    Want to display 2 modules side-by-side
    5 Posts 2 Posters 1.6k Views 2 Watching
    • N
      nakulbende
      Hey all,
      I have two MBTA modules in my mirror - made possible by cloning the repo twice with changed name. So, the config.json looks like:
      		// MBTA - Main x Emerson
      			module: 'MMM-MBTA',
      			position: 'bottom_left', // This can be any of the regions.
      			header: "MBTA: ",
      				apikey: '69a372ea82d748ad8531f55dd05d8df3',
      				updateInterval: 60,
      				stations: [ "Main St @ Emerson St" ], //[ "Davis Square" ]
      				formatETA: true,
      				maxEntries: 4,
      				showOnly: ["Bus"],
      				colorIcons: true,
      				direction: 'Inbound',
      		// // MBTA - Davis
      			module: 'MMM-MBTA1',
      			header: "MBTA: ",
      				updateInterval: 65,
      				stations: [ "Davis Square" ],
      				formatETA: true,
      				maxEntries: 4,
      				showOnly: ["Subway"],
      				colorIcons: true,
      And the bottom of my mirror looks like:
      I would like to have these modules side by side (see below). There are pretty complicated answers on this forum, and I could not get a simple straightforward way to do that with css. Is it possible?
      PS: Bonus gratitude for solving the desaturation of one of the modules. They have renamed css, folders and .json files. But one shows colors, other appears only white.
        sdetweil @nakulbende
        @nakulbende said in Want to display 2 modules side-by-side:
        you have to do the css stuff by moduleName… so duplicate that too
          @nakulbende each position is a stack, 1st is on top, next is below it, etc…
          most modules don’t have capability to align like u want.
          I did one last year for a guy in Rome… but u have to change the code…
          this is for the same module, invoked multiple times (I think i had 5 going at once in test)
          as part of getDom()
          spacing is amount of pixels between instances
          float is left/right to align
          if(this.config.float!== ""){
          			document.getElementById(this.identifier).style.float=this.config.float;
          			if(this.config.spacing !==""){
          				if(this.config.float === "left")
          					document.getElementById(this.identifier).style.marginLeft=this.config.spacing
          				else if(this.config.float === "right")
          					document.getElementById(this.identifier).style.marginRight=this.config.spacing
          but took coding to make multiple instances run… this ‘might’ work for the multiple modules…
          • N
            nakulbende
            Apologies that I cant upload the photos. For some reason, the forum is throwing an error. So I just made 2 instances of the repo - renamed everything from folder, .css and .js files inside the module folder. Then I went to .js file, and changed names to css target. Should that work?
              @nakulbende what is in the css file?
