    no /etc/kbd/config Folder/File
    31 Posts 2 Posters 19.1k Views 2 Watching
      Miked180
      ok now there was no error for use the command
        sdetweil @Miked180
        @Miked180 and screen saver should now be off on your system
        the log will say what it did
        ~/screensaver.log
          Miked180
          This is in the log:
          xscreensaver running
          xscreensaver already disabled
          disable screensaver via gsettings was true and uint32 300
          install screensaver via lightdm.conf
          disable screensaver via lxsession
          gsettings screen saver already disabled
          screensaver via lightdm already disabled
          lxsession screen saver already disabled
            sdetweil @Miked180
            @Miked180 yeh, it adds to the log each time its run
            as it has become more difficult to figure out which setting is actually in control
            (some newer OS’s have gsettings capability, but different versions do or do not use it)…
            so I report them all…
              Miked180
              no i have a black screen after ca 2 mins and cant wake up with mouse or keyboard
                sdetweil @Miked180
                @Miked180 then that is not screensaver
                use alt-spacebar
                to see if this is a browser window
                  Miked180
                  ok thanks
                  have you any idea ?
                    sdetweil @Miked180
                    @Miked180 see my prior updated reply
                      Miked180
                      i have delete MMM-Motion Detector from the config.js and since this i have no black screen, i will test for longer timer
                      I wait for tomorrow for my new cas with fan cooler . I have 70 ° Temp now , this is to much , maybe this is the problem too
                      Thansk now for the big help, in the next days i know more .
                        sdetweil @Miked180
                        @Miked180 ok, the black screen means that the UI portion of MM has died… usually due to some coding error or unexpected error…
                          Miked180
                          I found this in Log File:
                          pm2 log MagicMirror
                          [TAILING] Tailing last 15 lines for [MagicMirror] process (change the value with --lines option)
                          /home/pi/.pm2/logs/MagicMirror-error.log last 15 lines:
                          0|MagicMir | at Module.load (internal/modules/cjs/loader.js:620:32)
                          0|MagicMir | at tryModuleLoad (internal/modules/cjs/loader.js:559:12)
                          0|MagicMir | at Function.Module._load (internal/modules/cjs/loader.js:551:3)
                          0|MagicMir | at Module.require (internal/modules/cjs/loader.js:658:17)
                          0|MagicMir | at require (internal/modules/cjs/helpers.js:20:18)
                          0|MagicMir | npm ERR! code ELIFECYCLE
                          0|MagicMir | npm ERR! errno 1
                          0|MagicMir | npm ERR! magicmirror@2.10.1 start: ./run-start.sh
                          0|MagicMir | npm ERR! Exit status 1
                          0|MagicMir | npm ERR! Failed at the magicmirror@2.10.1 start script.
                          0|MagicMir | npm ERR! This is probably not a problem with npm. There is likely additional logging output above.
                          0|MagicMir |
                          0|MagicMir | npm ERR! A complete log of this run can be found in:
                          0|MagicMir | npm ERR! /home/pi/.npm/_logs/2020-03-11T17_05_15_894Z-debug.log
                            sdetweil @Miked180
                            @Miked180 do
                            pm2 logs --lines=100
                              Miked180
                              See Link. I cant post log here
                              Log File
                                sdetweil @Miked180
                                @Miked180 for calendar error
                                change http://calendar to https://calendar
                                don’t see the error listed above
                                pm2 stop 0
                                pm2 flush
                                pm2 start 0
                                after error
                                  Miked180
                                  pi@raspberrypi:~/MagicMirror/config $ pm2 logs --lines=100
                                  PM2 | 2020-03-11T18:29:32: PM2 log: App [MagicMirror:0] starting in -fork mode-
                                  PM2 | 2020-03-11T18:29:32: PM2 log: App [MagicMirror:0] online
                                  /home/pi/.pm2/logs/MagicMirror-error.log last 100 lines:
                                  /home/pi/.pm2/logs/MagicMirror-out.log last 100 lines:
                                  0|MagicMir |
                                  0|MagicMir | > magicmirror@2.10.1 start /home/pi/MagicMirror
                                  0|MagicMir | > ./run-start.sh
                                  0|MagicMir |
                                  0|MagicMir | [18:29:37.650] [LOG] Starting MagicMirror: v2.10.1
                                  0|MagicMir | [18:29:37.659] [LOG] Loading config …
                                  0|MagicMir | [18:29:37.664] [LOG] Loading module helpers …
                                  0|MagicMir | [18:29:37.666] [LOG] No helper found for module: alert.
