    no /etc/kbd/config Folder/File
    31 Posts 2 Posters 17.9k Views 2 Watching
      Miked180
      i have delete MMM-Motion Detector from the config.js and since this i have no black screen, i will test for longer timer
      I wait for tomorrow for my new cas with fan cooler . I have 70 ° Temp now , this is to much , maybe this is the problem too
      Thansk now for the big help, in the next days i know more .
        sdetweil @Miked180
        @Miked180 ok, the black screen means that the UI portion of MM has died… usually due to some coding error or unexpected error…
          Miked180
          I found this in Log File:
          pm2 log MagicMirror
          [TAILING] Tailing last 15 lines for [MagicMirror] process (change the value with --lines option)
          /home/pi/.pm2/logs/MagicMirror-error.log last 15 lines:
          0|MagicMir | at Module.load (internal/modules/cjs/loader.js:620:32)
          0|MagicMir | at tryModuleLoad (internal/modules/cjs/loader.js:559:12)
          0|MagicMir | at Function.Module._load (internal/modules/cjs/loader.js:551:3)
          0|MagicMir | at Module.require (internal/modules/cjs/loader.js:658:17)
          0|MagicMir | at require (internal/modules/cjs/helpers.js:20:18)
          0|MagicMir | npm ERR! code ELIFECYCLE
          0|MagicMir | npm ERR! errno 1
          0|MagicMir | npm ERR! magicmirror@2.10.1 start: ./run-start.sh
          0|MagicMir | npm ERR! Exit status 1
          0|MagicMir | npm ERR! Failed at the magicmirror@2.10.1 start script.
          0|MagicMir | npm ERR! This is probably not a problem with npm. There is likely additional logging output above.
          0|MagicMir |
          0|MagicMir | npm ERR! A complete log of this run can be found in:
          0|MagicMir | npm ERR! /home/pi/.npm/_logs/2020-03-11T17_05_15_894Z-debug.log
            sdetweil @Miked180
            @Miked180 do
            pm2 logs --lines=100
              Miked180
              See Link. I cant post log here
              Log File
                sdetweil @Miked180
                @Miked180 for calendar error
                change http://calendar to https://calendar
                don’t see the error listed above
                pm2 stop 0
                pm2 flush
                pm2 start 0
                after error
                  Miked180
                  pi@raspberrypi:~/MagicMirror/config $ pm2 logs --lines=100
                  PM2 | 2020-03-11T18:29:32: PM2 log: App [MagicMirror:0] starting in -fork mode-
                  PM2 | 2020-03-11T18:29:32: PM2 log: App [MagicMirror:0] online
                  /home/pi/.pm2/logs/MagicMirror-error.log last 100 lines:
                  /home/pi/.pm2/logs/MagicMirror-out.log last 100 lines:
                  0|MagicMir |
                  0|MagicMir | > magicmirror@2.10.1 start /home/pi/MagicMirror
                  0|MagicMir | > ./run-start.sh
                  0|MagicMir |
                  0|MagicMir | [18:29:37.650] [LOG] Starting MagicMirror: v2.10.1
                  0|MagicMir | [18:29:37.659] [LOG] Loading config …
                  0|MagicMir | [18:29:37.664] [LOG] Loading module helpers …
                  0|MagicMir | [18:29:37.666] [LOG] No helper found for module: alert.
                  0|MagicMir | [18:29:37.713] [LOG] Initializing new module helper …
                  0|MagicMir | [18:29:37.714] [LOG] Module helper loaded: updatenotification
                  0|MagicMir | [18:29:37.715] [LOG] No helper found for module: clock.
                  0|MagicMir | [18:29:38.184] [LOG] Initializing new module helper …
                  0|MagicMir | [18:29:38.185] [LOG] Module helper loaded: calendar
                  0|MagicMir | [18:29:38.185] [LOG] No helper found for module: compliments.
                  0|MagicMir | [18:29:38.186] [LOG] No helper found for module: currentweather.
                  0|MagicMir | [18:29:38.187] [LOG] No helper found for module: weatherforecast.
