    no /etc/kbd/config Folder/File
    31 Posts 2 Posters 18.4k Views 2 Watching
      Miked180
      pi@raspberrypi:~/MagicMirror/config $ pm2 logs --lines=100
      [TAILING] Tailing last 100 lines for [all] processes (change the value with --lines option)
      /home/pi/.pm2/pm2.log last 100 lines:
      PM2 | 2020-03-11T18:29:32: PM2 log: App [MagicMirror:0] starting in -fork mode-
      PM2 | 2020-03-11T18:29:32: PM2 log: App [MagicMirror:0] online
      /home/pi/.pm2/logs/MagicMirror-error.log last 100 lines:
      /home/pi/.pm2/logs/MagicMirror-out.log last 100 lines:
      0|MagicMir |
      0|MagicMir | > magicmirror@2.10.1 start /home/pi/MagicMirror
      0|MagicMir | > ./run-start.sh
      0|MagicMir |
      0|MagicMir | [18:29:37.650] [LOG] Starting MagicMirror: v2.10.1
      0|MagicMir | [18:29:37.659] [LOG] Loading config …
      0|MagicMir | [18:29:37.664] [LOG] Loading module helpers …
      0|MagicMir | [18:29:37.666] [LOG] No helper found for module: alert.
      0|MagicMir | [18:29:37.713] [LOG] Initializing new module helper …
      0|MagicMir | [18:29:37.714] [LOG] Module helper loaded: updatenotification
      0|MagicMir | [18:29:37.715] [LOG] No helper found for module: clock.
      0|MagicMir | [18:29:38.184] [LOG] Initializing new module helper …
      0|MagicMir | [18:29:38.185] [LOG] Module helper loaded: calendar
      0|MagicMir | [18:29:38.185] [LOG] No helper found for module: compliments.
      0|MagicMir | [18:29:38.186] [LOG] No helper found for module: currentweather.
      0|MagicMir | [18:29:38.187] [LOG] No helper found for module: weatherforecast.
      0|MagicMir | [18:29:38.218] [LOG] Initializing new module helper …
      0|MagicMir | [18:29:38.218] [LOG] Module helper loaded: newsfeed
      0|MagicMir | [18:29:38.222] [LOG] Initializing new module helper …
      0|MagicMir | [18:29:38.222] [LOG] Module helper loaded: MMM-WienerLinien
      0|MagicMir | [18:29:38.224] [LOG] Initializing new module helper …
      0|MagicMir | [18:29:38.225] [LOG] Module helper loaded: MMM-RandomYouTubePlayer
      0|MagicMir | [18:29:38.226] [LOG] No helper found for module: MMM-EyeCandy.
      0|MagicMir | [18:29:38.226] [LOG] All module helpers loaded.
      0|MagicMir | [18:29:38.227] [LOG] Starting server on port 8080 …
      0|MagicMir | [18:29:38.241] [LOG] Server started …
      0|MagicMir | [18:29:38.242] [LOG] Connecting socket for: updatenotification
      0|MagicMir | [18:29:38.243] [LOG] Connecting socket for: calendar
      0|MagicMir | [18:29:38.244] [LOG] Starting node helper for: calendar
      0|MagicMir | [18:29:38.245] [LOG] Connecting socket for: newsfeed
      0|MagicMir | [18:29:38.245] [LOG] Starting module: newsfeed
      0|MagicMir | [18:29:38.246] [LOG] Connecting socket for: MMM-WienerLinien
      0|MagicMir | [18:29:38.247] [LOG] Starting module helper: MMM-WienerLinien
      0|MagicMir | [18:29:38.248] [LOG] Connecting socket for: MMM-RandomYouTubePlayer
      0|MagicMir | [18:29:38.248] [LOG] Starting module helper: MMM-RandomYouTubePlayer
      0|MagicMir | [18:29:38.249] [LOG] Sockets connected & modules started …
      0|MagicMir | [18:29:38.404] [LOG] Launching application.
      0|MagicMir | [18:29:40.761] [LOG] Create new calendar fetcher for url: https://calendar.google.com/calendar/ical/vaios2k%40gmail.com/public/basic.ics - Interval: 120000
      0|MagicMir | [18:29:40.873] [LOG] Create new news fetcher for url: https://rss.orf.at/science.xml - Interval: 300000
        sdetweil @Miked180
        @Miked180 did it black screen?
          Miked180
          now i see the mirror, i wait few minutes
            Miked180
            Now i got a black screen.
            0|MagicMir | npm ERR! code ELIFECYCLE
            0|MagicMir | npm ERR! errno 1
            0|MagicMir | npm ERR! magicmirror@2.10.1 start: ./run-start.sh
            0|MagicMir | npm ERR! Exit status 1
            0|MagicMir | npm ERR! Failed at the magicmirror@2.10.1 start script.
            0|MagicMir | npm ERR! This is probably not a problem with npm. There is likely additional logging output above.
            0|MagicMir |
            0|MagicMir | npm ERR! A complete log of this run can be found in:
            0|MagicMir | npm ERR! /home/pi/.npm/_logs/2020-03-11T17_47_10_283Z-debug.log
            from 283Z-debug.log :
            0|MagicMir |
            after restart raspberry i see the mirror
              sdetweil @Miked180
              @Miked180 before restart pi, do with keyboard on pi…
              alt-spacebar, n
              see if MM window will minimize
              also, setup ssh on pi, and ssh from windows to pi to examine…
              xset q
              setterm -blank 0 -powerdown 0
              from here https://wiki.archlinux.org/index.php/Display_Power_Management_Signaling
              in ssh terminal session, may have to do export DISPLAY=:0
                Miked180
                thanks for your help,
                der is no file in /etc/X11/xorg.conf.d
                ist better to make a new setup ??
                in ssh terminal session, may have to do export DISPLAY=:0 ?
                  sdetweil @Miked180
                  @Miked180 said in no /etc/kbd/config Folder/File:
                  where does that happen?
                    Miked180
                    tis is in your link . or on the flase position in the page ?
                    Sorry i dont know about this .
                    Im learning since short time but im not so good as you :-=
                    UPDATE : i geht : setterm: terminal xterm-256color does not support --blank
                    if i use your command
                      sdetweil @Miked180
                      @Miked180 sorry, no idea… i thought that was one of the best sites for this kind of info
                        Miked180
                        i make now a new setpu, its better and cleaner, thansk very much for your big support
                          Miked180
                          This post is deleted!
