    Something went wrong displaying this web page error
    16 Posts 2 Posters 5.0k Views 2 Watching
    • K Offline
      kellogg76
      Everything has been running well for a few months, a couple of weekends ago I noticed a message on the screen informing me that updates were available so I did a git pull in the MagicMirror folder then npm install.
      Everything seemed to have gone well, but after about 15 minutes the screen gives me a “Something went wrong displaying this web page error”. If I use VNC to login in and reload the page everything loads, and I can also load the MagicMirror from other computers on my network but it always goes back to the same error after a period of time.
      I’m using a Pi Zero if that helps with any suggestions.
        sdetweil @kellogg76
        @kellogg76 is pm2 used to start mirror app?
        if so, pm2 logs --lines=100
        might show the error
        if u have modules that have a package.json file, they also needed an npm install done in their folders too…
        my upgrade script handles all that
        see here https://github.com/sdetweil/MagicMirror_scripts
        • K Offline
          kellogg76 @sdetweil
          @sdetweil said in Something went wrong displaying this web page error:
          Your updater script doesn’t work on a Pi Zero.
          I’ll try running npm install in the three non default module folders.
            sdetweil @kellogg76
            @kellogg76 >Your updater script doesn’t work on a Pi Zero.
            say what? i have tested on pi 0, 3, 4, odroid, jetson nano, and mac.
            a bunch of folks have tested on all kinds of pi’s…
            show me the log, ~/MagicMirror/installers/upgrade.log
            just for clarity the , updater doesn’t do anything by default except test the upgrade
            if u want it to DO the upgrade, u have to add the parm at the end ‘apply’
            from https://github.com/sdetweil/MagicMirror_scripts
            it should handle all the work… and give you a trial run of all that…
            only applying changes if u request them
            give it a try this works on Mac as well
            bash -c "$(curl -sL https://raw.githubusercontent.com/sdetweil/MagicMirror_scripts/master/upgrade-script.sh)"
            no changes are made to the local repo or the working copy
            if you WANT to actually apply the changes do
            bash -c "$(curl -sL https://raw.githubusercontent.com/sdetweil/MagicMirror_scripts/master/upgrade-script.sh)" apply
            K 1 Reply Last reply Reply Quote 1
            • K Offline
              kellogg76 @sdetweil
              Apologies, when I ran
              curl -sL https://raw.githubusercontent.com/sdetweil/MagicMirror_scripts/master/raspberry.sh | bash
              I stopped reading after “Sorry, your Pi is not supported”, I just re-ran it and see the bit about Pi Zero’s.
              The install log is as follows
              Upgrade started - Fri Jan 24 13:47:22 AST 2020
              system is Linux raspberrypi 4.19.75+ #1270 Tue Sep 24 18:38:54 BST 2019 armv6l GNU/Linux
              the os is Distributor ID: Raspbian Description: Raspbian GNU/Linux 10 (buster) Release: 10 Codename: buster
              doing test run = true
              saving custom.css
              remote name = origin
              upgrading from version 2.10.1 to 2.10.1
              fetching latest revisions
              git fetch rc=0
              current branch = master
              On branch master
              Your branch is up to date with 'origin/master'.
              Changes not staged for commit:
                (use "git add <file>..." to update what will be committed)
                (use "git checkout -- <file>..." to discard changes in working directory)
                      modified:   vendor/package-lock.json
              Untracked files:
                (use "git add <file>..." to include in what will be committed)
                      css/save_custom.css
              no changes added to commit (use "git add" and/or "git commit -a")
              there are 1 local files that are different than the master repo
              save/restore files selection = n
              restoring vendor/package-lock.json from repo
              skipping restore for vendor/package-lock.json, doing test run
              test merge result rc='' , if empty, no conflicts
              skipping merge, only test run
              processing dependency changes for active modules with package.json files
              processing for module MMM-BackgroundSlideshow please wait
              skipped processing for MMM-BackgroundSlideshow, doing test run
              processing complete for module MMM-BackgroundSlideshow
              processing for module MMM-DarkSkyForecast please wait
              skipped processing for MMM-DarkSkyForecast, doing test run
              processing complete for module MMM-DarkSkyForecast
              processing for module mmm-suncalc please wait
              skipped processing for mmm-suncalc, doing test run
              processing complete for module mmm-suncalc
              restoring custom.css
              removing git alias
              Upgrade ended - Fri Jan 24 13:48:09 AST 2020
              It doesn’t appear there are any updates to apply as far as i can tell.
                sdetweil @kellogg76
                @kellogg76 said in Something went wrong displaying this web page error:
                which means you didn’t add
                apply
                to the end to actually DO the upgrade
                like this
                correct
                u can do force instead of apply to redo the upgrade
                like this
                bash -c "$(curl -sL https://raw.githubusercontent.com/sdetweil/MagicMirror_scripts/master/upgrade-script.sh)" force
                K 2 Replies Last reply Reply Quote 0
                • K Offline
                  kellogg76 @sdetweil
                  I’ll give it a try with the force option.
                  • K Offline
                    kellogg76 @sdetweil
                    Unfortunately it doesn’t seem to have made any difference.
                      sdetweil
                      Ok, we/I made a change to how the mirror app starts on pi 0 or other armv6l systems.
                      But I introduced a bug. Download the fixed run-start.sh like this
                      cd ~/MagicMirror
                      curl -sL https://raw.githubusercontent.com/sdetweil/MagicMirror_scripts/master/run-start.sh > run-start.sh
                      Then start the mirror app again
                      • K Offline
                        kellogg76 @sdetweil
                        Still the same error after doing the above and then rebooting.
                          sdetweil @kellogg76
                          @kellogg76 ok, some module did not get updated with the new mm.
                          Can you do
                          cd ~/MagicMirror
                          node installers/dumpactivemodules.js
                          This should return a list of modules that have package.json files
                          • K Offline
                            kellogg76 @sdetweil
                            When I do that nothing appears on screen
                              sdetweil @kellogg76
                              @kellogg76 ok
                              Then do this
                              ls ~/MagicMirror/modules
                              • K Offline
                                kellogg76 @sdetweil
                                The only non-default modules I have are
                                MMM-DarkSkyForecast
                                mmm-suncalc
                                I’m going to remove them one by one from the config and see if that identifies which is the problem module.
                                Edit: it looks like it’s the BackgroundSlideshow module, removing that from my config file makes everything stable again. Thanks for your help.
                                  sdetweil @kellogg76
                                  @kellogg76
                                  ok, great feedback
                                  I was wrong before
                                  cd ~/MagicMirror/modules
                                  this will list off all the modules which are active in config.js
                                  i would go the the MMM-BackgroundSlideshowfolder and do
                                  npm install
                                    sdetweil @kellogg76
                                    @kellogg76 also, the first script u listed is raspberry.sh which is new install.
                                    Upgrade-script is the one that does version upgrades of existing installations (get rid of that message)
