    Issues after update - restoring?
    13 Posts 2 Posters 3.4k Views 2 Watching
    • N Offline
      nakulbende
      Here is the log from npm start:
      > magicmirror@2.10.1 start /home/pi/MagicMirror
      > ./run-start.sh
      [10:59:40.101] [LOG]    Starting MagicMirror: v2.10.1
      [10:59:40.117] [LOG]    Loading config ...
      [10:59:40.153] [LOG]    Loading module helpers ...
      [10:59:40.156] [LOG]    No helper found for module: alert.
      [10:59:40.329] [LOG]    Initializing new module helper ...
      [10:59:40.332] [LOG]    Module helper loaded: updatenotification
      [10:59:40.339] [LOG]    Initializing new module helper ...
      [10:59:40.340] [LOG]    Module helper loaded: MMM-BurnIn
      [10:59:40.353] [LOG]    Initializing new module helper ...
      [10:59:40.359] [LOG]    Module helper loaded: MMM-WatchDog
      [10:59:40.559] [LOG]    Initializing new module helper ...
      [10:59:40.561] [LOG]    Module helper loaded: MMM-Remote-Control
      [10:59:40.562] [LOG]    No helper found for module: compliments.
      [10:59:40.564] [LOG]    No helper found for module: clock.
      [10:59:40.565] [LOG]    No helper found for module: calendar_monthly.
      [10:59:41.778] [LOG]    Initializing new module helper ...
      [10:59:41.780] [LOG]    Module helper loaded: calendar
      [10:59:46.210] [LOG]    Initializing new module helper ...
      [10:59:46.211] [LOG]    Module helper loaded: MMM-Buller
      [10:59:47.302] [LOG]    Initializing new module helper ...
      [10:59:47.303] [LOG]    Module helper loaded: MMM-DarkSkyForecast
      [10:59:47.305] [LOG]    No helper found for module: MMM-DailyPokemon.
      [10:59:47.320] [LOG]    Initializing new module helper ...
      [10:59:47.322] [LOG]    Module helper loaded: MMM-fitbit
      [10:59:47.388] [LOG]    Initializing new module helper ...
      [10:59:47.389] [LOG]    Module helper loaded: MMM-GoogleFit
      [10:59:47.396] [LOG]    No helper found for module: MMM-MBTA.
      [10:59:47.398] [LOG]    No helper found for module: MMM-MBTA1.
      [10:59:48.306] [LOG]    Initializing new module helper ...
      [10:59:48.307] [LOG]    Module helper loaded: MMM-MyCommute
      [10:59:48.311] [LOG]    Initializing new module helper ...
      [10:59:48.313] [LOG]    Module helper loaded: DailyXKCD
      [10:59:48.314] [LOG]    No helper found for module: MMM-pihole-stats.
      [10:59:48.315] [LOG]    All module helpers loaded.
      [10:59:48.322] [LOG]    Starting server on port 8080 ...
      [10:59:48.362] [LOG]    Server started ...
      [10:59:48.366] [LOG]    Connecting socket for: updatenotification
      [10:59:48.368] [LOG]    Connecting socket for: MMM-BurnIn
      [10:59:48.371] [LOG]    Connecting socket for: MMM-WatchDog
      [10:59:48.376] [LOG]    Starting module helper: MMM-WatchDog
      [10:59:48.378] [LOG]    Connecting socket for: MMM-Remote-Control
      [10:59:48.380] [LOG]    Starting node helper for: MMM-Remote-Control
      [10:59:48.444] [LOG]    Connecting socket for: calendar
      [10:59:48.446] [LOG]    Starting node helper for: calendar
      [10:59:48.448] [LOG]    Connecting socket for: MMM-Buller
      [10:59:48.450] [LOG]    Connecting socket for: MMM-DarkSkyForecast
      [10:59:48.451] [LOG]    ====================== Starting node_helper for module [MMM-DarkSkyForecast]
      [10:59:48.452] [LOG]    Connecting socket for: MMM-fitbit
      [10:59:48.453] [LOG]    Starting module helper: MMM-fitbit
      [10:59:48.455] [LOG]    Connecting socket for: MMM-GoogleFit
      [10:59:48.456] [LOG]    MMM-GoogleFit helper started...
      [10:59:48.459] [LOG]    Connecting socket for: MMM-MyCommute
      [10:59:48.461] [LOG]    ====================== Starting node_helper for module [MMM-MyCommute]
      [10:59:48.463] [LOG]    Connecting socket for: DailyXKCD
      [10:59:48.465] [LOG]    Starting node helper: DailyXKCD
      [10:59:48.466] [LOG]    Sockets connected & modules started ...
      [10:59:48.695] [LOG]    Launching application.
      [10:59:55.989] [LOG]    WatchDog started. Maximum timeout: 25s.
