    no /etc/kbd/config Folder/File
    31 Posts 2 Posters 17.7k Views 2 Watching
      sdetweil @Miked180
      @Miked180 for calendar error
      change http://calendar to https://calendar
      don’t see the error listed above
      pm2 stop 0
      pm2 flush
      pm2 start 0
      after error
      pm2 logs --lines=100
        Miked180
        pi@raspberrypi:~/MagicMirror/config $ pm2 logs --lines=100
        PM2 | 2020-03-11T18:29:32: PM2 log: App [MagicMirror:0] starting in -fork mode-
        PM2 | 2020-03-11T18:29:32: PM2 log: App [MagicMirror:0] online
        /home/pi/.pm2/logs/MagicMirror-error.log last 100 lines:
        /home/pi/.pm2/logs/MagicMirror-out.log last 100 lines:
        0|MagicMir |
        0|MagicMir | > magicmirror@2.10.1 start /home/pi/MagicMirror
        0|MagicMir | > ./run-start.sh
        0|MagicMir |
        0|MagicMir | [18:29:37.650] [LOG] Starting MagicMirror: v2.10.1
        0|MagicMir | [18:29:37.659] [LOG] Loading config …
        0|MagicMir | [18:29:37.664] [LOG] Loading module helpers …
        0|MagicMir | [18:29:37.666] [LOG] No helper found for module: alert.
        0|MagicMir | [18:29:37.713] [LOG] Initializing new module helper …
        0|MagicMir | [18:29:37.714] [LOG] Module helper loaded: updatenotification
        0|MagicMir | [18:29:37.715] [LOG] No helper found for module: clock.
        0|MagicMir | [18:29:38.184] [LOG] Initializing new module helper …
        0|MagicMir | [18:29:38.185] [LOG] Module helper loaded: calendar
        0|MagicMir | [18:29:38.185] [LOG] No helper found for module: compliments.
        0|MagicMir | [18:29:38.186] [LOG] No helper found for module: currentweather.
        0|MagicMir | [18:29:38.187] [LOG] No helper found for module: weatherforecast.
        0|MagicMir | [18:29:38.218] [LOG] Initializing new module helper …
        0|MagicMir | [18:29:38.218] [LOG] Module helper loaded: newsfeed
        0|MagicMir | [18:29:38.222] [LOG] Initializing new module helper …
        0|MagicMir | [18:29:38.222] [LOG] Module helper loaded: MMM-WienerLinien
        0|MagicMir | [18:29:38.224] [LOG] Initializing new module helper …
        0|MagicMir | [18:29:38.225] [LOG] Module helper loaded: MMM-RandomYouTubePlayer
        0|MagicMir | [18:29:38.226] [LOG] No helper found for module: MMM-EyeCandy.
        0|MagicMir | [18:29:38.226] [LOG] All module helpers loaded.
        0|MagicMir | [18:29:38.227] [LOG] Starting server on port 8080 …
        0|MagicMir | [18:29:38.241] [LOG] Server started …
        0|MagicMir | [18:29:38.242] [LOG] Connecting socket for: updatenotification
        0|MagicMir | [18:29:38.243] [LOG] Connecting socket for: calendar
        0|MagicMir | [18:29:38.244] [LOG] Starting node helper for: calendar
        0|MagicMir | [18:29:38.245] [LOG] Connecting socket for: newsfeed
        0|MagicMir | [18:29:38.245] [LOG] Starting module: newsfeed
        0|MagicMir | [18:29:38.246] [LOG] Connecting socket for: MMM-WienerLinien
        0|MagicMir | [18:29:38.247] [LOG] Starting module helper: MMM-WienerLinien
        0|MagicMir | [18:29:38.248] [LOG] Connecting socket for: MMM-RandomYouTubePlayer
        0|MagicMir | [18:29:38.248] [LOG] Starting module helper: MMM-RandomYouTubePlayer
        0|MagicMir | [18:29:38.249] [LOG] Sockets connected & modules started …
        0|MagicMir | [18:29:38.404] [LOG] Launching application.
        0|MagicMir | [18:29:40.761] [LOG] Create new calendar fetcher for url: https://calendar.google.com/calendar/ical/vaios2k%40gmail.com/public/basic.ics - Interval: 120000
        0|MagicMir | [18:29:40.873] [LOG] Create new news fetcher for url: https://rss.orf.at/science.xml - Interval: 300000
          sdetweil @Miked180
          @Miked180 did it black screen?
            Miked180
            now i see the mirror, i wait few minutes
              Miked180
              Now i got a black screen.
              0|MagicMir | npm ERR! code ELIFECYCLE
              0|MagicMir | npm ERR! errno 1
              0|MagicMir | npm ERR! magicmirror@2.10.1 start: ./run-start.sh
              0|MagicMir | npm ERR! Exit status 1
              0|MagicMir | npm ERR! Failed at the magicmirror@2.10.1 start script.
              0|MagicMir | npm ERR! This is probably not a problem with npm. There is likely additional logging output above.
              0|MagicMir |
              0|MagicMir | npm ERR! A complete log of this run can be found in:
              0|MagicMir | npm ERR! /home/pi/.npm/_logs/2020-03-11T17_47_10_283Z-debug.log
              from 283Z-debug.log :
              0|MagicMir |
              after restart raspberry i see the mirror
                sdetweil @Miked180
                @Miked180 before restart pi, do with keyboard on pi…
                alt-spacebar, n
                see if MM window will minimize
                also, setup ssh on pi, and ssh from windows to pi to examine…
                xset q
                setterm -blank 0 -powerdown 0
                from here https://wiki.archlinux.org/index.php/Display_Power_Management_Signaling
                in ssh terminal session, may have to do export DISPLAY=:0
                  Miked180
                  thanks for your help,
                  der is no file in /etc/X11/xorg.conf.d
                  ist better to make a new setup ??
                  in ssh terminal session, may have to do export DISPLAY=:0 ?
                    sdetweil @Miked180
                    @Miked180 said in no /etc/kbd/config Folder/File:
                    where does that happen?
                      Miked180
                      tis is in your link . or on the flase position in the page ?
                      Sorry i dont know about this .
                      Im learning since short time but im not so good as you :-=
                      UPDATE : i geht : setterm: terminal xterm-256color does not support --blank
                      if i use your command
                        sdetweil @Miked180
                        @Miked180 sorry, no idea… i thought that was one of the best sites for this kind of info
                          Miked180
                          i make now a new setpu, its better and cleaner, thansk very much for your big support
                            Miked180
