    MMM-COVID19
    Scheduled Pinned Locked Moved Health
    63 Posts 25 Posters 30.3k Views 24 Watching
      Saeijou
      I don’t know what I am doing wrong, I can’t get it to work.
      I have that in my config:
          module: 'MMM-COVID19',
          positon: "top_left",
            updateInterval: 300000,
            worldStats: true,
            countries: ["Germany","USA"],
            headerRowClass: "small",
            rapidapiKey: "API_KEY"
      when I execute the curl command posted here I also get an output with my API key.
      I am not 100% sure what is meant with “posting it twice”, why would that be?
      Thank you for any help!
      Edit: MM is loading normally - no errors. the module is just not there
      • H Offline
        hweigel @Saeijou
        @Saeijou said in MMM-COVID19:
        positon
        Hey @Saeijou,
        try using
        instead of
        That should do the trick :-)
          Saeijou @hweigel
          @hweigel OH MY GOODNESS!!! I debugged that thing for HOURS! thank you so much :)
          • K Offline
            KD
            Hi Guys, I cannot get this to work - not sure what i am doing wrong…i can only see the header displaying and nothing else… please help! my config looks like this:
                                  position: "bottom_right",
                                  header: "COVID-19 Stats",
                                  worldStats: true,
                                  rapidapiKey: "My Rapidapikey",
                                  orderCountriesByName: "false",
                                  countries: [ "Austria", "Germany", "Italy" ],
                                  updateInterval: 10000000,
                                  lastUpdateInfo: "true",
                                  infoRowClass: "medium",
            Many Thanks in advance
            S mumblebajM 2 Replies Last reply Reply Quote 0
              sdetweil @KD
              @KD please use code block marks , mark the text and hit the </> button
              • K Offline
                KD @sdetweil
                @sdetweil Will do thank you - apologies i am new first post actually :)
                • P Offline
                  paulie420
                  Ok, I pulled the MMM-Covid19 git. I added the module in config.js, and entered my APIkey… However, it only displays the COVID-19 title and no data.
                  Am I correct in stating that its not working because now rapidapi has made the coronavirus monitor API paid? Because I think I have it all setup correctly, I notice that the API in rapidapi states PAID, and nothing shows… I want Covid data; is there a way, or am I doing something wrong? OR do I just need to pay and then it’ll show up??
                  • mumblebajM Offline
                    mumblebaj Module Developer @KD
                    @KD remove the comma after “medium” and you should be fine.
                      mumblebaj Module Developer @paulie420
                      @paulie420 The RapidAPI seems to be working fine. No need to pay. Can you post your config?
                      J A 2 Replies Last reply Reply Quote 0
                        Joeri @mumblebaj
                        @mumblebaj Hello, I’ve got the same problem, this is my config.
                        module: “MMM-COVID19”,
                        position: “lower_third”,
                        worldStats: true,
                        delta: true,
                        headerRowClass: ‘small’,
                        orderCountriesByName: “false”,
                        lastUpdateInfo: true,
                        countries: [ “Argentina”, “USA” ],
                        headerRowClass: “small”,
                        infoRowClass: “medium”,
                        rapidapiKey : “MY KEY”,
                        • 6
                        • 7
                        • 5 / 7