      [10:59:56.551] [LOG]    Create new calendar fetcher for url: http://www.calendarlabs.com/ical-calendar/ics/76/US_Holidays.ics - Interval: 300000
      [10:59:56.748] [LOG]    Create new calendar fetcher for url: https://calendar.google.com/calendar/ical/kiij30c31pmgimj2fhja5dejh0%40group.calendar.google.com/private-9db55d67edd0ff1ebecddbb28201bb01/basic.ics - Interval: 300000
      [10:59:56.939] [LOG]    Set credential request recieved.
      [10:59:56.945] [LOG]    { client_id: 'XXXXXX',
        client_secret: 'XXXXXXXX' }
      [10:59:56.968] [LOG]    Whoops! There was an uncaught exception...
      [10:59:56.969] [ERROR]  TypeError: PythonShell.run is not a function
          at Class.setCreds (/home/pi/MagicMirror/modules/MMM-fitbit/node_helper.js:32:15)
          at Class.socketNotificationReceived (/home/pi/MagicMirror/modules/MMM-fitbit/node_helper.js:18:9)
          at Socket.<anonymous> (/home/pi/MagicMirror/js/node_helper.js:113:11)
          at Socket.emit (events.js:182:13)
          at /home/pi/MagicMirror/node_modules/socket.io/lib/socket.js:528:12
          at process._tickCallback (internal/process/next_tick.js:61:11)
      [10:59:56.974] [LOG]    MagicMirror will not quit, but it might be a good idea to check why this happened. Maybe no internet connection?
      [10:59:56.977] [LOG]    If you think this really is an issue, please open an issue on GitHub: https://github.com/MichMich/MagicMirror/issues
      [10:59:57.067] [LOG]    Initial run request recieved.
      [10:59:57.078] [LOG]    Running getData.py
      [10:59:57.092] [LOG]    Whoops! There was an uncaught exception...
      [10:59:57.097] [ERROR]  TypeError: PythonShell is not a constructor
          at Class.getData (/home/pi/MagicMirror/modules/MMM-fitbit/node_helper.js:43:25)
          at Class.socketNotificationReceived (/home/pi/MagicMirror/modules/MMM-fitbit/node_helper.js:22:9)
      [10:59:57.104] [LOG]    MagicMirror will not quit, but it might be a good idea to check why this happened. Maybe no internet connection?
      [10:59:57.106] [LOG]    If you think this really is an issue, please open an issue on GitHub: https://github.com/MichMich/MagicMirror/issues
      [10:59:57.590] [LOG]    Notification: GET_COMIC Payload: [object Object]
      [10:59:59.415] [LOG]    Task lists:
      [10:59:59.421] [LOG]    To read (MDMxODA0MzYxMjU2NTQyODg2NDg6MDow)
      [10:59:59.423] [LOG]    Ideas (MDMxODA0MzYxMjU2NTQyODg2NDg6NDQ5MzE4MjI0NjMwNDQzNDow)
      [10:59:59.427] [LOG]    Life (MDMxODA0MzYxMjU2NTQyODg2NDg6MTE4NzY4MDk1NTow)
      [10:59:59.436] [LOG]    Random thoughts (MDMxODA0MzYxMjU2NTQyODg2NDg6NDkzOTQyODczOjA)
      [10:59:59.443] [LOG]    HomeToDo (dXA5MVM4bGpmTmJHZnZmVg)
      [11:01:10.537] [LOG]    Whoops! There was an uncaught exception...
      [11:01:10.539] [ERROR]  TypeError: Cannot read property 'startOnMonday' of undefined
          at Class.getStats (/home/pi/MagicMirror/modules/MMM-GoogleFit/node_helper.js:134:22)
          at Request._callback (/home/pi/MagicMirror/modules/MMM-GoogleFit/node_helper.js:98:14)
          at Request.self.callback (/home/pi/MagicMirror/node_modules/request/request.js:185:22)
          at Request.emit (events.js:182:13)
          at Request.<anonymous> (/home/pi/MagicMirror/node_modules/request/request.js:1161:10)
          at IncomingMessage.<anonymous> (/home/pi/MagicMirror/node_modules/request/request.js:1083:12)
          at Object.onceWrapper (events.js:273:13)
          at IncomingMessage.emit (events.js:187:15)
          at endReadableNT (_stream_readable.js:1090:12)
      [11:01:10.544] [LOG]    MagicMirror will not quit, but it might be a good idea to check why this happened. Maybe no internet connection?