                  0|MagicMir | [18:29:38.218] [LOG] Initializing new module helper …
                  0|MagicMir | [18:29:38.218] [LOG] Module helper loaded: newsfeed
                  0|MagicMir | [18:29:38.222] [LOG] Initializing new module helper …
                  0|MagicMir | [18:29:38.222] [LOG] Module helper loaded: MMM-WienerLinien
                  0|MagicMir | [18:29:38.224] [LOG] Initializing new module helper …
                  0|MagicMir | [18:29:38.225] [LOG] Module helper loaded: MMM-RandomYouTubePlayer
                  0|MagicMir | [18:29:38.226] [LOG] No helper found for module: MMM-EyeCandy.
                  0|MagicMir | [18:29:38.226] [LOG] All module helpers loaded.
                  0|MagicMir | [18:29:38.227] [LOG] Starting server on port 8080 …
                  0|MagicMir | [18:29:38.241] [LOG] Server started …
                  0|MagicMir | [18:29:38.242] [LOG] Connecting socket for: updatenotification
                  0|MagicMir | [18:29:38.243] [LOG] Connecting socket for: calendar
                  0|MagicMir | [18:29:38.244] [LOG] Starting node helper for: calendar
                  0|MagicMir | [18:29:38.245] [LOG] Connecting socket for: newsfeed
                  0|MagicMir | [18:29:38.245] [LOG] Starting module: newsfeed
                  0|MagicMir | [18:29:38.246] [LOG] Connecting socket for: MMM-WienerLinien
                  0|MagicMir | [18:29:38.247] [LOG] Starting module helper: MMM-WienerLinien
                  0|MagicMir | [18:29:38.248] [LOG] Connecting socket for: MMM-RandomYouTubePlayer
                  0|MagicMir | [18:29:38.248] [LOG] Starting module helper: MMM-RandomYouTubePlayer
                  0|MagicMir | [18:29:38.249] [LOG] Sockets connected & modules started …
                  0|MagicMir | [18:29:38.404] [LOG] Launching application.
                  0|MagicMir | [18:29:40.761] [LOG] Create new calendar fetcher for url: https://calendar.google.com/calendar/ical/vaios2k%40gmail.com/public/basic.ics - Interval: 120000
                  0|MagicMir | [18:29:40.873] [LOG] Create new news fetcher for url: https://rss.orf.at/science.xml - Interval: 300000
                    sdetweil @Miked180
                    @Miked180 did it black screen?
                      Miked180
                      now i see the mirror, i wait few minutes
                        Miked180
                        Now i got a black screen.
                        0|MagicMir |
                        0|MagicMir | npm ERR! /home/pi/.npm/_logs/2020-03-11T17_47_10_283Z-debug.log
                        from 283Z-debug.log :
                        0|MagicMir |
                        after restart raspberry i see the mirror
                          sdetweil @Miked180
                          @Miked180 before restart pi, do with keyboard on pi…
                          alt-spacebar, n
                          see if MM window will minimize
                          also, setup ssh on pi, and ssh from windows to pi to examine…
                          xset q
                          setterm -blank 0 -powerdown 0
                          from here https://wiki.archlinux.org/index.php/Display_Power_Management_Signaling
                          in ssh terminal session, may have to do export DISPLAY=:0
                            Miked180
                            thanks for your help,
                            der is no file in /etc/X11/xorg.conf.d
                            ist better to make a new setup ??
                            in ssh terminal session, may have to do export DISPLAY=:0 ?
                              sdetweil @Miked180
                              @Miked180 said in no /etc/kbd/config Folder/File:
                              where does that happen?
                                Miked180
                                tis is in your link . or on the flase position in the page ?
                                Sorry i dont know about this .
                                Im learning since short time but im not so good as you :-=
                                UPDATE : i geht : setterm: terminal xterm-256color does not support --blank
                                if i use your command
                                  sdetweil @Miked180
                                  @Miked180 sorry, no idea… i thought that was one of the best sites for this kind of info
                                    Miked180
                                    i make now a new setpu, its better and cleaner, thansk very much for your big support
                                      Miked180
