    MMM-Bose-Soundtouch keeps flashing
    1 Posts 1 Posters 313 Views 1 Watching
    • A
      an0n
      Hello,
      I’m running a MagicMirror2 Instance as server only on a Raspberry Pi now for ~2 years without any big problems. Today I wanted to display the states of my 4 Bose Soundtouch devices. At first it worked fine, the status informations were displayed correctly. Then, I don’t know what I did while configurating, the load on my Pi kept rising till freeze. I couldn’t find a reason in the system logs. My MagicMirror instances doesn’t log anything or at least I don’t know where by default.
      Now, after reboot, the Bose-Module doesn’t work correctly anymore. I keeps flashing and jumps between displaying the status information to the way the module looks, when the speakers are turned off.
      I can see the html switching in irregular intervals to an empty “module-content”-div.
      The startup doesn’t throw any errors:
      user@host: node serveronly
      Starting MagicMirror: v2.1.2
      Loading config ...
      Loading module helpers ...
      Module helper loaded: MMM-CalendarExt
      Module helper loaded: MMM-Bose-Soundtouch
      All module helpers loaded.
      Starting server on port 8081 ...
      Server started ...
      Connecting socket for: MMM-CalendarExt
      Connecting socket for: MMM-Bose-Soundtouch
      Bose helper started ...
      Ready to go! Please point your browser to: http://localhost:8081
      My config.js
            module: "MMM-Bose-Soundtouch",
              updateInterval: 5, // every 5 seconds
              apiBase: '192.168.24.46', //bathroom1
              hideImage: true
              apiBase: '192.168.24.44', //office1
              hideImage: true
              apiBase: '192.168.24.32', //kitchen1
              hideImage: true
              apiBase: '192.168.24.36', //bedroom1
              hideImage: true
      Module: https://github.com/SpoturDeal/MMM-Bose-Soundtouch
      The other modules (clock, currentweather, weatherforecast, MMM-CalendarExt) work fine. The problem is server-side. Clearing the clients cache or using different browser for testing didn’t pay off.
      It seems like there is something wrong stuck in the cache or something. Any help to debug and solve this issue would be great. Thanks!
