    Something went wrong displaying this web page error
    16 Posts 2 Posters 5.3k Views 2 Watching
    • K
      kellogg76 @sdetweil
      @sdetweil said in Something went wrong displaying this web page error:
      ~/MagicMirror/installers/upgrade.log
      Apologies, when I ran
      curl -sL https://raw.githubusercontent.com/sdetweil/MagicMirror_scripts/master/raspberry.sh | bash
      I stopped reading after “Sorry, your Pi is not supported”, I just re-ran it and see the bit about Pi Zero’s.
      The install log is as follows
      Upgrade started - Fri Jan 24 13:47:22 AST 2020
      system is Linux raspberrypi 4.19.75+ #1270 Tue Sep 24 18:38:54 BST 2019 armv6l GNU/Linux
      the os is Distributor ID: Raspbian Description: Raspbian GNU/Linux 10 (buster) Release: 10 Codename: buster
      doing test run = true
      saving custom.css
      remote name = origin
      upgrading from version 2.10.1 to 2.10.1
      fetching latest revisions
      git fetch rc=0
      current branch = master
      On branch master
      Your branch is up to date with 'origin/master'.
        (use "git add <file>..." to update what will be committed)
        (use "git checkout -- <file>..." to discard changes in working directory)
              modified:   vendor/package-lock.json
      Untracked files:
        (use "git add <file>..." to include in what will be committed)
              css/save_custom.css
      no changes added to commit (use "git add" and/or "git commit -a")
      there are 1 local files that are different than the master repo
      save/restore files selection = n
      restoring vendor/package-lock.json from repo
      skipping restore for vendor/package-lock.json, doing test run
      test merge result rc='' , if empty, no conflicts
      skipping merge, only test run
      processing for module MMM-BackgroundSlideshow please wait
      skipped processing for MMM-BackgroundSlideshow, doing test run
      processing complete for module MMM-BackgroundSlideshow
      processing for module MMM-DarkSkyForecast please wait
      skipped processing for MMM-DarkSkyForecast, doing test run
      processing complete for module MMM-DarkSkyForecast
      processing for module mmm-suncalc please wait
      skipped processing for mmm-suncalc, doing test run
      processing complete for module mmm-suncalc
      restoring custom.css
      removing git alias
      Upgrade ended - Fri Jan 24 13:48:09 AST 2020
      It doesn’t appear there are any updates to apply as far as i can tell.
      S 2 Replies Last reply
        sdetweil @kellogg76
        @kellogg76 said in Something went wrong displaying this web page error:
        which means you didn’t add
        apply
        to the end to actually DO the upgrade
        like this
        bash -c "$(curl -sL https://raw.githubusercontent.com/sdetweil/MagicMirror_scripts/master/upgrade-script.sh)" apply
        correct
        u can do force instead of apply to redo the upgrade
        like this
        bash -c "$(curl -sL https://raw.githubusercontent.com/sdetweil/MagicMirror_scripts/master/upgrade-script.sh)" force
        K 2 Replies Last reply
        • K
          kellogg76 @sdetweil
          I’ll give it a try with the force option.
          • K
            kellogg76 @sdetweil
            Unfortunately it doesn’t seem to have made any difference.
              Ok, we/I made a change to how the mirror app starts on pi 0 or other armv6l systems.
              But I introduced a bug. Download the fixed run-start.sh like this
              curl -sL https://raw.githubusercontent.com/sdetweil/MagicMirror_scripts/master/run-start.sh > run-start.sh
              Then start the mirror app again
              K 1 Reply Last reply
              • K
                kellogg76 @sdetweil
                Still the same error after doing the above and then rebooting.
                  sdetweil @kellogg76
                  @kellogg76 ok, some module did not get updated with the new mm.
                  Can you do
                  node installers/dumpactivemodules.js
                  This should return a list of modules that have package.json files
                  • K
                    kellogg76 @sdetweil
                    When I do that nothing appears on screen
                      sdetweil @kellogg76
                      @kellogg76 ok
                      Then do this
                      ls ~/MagicMirror/modules
                      • K
                        kellogg76 @sdetweil
                        The only non-default modules I have are
                        MMM-DarkSkyForecast
                        mmm-suncalc
                        I’m going to remove them one by one from the config and see if that identifies which is the problem module.
                        Edit: it looks like it’s the BackgroundSlideshow module, removing that from my config file makes everything stable again. Thanks for your help.
                          sdetweil @kellogg76
                          @kellogg76
                          ok, great feedback
                          I was wrong before
                          cd ~/MagicMirror/modules
                          this will list off all the modules which are active in config.js
                          i would go the the MMM-BackgroundSlideshowfolder and do
                          npm install
                            sdetweil @kellogg76
                            @kellogg76 also, the first script u listed is raspberry.sh which is new install.
                            Upgrade-script is the one that does version upgrades of existing installations (get rid of that message)
