    MMM-COVID-19 (Deprecated)
    Scheduled Pinned Locked Moved Health
    71 Posts 16 Posters 41.9k Views 16 Watching
    • N
      najtram
      Would it be possible to see only one country? I see tree results when just one country is configured. Would it be possible to remove World total, and the country slideshow below.
        A Former User @najtram
        @najtram
        First, set pinned only one region.
        To remove THIRD whole region rotation, set rotateInterval:0
        To remove World Total, Hmmmm… There is a trick. add this into your css/custom.css
        .covid .item.total {
          display:none;
        • B
          banbutcher
          is it possible to set the third slot to a specific country?
          and if possible to add more countries? slot 4?
          ? 2 Replies Last reply Reply Quote 0
            A Former User @banbutcher
            @banbutcher
            “pinned” is array, so you can add as many as possible in screen.
              @banbutcher
              pinned: [“Diamond Princess cruise ship, Others”, “Mainland China”, “South Korea”],
              • B
                banbutcher @Guest
                @Sean
                i tried addind a second country with this code:
                			module: "MMM-COVID-19",
                			header: "COVID-19",
                			position: "bottom_left",
                			config:{
                				scanInterval: 1000 * 60 * 60 * 12,
                				rotateInterval: 0,
                				detailProvince: true,
                				pinned: ["Ireland"],
                				pinned: ["New Zealand"],
                				logProvinceCountry: false,
                				logOnce: true,
                		        	sortOrder: null,				}
                no joy tho with second country!
                  @banbutcher
                  • B
                    banbutcher
                    its showing iew zealand and not ireland
                    • B
                      banbutcher
                      does it throttle alyone elses cpu? running top shows electron using it all? is this normal?
                        sdetweil
                        can u describe the data labels?
                        never mind read the code and its NEW confirmed/dead/recovered) as compared to last reported data
                        ? iMAGiCI 2 Replies Last reply Reply Quote 0
                          A Former User @sdetweil
                          Sorry for no convenience. C/D/R are Confirmed, Deaths, Recovered. NC/ND/NR are new ...
                          You can change labels on CSS.
                          • iMAGiCI
                            iMAGiC @sdetweil
                            Like this?
                            Pictures
                            Choice * Judgment * Values
                              sdetweil @iMAGiC
                              @iMAGiC i just didn’t know what the N? labels meant… sometimes cant see the forest because of all the trees!!
                              • T
                                Tribun
                                I updated the module today and since then the Raspi has been running 10 ° C warmer. Electron has a much higher CPU usage.
                                If I deactivate the module, everything will go back to normal.
                                mfg
                                • C
                                  ctatos @Tribun
                                  @Tribun I can confirm this as well.
                                    A Former User @ctatos
                                    Original source format was changed yesterday, so you guys need to reinstall and reconfigure again. (read the README)
                                    2.1.0 (2020-03-16)
                                    • Whole refactored. (Orignial source format is changed.)
                                    • Changed: the territory name rule is changed. (See configuration section)
                                    • Changed: reduction of CPU usage (I hope.)
                                    • added: drawGraph option to show graph or not.
                                    • added: logTerritory option to log territory names.
                                    @ctatos @Tribun
                                    Refactored to reduce memory and CPU usage. Update and try again. (And I left some tips on README)
                                      sdetweil @Guest
                                      @Sean thx for the update…
                                      position top_right
                                      I have 5 tables, world, us, france, spain, italy… drawgraph:true…
                                      graph isn’t seen… is it off screen?
                                        @sdetweil Show me config.
                                          sdetweil @Guest
                                          @Sean
                                            debug:false,
                                            scanInterval: 1000 * 60 * 60 * 3,
                                            rotateInterval: 0, // 0 means no rotate
                                            pinned: [ "World","US Total","France","Spain","Italy"],
                                            reportTimeFormat: "YYYY.MM.DD hh a",
                                            drawGraph: true,
                                            Hmmm. For me no problem. There might be CSS collision with other module? (“.graph”)
                                            And France means only mainland of France, not Sum of all territories of French.
                                            • 2 / 4
