    update magic mirror
    19 Posts 3 Posters 5.5k Views 3 Watching
      Raxos
      okay, so if i understand, i nedd to do bash -c “$(curl -sL https://raw.githubusercontent.com/sdetweil/MagicMirror_scripts/master/upgrade-script.sh)” apply
      the log: https://drive.google.com/file/d/1t1eFgTcRHwEFOalFnfDFjbiW5g80V6VT/view?usp=sharing
        sdetweil @Raxos
        @Raxos ok, can you execute these commands and tell me the results
        LC_ALL=C git status
        locale
          mastadook
          after Update I have this Problem: Any Idea?
          0|MagicMirror | > magicmirror@2.10.1 start /home/pi/MagicMirror
          0|MagicMirror | > ./run-start.sh
          0|MagicMirror | ./run-start.sh: Zeile 66: electron: Kommando nicht gefunden.
          0|MagicMirror | npm
          0|MagicMirror | ERR! code ELIFECYCLE
          0|MagicMirror | npm
          0|MagicMirror | ERR! syscall spawn
          0|MagicMirror | npm ERR! file
          0|MagicMirror | sh
          0|MagicMirror | npm ERR! errno ENOENT
          0|MagicMirror | npm
          0|MagicMirror | ERR! magicmirror@2.10.1 start: ./run-start.sh
          0|MagicMirror | npm ERR! spawn ENOENT
          0|MagicMirror | npm
          0|MagicMirror | ERR! Failed at the magicmirror@2.10.1 start script.
          0|MagicMirror | npm ERR! This is probably not a problem with npm. There is likely additional logging output above.
          0|MagicMirror | npm ERR! A complete log of this run can be found in:
          0|MagicMirror | npm ERR! /home/pi/.npm/_logs/2020-01-31T15_08_06_616Z-debug.log
          What can I do?
          Regards
          Clemens
            sdetweil
            @mastadook can u tell us more?
            What version did u upgrade from?
            Show output of
            uname
            npm -v
            node -v
              mastadook
              Hi Sam,
              here are the requested Infos:
              pi@magicmirror:~ $ uname
              Linux
              pi@magicmirror:~ $ npm -v
              6.13.4
              pi@magicmirror:~ $ node -v
              v10.18.1
              Errormessage after npm install
              0|MagicMirror | path: ‘package.json’ }
              0|MagicMirror | [15:31:05.578] [ERROR]
              0|MagicMirror | { Error: ENOENT: no such file or directory, open ‘package.json’
              0|MagicMirror | at Object.openSync (fs.js:443:3)
              0|MagicMirror | at Object.readFileSync (fs.js:343:35)
              0|MagicMirror | at Object. (/home/pi/MagicMirror/js/app.js:21:32)
              0|MagicMirror | at Module._compile (internal/modules/cjs/loader.js:778:30)
              0|MagicMirror | at Object.Module._extensions…js (internal/modules/cjs/loader.js:789:10)
              0|MagicMirror | at Module.load (internal/modules/cjs/loader.js:653:32)
              0|MagicMirror | at tryModuleLoad (internal/modules/cjs/loader.js:593:12)
              0|MagicMirror | at Function.Module._load (internal/modules/cjs/loader.js:585:3)
              0|MagicMirror | at Module.require (internal/modules/cjs/loader.js:692:17)
              0|MagicMirror | at Module.Hook._require.Module.require (/usr/lib/node_modules/pm2/node_modules/require-in-the-middle/index.js:70:39)
              0|MagicMirror | errno: -2,
              0|MagicMirror | syscall: ‘open’,
              0|MagicMirror | code: ‘ENOENT’,
              It works for some hours, after restart the Errormessage comes back.
                sdetweil @mastadook
                @mastadook said in update magic mirror:
                can u tell me what modules u have installed? (folder names in MagicMirror/modules, excluding default)
                there is one module I know of that uses pm2 to launch another component under the covers
                how did u upgrade to 2.10.1?
                  mastadook
                  Hi
                  pi@magicmirror:~/MagicMirror/modules $ ls
                  default MMM-DailyBibleVerse MMM-Domoticz
                  MMM-DailyBibleVerse is not used it´s just there
                  MMM-Domoticz is needed
                  I used this here from another Topic:
                  @Snille said in How to update.:
                  @izanbard Hello, added a restart of the mirror (via pm2) if an npm install has been done and also added “–production” to the npm install command. Sometimes the module-developer have lot’s of extra stuff added in the package list just for developing. :)
                  I’m currently now running this script via CRON every night. :)
                  #!/usr/bin/env bash
                  updated=false
                  cd /home/pi/MagicMirror
                  echo "Checking for MagicMirror updates."