                                  0|MagicMir | [18:29:37.713] [LOG] Initializing new module helper …
                                  0|MagicMir | [18:29:37.714] [LOG] Module helper loaded: updatenotification
                                  0|MagicMir | [18:29:37.715] [LOG] No helper found for module: clock.
                                  0|MagicMir | [18:29:38.184] [LOG] Initializing new module helper …
                                  0|MagicMir | [18:29:38.185] [LOG] Module helper loaded: calendar
                                  0|MagicMir | [18:29:38.185] [LOG] No helper found for module: compliments.
                                  0|MagicMir | [18:29:38.186] [LOG] No helper found for module: currentweather.
                                  0|MagicMir | [18:29:38.187] [LOG] No helper found for module: weatherforecast.
                                  0|MagicMir | [18:29:38.218] [LOG] Initializing new module helper …
                                  0|MagicMir | [18:29:38.218] [LOG] Module helper loaded: newsfeed
                                  0|MagicMir | [18:29:38.222] [LOG] Initializing new module helper …
                                  0|MagicMir | [18:29:38.222] [LOG] Module helper loaded: MMM-WienerLinien
                                  0|MagicMir | [18:29:38.224] [LOG] Initializing new module helper …
                                  0|MagicMir | [18:29:38.225] [LOG] Module helper loaded: MMM-RandomYouTubePlayer
                                  0|MagicMir | [18:29:38.226] [LOG] No helper found for module: MMM-EyeCandy.
                                  0|MagicMir | [18:29:38.226] [LOG] All module helpers loaded.
                                  0|MagicMir | [18:29:38.227] [LOG] Starting server on port 8080 …
                                  0|MagicMir | [18:29:38.241] [LOG] Server started …
                                  0|MagicMir | [18:29:38.242] [LOG] Connecting socket for: updatenotification
                                  0|MagicMir | [18:29:38.243] [LOG] Connecting socket for: calendar
                                  0|MagicMir | [18:29:38.244] [LOG] Starting node helper for: calendar
                                  0|MagicMir | [18:29:38.245] [LOG] Connecting socket for: newsfeed
                                  0|MagicMir | [18:29:38.245] [LOG] Starting module: newsfeed
                                  0|MagicMir | [18:29:38.246] [LOG] Connecting socket for: MMM-WienerLinien
                                  0|MagicMir | [18:29:38.247] [LOG] Starting module helper: MMM-WienerLinien
                                  0|MagicMir | [18:29:38.248] [LOG] Connecting socket for: MMM-RandomYouTubePlayer
                                  0|MagicMir | [18:29:38.248] [LOG] Starting module helper: MMM-RandomYouTubePlayer
                                  0|MagicMir | [18:29:38.249] [LOG] Sockets connected & modules started …
                                  0|MagicMir | [18:29:38.404] [LOG] Launching application.
                                  0|MagicMir | [18:29:40.761] [LOG] Create new calendar fetcher for url: https://calendar.google.com/calendar/ical/vaios2k%40gmail.com/public/basic.ics - Interval: 120000
                                  0|MagicMir | [18:29:40.873] [LOG] Create new news fetcher for url: https://rss.orf.at/science.xml - Interval: 300000
                                    sdetweil @Miked180
                                    @Miked180 did it black screen?
                                      Miked180
                                      now i see the mirror, i wait few minutes
                                        Miked180
                                        Now i got a black screen.
                                        0|MagicMir |
                                        0|MagicMir | npm ERR! /home/pi/.npm/_logs/2020-03-11T17_47_10_283Z-debug.log
                                        from 283Z-debug.log :
                                        0|MagicMir |
                                        after restart raspberry i see the mirror
                                          sdetweil @Miked180
                                          @Miked180 before restart pi, do with keyboard on pi…
                                          alt-spacebar, n
                                          see if MM window will minimize
                                          also, setup ssh on pi, and ssh from windows to pi to examine…
                                          xset q
                                          setterm -blank 0 -powerdown 0
                                          from here https://wiki.archlinux.org/index.php/Display_Power_Management_Signaling
                                          in ssh terminal session, may have to do export DISPLAY=:0
                                            Miked180
                                            thanks for your help,
                                            der is no file in /etc/X11/xorg.conf.d
                                            ist better to make a new setup ??
                                            in ssh terminal session, may have to do export DISPLAY=:0 ?
