10.544] [LOG]    MagicMirror will not quit, but it might be a good idea to check why this happened. Maybe no internet connection?
          [11:01:10.545] [LOG]    If you think this really is an issue, please open an issue on GitHub: https://github.com/MichMich/MagicMirror/issues
            @nakulbende said in Issues after update - restoring?:
            some error with the fitbit module…
            • N
              nakulbende @sdetweil
              Upgrade started - Sun Jan 19 15:52:57 EST 2020
              system is Linux magicmirror 4.19.75-v7+ #1270 SMP Tue Sep 24 18:45:11 BST 2019 armv7l GNU/Linux
              the os is Distributor ID: Raspbian Description: Raspbian GNU/Linux 10 (buster) Release: 10 Codename: buster
              user requested to apply changes
              doing test run = false
              saving custom.css
              remote name = origin
              upgrading from version 2.9.0 to 2.10.1
              fetching latest revisions
              git fetch rc=0
              current branch = master
              On branch master
              Your branch is behind 'origin/master' by 2836 commits, and can be fast-forwarded.
                (use "git pull" to update your local branch)
              Changes to be committed:
                (use "git reset HEAD <file>..." to unstage)
              	deleted:    css/custom.css
              Changes not staged for commit:
                (use "git add <file>..." to update what will be committed)
                (use "git checkout -- <file>..." to discard changes in working directory)
              	modified:   package.json
              Untracked files:
                (use "git add <file>..." to include in what will be committed)
              	core
              	css/save_custom.css
              there are 1 local files that are different than the master repo
                 package.json
              save/restore files selection = y
              Saved working directory and index state WIP on master: 500147e Merge pull request #1776 from MichMich/develop
              test merge result rc='' , if empty, no conflicts
              executing merge, apply specified
              merge result rc= 0
               Updating 500147e..5bf90ae Fast-forward  .gitignore
                  6 -  .snyk
                 14 -  .travis.yml
                  8 +-  CHANGELOG.md
                 33 +-  README.md
                210 +-  config/config.js.sample
                  7 +-  css/custom.css
                 14 -  installers/dumpactivemodules.js
                 15 +  installers/fixuppm2.sh
                183 +  installers/raspberry.sh
                560 ++-  installers/screensaveroff.sh
                101 +  installers/upgrade-script.sh
                361 ++  js/app.js
                  6 +  js/main.js
                 17 +-  .../node_helper/index.js => js/node_helper.js
                  2 +-  js/server.js
                  2 +-  modules/default/calendar/calendar.js
                  1 +  modules/default/calendar/calendarfetcher.js
                  7 +-  modules/default/calendar/debug.js
                  4 +-  modules/default/compliments/compliments.js
                 39 +-  modules/default/weatherforecast/weatherforecast.js
                  4 +-  package-lock.json
               4187 +++++++++++---------  package.json
                 17 +-  run-start.sh
                 64 +-  tests/e2e/modules/weather_spec.js
                138 +-  tests/e2e/vendor_spec.js
                  5 +-  untrack-css.sh
                  2 +-  vendor/package-lock.json
                  2 +-  28 files changed, 3652 insertions(+), 2357 deletions(-)  delete mode 100644 .snyk  delete mode 100644 css/custom.css
              create mode 100644 installers/dumpactivemodules.js
              create mode 100755 installers/fixuppm2.sh
              mode change 100644 => 100755 installers/raspberry.sh
              create mode 100755 installers/screensaveroff.sh
              create mode 100755 installers/upgrade-script.sh  rename modules/node_modules/node_helper/index.js => js/node_helper.js (98%)
              mode change 100644 => 100755 run-start.sh
              processor architecture is armv7l
              updating MagicMirror runtime, please wait
              > console-stamp@0.2.9 postinstall /home/pi/MagicMirror/node_modules/console-stamp
              > node ./msg.js
              Attention
                  Console-stamp version 3.0.0 Release Candidate is out. Install by using the tag '@next'. NB: Breaking changes.
                  For more details goto: https://www.npmjs.com/package/console-stamp/v/next
              > magicmirror@2.10.1 install /home/pi/MagicMirror
              > cd vendor && npm install
              npm WARN optional SKIPPING OPTIONAL DEPENDENCY: fsevents@1.2.11 (node_modules/fsevents):
              npm WARN notsup SKIPPING OPTIONAL DEPENDENCY: Unsupported platform for fsevents@1.2.11: wanted {"os":"darwin","arch":"any"} (current: {"os":"linux","arch":"arm"})
              audited 2191 packages in 12.474s
              1 package is looking for funding
                run `npm fund` for details
              found 0 vulnerabilities
              > magicmirror@2.10.1 postinstall /home/pi/MagicMirror
              > sh untrack-css.sh && sh installers/postinstall/postinstall.sh && npm run install-fonts
              MagicMirror installation successful!