      [11:01:10.545] [LOG]    If you think this really is an issue, please open an issue on GitHub: https://github.com/MichMich/MagicMirror/issues
        sdetweil @nakulbende
        @nakulbende said in Issues after update - restoring?:
        some error with the fitbit module…
        • N Offline
          nakulbende @sdetweil
          Upgrade started - Sun Jan 19 15:52:57 EST 2020
          system is Linux magicmirror 4.19.75-v7+ #1270 SMP Tue Sep 24 18:45:11 BST 2019 armv7l GNU/Linux
          the os is Distributor ID: Raspbian Description: Raspbian GNU/Linux 10 (buster) Release: 10 Codename: buster
          user requested to apply changes
          doing test run = false
          saving custom.css
          remote name = origin
          upgrading from version 2.9.0 to 2.10.1
          fetching latest revisions
          git fetch rc=0
          current branch = master
          On branch master
          Your branch is behind 'origin/master' by 2836 commits, and can be fast-forwarded.
            (use "git pull" to update your local branch)
          Changes to be committed:
            (use "git reset HEAD <file>..." to unstage)
          	deleted:    css/custom.css
            (use "git add <file>..." to update what will be committed)
            (use "git checkout -- <file>..." to discard changes in working directory)
          	modified:   package.json
          Untracked files:
            (use "git add <file>..." to include in what will be committed)
          	core
          	css/save_custom.css
          there are 1 local files that are different than the master repo
             package.json
          save/restore files selection = y
          Saved working directory and index state WIP on master: 500147e Merge pull request #1776 from MichMich/develop
          test merge result rc='' , if empty, no conflicts
          executing merge, apply specified
          merge result rc= 0
           Updating 500147e..5bf90ae Fast-forward  .gitignore
              6 -  .snyk
             14 -  .travis.yml
              8 +-  CHANGELOG.md
             33 +-  README.md
            210 +-  config/config.js.sample
              7 +-  css/custom.css
             14 -  installers/dumpactivemodules.js
             15 +  installers/fixuppm2.sh
            183 +  installers/raspberry.sh
            560 ++-  installers/screensaveroff.sh
            101 +  installers/upgrade-script.sh
            361 ++  js/app.js
              6 +  js/main.js
             17 +-  .../node_helper/index.js => js/node_helper.js
              2 +-  js/server.js
              2 +-  modules/default/calendar/calendar.js
              1 +  modules/default/calendar/calendarfetcher.js
              7 +-  modules/default/calendar/debug.js
              4 +-  modules/default/compliments/compliments.js
             39 +-  modules/default/weatherforecast/weatherforecast.js
              4 +-  package-lock.json
           4187 +++++++++++---------  package.json
             17 +-  run-start.sh
             64 +-  tests/e2e/modules/weather_spec.js
            138 +-  tests/e2e/vendor_spec.js
              5 +-  untrack-css.sh
              2 +-  vendor/package-lock.json
              2 +-  28 files changed, 3652 insertions(+), 2357 deletions(-)  delete mode 100644 .snyk  delete mode 100644 css/custom.css
          create mode 100644 installers/dumpactivemodules.js
          create mode 100755 installers/fixuppm2.sh
          mode change 100644 => 100755 installers/raspberry.sh
          create mode 100755 installers/screensaveroff.sh
          create mode 100755 installers/upgrade-script.sh  rename modules/node_modules/node_helper/index.js => js/node_helper.js (98%)
          mode change 100644 => 100755 run-start.sh
          processor architecture is armv7l
          > console-stamp@0.2.9 postinstall /home/pi/MagicMirror/node_modules/console-stamp
          > node ./msg.js
          Attention
              Console-stamp version 3.0.0 Release Candidate is out. Install by using the tag '@next'. NB: Breaking changes.
              For more details goto: https://www.npmjs.com/package/console-stamp/v/next
          > magicmirror@2.10.1 install /home/pi/MagicMirror
          > cd vendor && npm install
          npm WARN optional SKIPPING OPTIONAL DEPENDENCY: fsevents@1.2.11 (node_modules/fsevents):
          npm WARN notsup SKIPPING OPTIONAL DEPENDENCY: Unsupported platform for fsevents@1.2.11: wanted {"os":"darwin","arch":"any"} (current: {"os":"linux","arch":"arm"})
          audited 2191 packages in 12.474s
          1 package is looking for funding
            run `npm fund` for details
          found 0 vulnerabilities
          > magicmirror@2.10.1 postinstall /home/pi/MagicMirror
          > sh untrack-css.sh && sh installers/postinstall/postinstall.sh && npm run install-fonts
          MagicMirror installation successful!
