Want to display 2 modules side-by-side
Hey all,
I have two MBTA modules in my mirror - made possible by cloning the repo twice with changed name. So, the config.json looks like:
// MBTA - Main x Emerson { module: 'MMM-MBTA', position: 'bottom_left', // This can be any of the regions. header: "MBTA: ", config: { apikey: '69a372ea82d748ad8531f55dd05d8df3', updateInterval: 60, stations: [ "Main St @ Emerson St" ], //[ "Davis Square" ] formatETA: true, maxEntries: 4, showOnly: ["Bus"], colorIcons: true, direction: 'Inbound', } }, // // MBTA - Davis { module: 'MMM-MBTA1', position: 'bottom_left', // This can be any of the regions. header: "MBTA: ", config: { apikey: '69a372ea82d748ad8531f55dd05d8df3', updateInterval: 65, stations: [ "Davis Square" ], formatETA: true, maxEntries: 4, showOnly: ["Subway"], colorIcons: true, direction: 'Inbound', } },And the bottom of my mirror looks like:
I would like to have these modules side by side (see below). There are pretty complicated answers on this forum, and I could not get a simple straightforward way to do that with css. Is it possible?
PS: Bonus gratitude for solving the desaturation of one of the modules. They have renamed css, folders and .json files. But one shows colors, other appears only white.
@nakulbende said in Want to display 2 modules side-by-side:
you have to do the css stuff by moduleName… so duplicate that too
@nakulbende each position is a stack, 1st is on top, next is below it, etc…
most modules don’t have capability to align like u want.
I did one last year for a guy in Rome… but u have to change the code…
this is for the same module, invoked multiple times (I think i had 5 going at once in test)
as part of getDom()
spacing is amount of pixels between instances
float is left/right to alignif(this.config.float!== ""){ document.getElementById(this.identifier).style.float=this.config.float; if(this.config.spacing !==""){ if(this.config.float === "left") document.getElementById(this.identifier).style.marginLeft=this.config.spacing else if(this.config.float === "right") document.getElementById(this.identifier).style.marginRight=this.config.spacing } }but took coding to make multiple instances run… this ‘might’ work for the multiple modules…
Apologies that I cant upload the photos. For some reason, the forum is throwing an error. So I just made 2 instances of the repo - renamed everything from folder, .css and .js files inside the module folder. Then I went to .js file, and changed names to css target. Should that work?
@nakulbende what is in the css file?