              > magicmirror@2.10.1 install-fonts /home/pi/MagicMirror
              > cd fonts && npm install
              audited 1 package in 1.105s
              added 6 packages from 12 contributors and audited 3684 packages in 55.242s
              14 packages are looking for funding
              npm install completed - Sun Jan 19 15:54:14 EST 2020 on base
              processing dependency changes for active modules with package.json files
              processing for module MMM-Buller please wait
              npm WARN Invalid version: "1.0"
              npm WARN MMM-Buller No description
              npm WARN MMM-Buller No repository field.
              npm WARN MMM-Buller No README data
              npm WARN MMM-Buller No license field.
              up to date in 0.866s
              processing complete for module MMM-Buller
              processing for module MMM-DarkSkyForecast please wait
              audited 12091 packages in 15.608s
              found 1 low severity vulnerability
                run `npm audit fix` to fix them, or `npm audit` for details
              processing complete for module MMM-DarkSkyForecast
              processing for module MMM-DailyPokemon please wait
              npm WARN notsup Unsupported engine for eslint@6.8.0: wanted: {"node":"^8.10.0 || ^10.13.0 || >=11.10.1"} (current: {"node":"9.11.2","npm":"6.13.4"})
              npm WARN notsup Not compatible with your version of node/npm: eslint@6.8.0
              npm WARN stylelint-config-standard@19.0.0 requires a peer of stylelint@>=10.1.0 but none is installed. You must install peer dependencies yourself.
              npm WARN grunt-stylelint@0.13.0 requires a peer of stylelint@^12.0.0 but none is installed. You must install peer dependencies yourself.
              npm WARN stylelint-config-recommended@3.0.0 requires a peer of stylelint@>=10.1.0 but none is installed. You must install peer dependencies yourself.
              npm WARN MMM-DailyPokemon@1.0.0 No repository field.
              added 225 packages from 138 contributors and audited 432 packages in 39.173s
              3 packages are looking for funding
              processing complete for module MMM-DailyPokemon
              processing for module MMM-Bring please wait
              audited 6 packages in 1.008s
              processing complete for module MMM-Bring
              processing for module MMM-MyCommute please wait
              audited 3140 packages in 19.219s
              found 3 vulnerabilities (1 low, 2 high)
              processing complete for module MMM-MyCommute
              processing for module MMM-pihole-stats please wait
              npm ERR! code EJSONPARSE
              npm ERR! file /home/pi/MagicMirror/modules/MMM-pihole-stats/package.json
              npm ERR! JSON.parse Failed to parse json
              npm ERR! JSON.parse Unexpected token ] in JSON at position 271 while parsing near '...",
              npm ERR! JSON.parse     "Pi-Hole",
              npm ERR! JSON.parse   ],
              npm ERR! JSON.parse   "author": "shey...'
              npm ERR! JSON.parse Failed to parse package.json data.
              npm ERR! JSON.parse package.json must be actual JSON, not just JavaScript.
              npm ERR!     /home/pi/.npm/_logs/2020-01-19T20_55_54_012Z-debug.log
              processing complete for module MMM-pihole-stats
              restoring custom.css
              removing git alias
              we stashed a set of files that appear changed from the latest repo versions. you should review them
              Upgrade ended - Sun Jan 19 15:55:54 EST 2020
                can u post the package.json file from the MMM-pihole-stats module folder
                • N
                    "name": "mmm-pihole-stats",
                    "version": "1.0.0",
                    "description": "Pi-Hole stats for MagicMirror2",
                    "repository": {
                      "type": "git",
                      "url": "git+https://github.com/sheyabernstein/mmm-pihole-stats.git"
                    "keywords": [
                      "MagicMirror",
                      "Pi-Hole",
                    "author": "sheyabernstein",
                    "license": "MIT",
                    "bugs": {
                      "url": "https://github.com/sheyabernstein/mmm-pihole-stats/issues"
                    "homepage": "https://github.com/sheyabernstein/mmm-pihole-stats#readme"
                    @nakulbende
                    remove the trailing comma
                       "Pi-Hole",   // < -- here
                    then go to the module folder and do
                     npm install
                    but I don’t see pihole-stats starting in the startup… but it is listed as not disabled in config.js
                    (can u show me its config.js entry)
                    for MMM-GoogleFit module, it looks like
                    : Cannot read property ‘startOnMonday’ of undefined
                    that property is not defined in the config.js module entry
                    • N
                      @sdetweil Thank you so much for your time. If you are ever in Boston area, please let me buy you dinner. You have been a huge help and a great teacher.
                      I think I fixed the pihole-stats thing as you said. Here is the config.json entry
                      		// Pihole stats
                      			module: 'MMM-pihole-stats',
                      			position: 'bottom_bar',
                      				apiURL: 'http://pi.hole/admin/api.php'
                        @nakulbende cool, thanks for the feedback… are you running ok now?
                        • N
                          nakulbende
                          I am! It ran overnight without crashing, as soon as I disabled fitbit. Sad that I cant use it.
                          I am still having issues with ssh. I ran your update script again, but it said it is already on new version. Did my update go well, except that stupid error pi-hole stats threw?
                            @nakulbende yes, I think update worked…
                            I posted a link in the other topic about a new fitbit module
                            u could try to do the update again use ‘force’, instead of ‘apply’
                            • N
                              nakulbende
                              I saw that - the new fitbit module looks great, I am going to try it later today. Thanks!