          > magicmirror@2.10.1 install-fonts /home/pi/MagicMirror
          > cd fonts && npm install
          audited 1 package in 1.105s
          added 6 packages from 12 contributors and audited 3684 packages in 55.242s
          14 packages are looking for funding
          npm install completed - Sun Jan 19 15:54:14 EST 2020 on base
          processing for module MMM-Buller please wait
          npm WARN Invalid version: "1.0"
          npm WARN MMM-Buller No description
          npm WARN MMM-Buller No repository field.
          npm WARN MMM-Buller No README data
          npm WARN MMM-Buller No license field.
          up to date in 0.866s
          processing complete for module MMM-Buller
          processing for module MMM-DarkSkyForecast please wait
          audited 12091 packages in 15.608s
          found 1 low severity vulnerability
            run `npm audit fix` to fix them, or `npm audit` for details
          processing complete for module MMM-DarkSkyForecast
          processing for module MMM-DailyPokemon please wait
          npm WARN deprecated time-grunt@2.0.0: Deprecated because Grunt is practically unmaintained. Move on to something better. This package will continue to work with Grunt v1, but it will not receive any updates.
          npm WARN notsup Unsupported engine for eslint@6.8.0: wanted: {"node":"^8.10.0 || ^10.13.0 || >=11.10.1"} (current: {"node":"9.11.2","npm":"6.13.4"})
          npm WARN notsup Not compatible with your version of node/npm: eslint@6.8.0
          npm WARN stylelint-config-standard@19.0.0 requires a peer of stylelint@>=10.1.0 but none is installed. You must install peer dependencies yourself.
          npm WARN grunt-stylelint@0.13.0 requires a peer of stylelint@^12.0.0 but none is installed. You must install peer dependencies yourself.
          npm WARN stylelint-config-recommended@3.0.0 requires a peer of stylelint@>=10.1.0 but none is installed. You must install peer dependencies yourself.
          npm WARN MMM-DailyPokemon@1.0.0 No repository field.
          added 225 packages from 138 contributors and audited 432 packages in 39.173s
          3 packages are looking for funding
          processing complete for module MMM-DailyPokemon
          processing for module MMM-Bring please wait
          audited 6 packages in 1.008s
          processing complete for module MMM-Bring
          processing for module MMM-MyCommute please wait
          audited 3140 packages in 19.219s
          found 3 vulnerabilities (1 low, 2 high)
          processing complete for module MMM-MyCommute
          processing for module MMM-pihole-stats please wait
          npm ERR! code EJSONPARSE
          npm ERR! file /home/pi/MagicMirror/modules/MMM-pihole-stats/package.json
          npm ERR! JSON.parse Failed to parse json
          npm ERR! JSON.parse Unexpected token ] in JSON at position 271 while parsing near '...",
          npm ERR! JSON.parse     "Pi-Hole",
          npm ERR! JSON.parse   ],
          npm ERR! JSON.parse   "author": "shey...'
          npm ERR! JSON.parse Failed to parse package.json data.
          npm ERR! JSON.parse package.json must be actual JSON, not just JavaScript.
          npm ERR!     /home/pi/.npm/_logs/2020-01-19T20_55_54_012Z-debug.log
          processing complete for module MMM-pihole-stats
          restoring custom.css
          removing git alias
          we stashed a set of files that appear changed from the latest repo versions. you should review them
          Upgrade ended - Sun Jan 19 15:55:54 EST 2020
            can u post the package.json file from the MMM-pihole-stats module folder
            • N Offline
                "name": "mmm-pihole-stats",
                "version": "1.0.0",
                "description": "Pi-Hole stats for MagicMirror2",
                "repository": {
                  "type": "git",
                  "url": "git+https://github.com/sheyabernstein/mmm-pihole-stats.git"
                "keywords": [
                  "MagicMirror",
                  "Pi-Hole",
                "author": "sheyabernstein",
                "license": "MIT",
                "bugs": {
                  "url": "https://github.com/sheyabernstein/mmm-pihole-stats/issues"
                "homepage": "https://github.com/sheyabernstein/mmm-pihole-stats#readme"
                @nakulbende
                remove the trailing comma
                   "Pi-Hole",   // < -- here
                then go to the module folder and do
                 npm install
                but I don’t see pihole-stats starting in the startup… but it is listed as not disabled in config.js
                (can u show me its config.js entry)
                for MMM-GoogleFit module, it looks like
                : Cannot read property ‘startOnMonday’ of undefined
                that property is not defined in the config.js module entry
                • N Offline
                  @sdetweil Thank you so much for your time. If you are ever in Boston area, please let me buy you dinner. You have been a huge help and a great teacher.
                  I think I fixed the pihole-stats thing as you said. Here is the config.json entry
                  		// Pihole stats
                  			module: 'MMM-pihole-stats',
                  			position: 'bottom_bar',
                  				apiURL: 'http://pi.hole/admin/api.php'
                    @nakulbende cool, thanks for the feedback… are you running ok now?
                    • N Offline
                      nakulbende
                      I am! It ran overnight without crashing, as soon as I disabled fitbit. Sad that I cant use it.
                      I am still having issues with ssh. I ran your update script again, but it said it is already on new version. Did my update go well, except that stupid error pi-hole stats threw?
                        @nakulbende yes, I think update worked…
                        I posted a link in the other topic about a new fitbit module
                        u could try to do the update again use ‘force’, instead of ‘apply’
