Diego Vieria Random-Photo read image from PI ?
But if I wanted to see the lower right images, not as a background, for example, what should I change?
Thanks for your patience
Alberto
How did you fix it? This could be helpful for other people in the future. For now only full screen background is supported, I might change this in the future.
I did not specify what I did just because I removed and reinstalled in the form and everything worked immediately all.
For the fact that change size and position of the image I was trying to change the form css but if you tell me that there is not enough to put your hand means that this change but the issue is more complex then await the development of your work.Congratulations for your job
Thank you, Alberto