                  git fetch
                  if [ $(git rev-parse HEAD) != $(git rev-parse @{u}) ]
                  then
                      echo "Found, updating..."
                      git pull
                      npm install
                      updated=true
                      echo "Update done."
                  else
                      echo "No update needed."
                  fi
                  echo ""
                  cd modules
                  for directory in *; do
                      if [[ -d ${directory} && ${directory} != "node_modules" && ${directory} != "default" ]]; then
                          echo "Checking for ${directory} updates."
                          cd ${directory}
                          git fetch
                          if [ $(git rev-parse HEAD) != $(git rev-parse @{u}) ]; then
                              echo "Found, updating ${directory}..."
                              git pull
                              if [[ -e "package.json" && -f "package.json" ]]; then
                                  echo "package.joson changed for ${directory}, installing..."
                                  npm install --production
                                  updated=true
                                  echo "Update done."
                              fi
                          else
                          fi
                          echo ""
                          cd ..
                      fi
                  done
                  if $updated; then
                      echo "Restart of MM needed, restarting now."
                      pm2 restart mm
                  fi
                  echo "All done. :)"
                  maybe it was a failure …
                  if I try:
                  pi@magicmirror:~/MagicMirror $ ./run-start.sh
                  maybe this helps?
                    sdetweil @mastadook
                    @mastadook run-start.sh wasn’t meant to be executed directly… it depended on npm to setup the path
                    but you can fix this,
                    get the latest
                    cd ~/MagicMirror
                    curl -sL https://raw.githubusercontent.com/sdetweil/MagicMirror_scripts/master/run-start.sh >run-start.sh
                    or
                    u can edit the line in the script that is changed
                    add the path (node_modules/.bin/) to the invocation of electron like below
                    note the dot in front of bin
                      else
                        # we can use electron directly
                        node_modules/.bin/electron js/electron.js $1;
                      fi
                    can u show me the output of pm2 show mm
                      mastadook
                      yes, here is the Output you ask me:
                      pi@magicmirror:~ $ pm2 show 0
                       Describing process with id 0 - name MagicMirror
                      │ status            │ online                                   │
                      │ name              │ MagicMirror                              │
                      │ version           │ 2.10.1                                   │
                      │ restarts          │ 10                                       │
                      │ uptime            │ 3s                                       │
                      │ script path       │ /home/pi/MagicMirror                     │
                      │ script args       │ N/A                                      │
                      │ error log path    │ /home/pi/.pm2/logs/MagicMirror-error.log │
                      │ out log path      │ /home/pi/.pm2/logs/MagicMirror-out.log   │
                      │ pid path          │ /home/pi/.pm2/pids/MagicMirror-0.pid     │
                      │ interpreter       │ node                                     │
                      │ interpreter args  │ N/A                                      │
                      │ script id         │ 0                                        │
                      │ exec cwd          │ /home/pi                                 │
                      │ exec mode         │ fork_mode                                │
                      │ node.js version   │ 10.18.1                                  │
                      │ node env          │ N/A                                      │
                      │ watch & reload    │ ✘                                        │
                      │ unstable restarts │ 0                                        │
                      │ created at        │ 2020-02-05T12:09:50.536Z                 │
                       Actions available
                      │ km:heapdump            │
                      │ km:cpu:profiling:start │
                      │ km:cpu:profiling:stop  │
                      │ km:heap:sampling:start │
                      │ km:heap:sampling:stop  │
                       Trigger via: pm2 trigger MagicMirror <action_name>
                       Divergent env variables from local env
                       Add your own code metrics: http://bit.ly/code-metrics
                       Use `pm2 logs MagicMirror [--lines 1000]` to display logs
                       Use `pm2 env 0` to display environement variables
                       Use `pm2 monit` to monitor CPU and Memory usage MagicMirror
                      after change run-start.sh the error Message disappeared.
                      But start with pm2 is still not possible.
                        sdetweil @mastadook
                        @mastadook ok, you are starting in the wrong place with the wrong script…
                        in folder
                             /home/pi
                        start this
                        use my pm2 fixup script…
                        do this
                        pm2 delete 0
                        bash -c "$(curl -sL https://raw.githubusercontent.com/sdetweil/MagicMirror_scripts/master/fixuppm2.sh)"
