    MMM - Remote Control URL calling issues..
    5 Posts 2 Posters 805 Views 2 Watching
    • BKeyportB Offline
      BKeyport Module Developer
      @Jopyth
      I’ve got two URL commands that aren’t working. I’d like some help to figure them out.
      Update: Trying to use “http://[address]/api/update” - I get back “Cannot GET /api/update”
      Restart: Again, using “http://[address]/api/restart” - I get back:
      Error: Cannot find module ‘pm2’
      at Module._resolveFilename (internal/modules/cjs/loader.js:602:15)
      at Function.Module._resolveFilename (/home/pi/MagicMirror/node_modules/electron/dist/resources/electron.asar/common/reset-search-paths.js:35:12)
      at Function.Module._resolveFilename (/home/pi/MagicMirror/node_modules/module-alias/index.js:49:29)
      at Function.Module._load (internal/modules/cjs/loader.js:528:25)
      at Module.require (internal/modules/cjs/loader.js:658:17)
      at require (internal/modules/cjs/helpers.js:20:18)
      at Class.controlPm2 (/home/pi/MagicMirror/modules/MMM-Remote-Control/node_helper.js:867:23)
      at Class.executeQuery (/home/pi/MagicMirror/modules/MMM-Remote-Control/node_helper.js:654:22)
      at expressRouter.route.get (/home/pi/MagicMirror/modules/MMM-Remote-Control/API/api.js:170:18)
      at Layer.handle [as handle_request] (/home/pi/MagicMirror/node_modules/express/lib/router/layer.js:95:5)
        sdetweil @BKeyport
        @BKeyport try this syntax instead ip:port/remote?action=xxxxx&parms=???&parms2=???
        see
        https://forum.magicmirror.builders/topic/9941/mmm-remote-control-cannot-get-api/7
        • BKeyportB Offline
          Update: changing to other command works if all caps. UPDATE rather than update.
          Restart: Same error.
            sdetweil @BKeyport
            @BKeyport sorry, not quite sure what you said
            • BKeyportB Offline
              Update works with the http://
              /remote?action=update
              Restart does the same error as above regardless of URL.
