    no /etc/kbd/config Folder/File
    31 Posts 2 Posters 18.2k Views 2 Watching
      Miked180
      I see in some tutorials that i schould deachtivate the screensaver with :
      BLANK_TIME=0
      BLANK_DPMS=off
      POWERDOWN_TIME=0
      But i dont have this folder kbd
        sdetweil @Miked180
        @Miked180 use the screensaver off script here
          Miked180
          i get this:
          pi@raspberrypi:~ $ bash -c “$(curl -sL https://raw.githubusercontent.com/sdetweil/MagicMirror_scripts/master/screensaveroff.sh)”
          xscreensaver running
          grep: /home/pi/.xscreensaver: Datei oder Verzeichnis nicht gefunden
          bash: Zeile 42: [: !=: Einstelliger (unärer) Operator erwartet.
            sdetweil @Miked180
            @Miked180 oops… left debug stmt in… please retry
              Miked180 @sdetweil
              @sdetweil said in no /etc/kbd/config Folder/File:
              oops… left debug stmt in… ??
              Sorry im not sure what you mean ?
                sdetweil @Miked180
                @Miked180 sorry, I left some code in the script, which causes the error you encountered…
                please rerun the script (please retry)
                  Miked180
                  ok now there was no error for use the command
                    sdetweil @Miked180
                    @Miked180 and screen saver should now be off on your system
                    the log will say what it did
                    ~/screensaver.log
                      Miked180
                      This is in the log:
                      xscreensaver already disabled
                      disable screensaver via gsettings was true and uint32 300
                      install screensaver via lightdm.conf
                      disable screensaver via lxsession
                      gsettings screen saver already disabled
                      screensaver via lightdm already disabled
                      lxsession screen saver already disabled
                        sdetweil @Miked180
                        @Miked180 yeh, it adds to the log each time its run
                        as it has become more difficult to figure out which setting is actually in control
                        (some newer OS’s have gsettings capability, but different versions do or do not use it)…
                        so I report them all…
                          Miked180
                          no i have a black screen after ca 2 mins and cant wake up with mouse or keyboard
                            sdetweil @Miked180
                            @Miked180 then that is not screensaver
                            use alt-spacebar
                            to see if this is a browser window
                              Miked180
                              ok thanks
                              have you any idea ?
                                sdetweil @Miked180
                                @Miked180 see my prior updated reply
                                  Miked180
                                  i have delete MMM-Motion Detector from the config.js and since this i have no black screen, i will test for longer timer
                                  I wait for tomorrow for my new cas with fan cooler . I have 70 ° Temp now , this is to much , maybe this is the problem too
                                  Thansk now for the big help, in the next days i know more .
                                    sdetweil @Miked180
                                    @Miked180 ok, the black screen means that the UI portion of MM has died… usually due to some coding error or unexpected error…
                                      Miked180
                                      I found this in Log File:
                                      pm2 log MagicMirror
                                      [TAILING] Tailing last 15 lines for [MagicMirror] process (change the value with --lines option)
                                      /home/pi/.pm2/logs/MagicMirror-error.log last 15 lines:
                                      0|MagicMir | at Module.load (internal/modules/cjs/loader.js:620:32)
                                      0|MagicMir | at tryModuleLoad (internal/modules/cjs/loader.js:559:12)
                                      0|MagicMir | at Function.Module._load (internal/modules/cjs/loader.js:551:3)
                                      0|MagicMir | at Module.require (internal/modules/cjs/loader.js:658:17)
                                      0|MagicMir | at require (internal/modules/cjs/helpers.js:20:18)
                                      0|MagicMir | npm ERR! code ELIFECYCLE
                                      0|MagicMir | npm ERR! errno 1
                                      0|MagicMir | npm ERR! magicmirror@2.10.1 start: ./run-start.sh
                                      0|MagicMir | npm ERR! Exit status 1
                                      0|MagicMir | npm ERR! Failed at the magicmirror@2.10.1 start script.
                                      0|MagicMir | npm ERR! This is probably not a problem with npm. There is likely additional logging output above.
                                      0|MagicMir |
                                      0|MagicMir | npm ERR! A complete log of this run can be found in:
                                      0|MagicMir | npm ERR! /home/pi/.npm/_logs/2020-03-11T17_05_15_894Z-debug.log
                                        sdetweil @Miked180
                                        @Miked180 do
                                        pm2 logs --lines=100
                                          Miked180
                                          See Link. I cant post log here
                                          Log File
                                            sdetweil @Miked180
                                            @Miked180 for calendar error
                                            change http://calendar to https://calendar
                                            don’t see the error listed above
                                            pm2 stop 0
                                            pm2 flush
                                            pm2 start 0
                                            after error
