    covid bell curve line graph tracker
    89 Posts 6 Posters 61.9k Views 8 Watching
      sdetweil @almostgithub
      @almostgithub lets try some new debugging
      git clone again, make sure debug:true, in each MyCovid19 module def in config.js
      the update now only downloads the data file ONCE across all the modules (1 for countries, 1 for states if both used)
      add this module
      git clone https://github.com/sdetweil/MMM-Logging
      add it to the TOP of the module list like this
      	modules: [    // < top of module list
                  module: 'MMM-Logging',
                  disabled: false,
                      // Module functions out of the box with nothing set here.
                      // See below for configurable options.
                      echoLocal: true,
                      echoRemote: true,
                      format: "{{message}} ({{folder}}/{{file}}:{{line}} {{method}})",
      start MM like this from a terminal window (make sure to stop the pm2 one if u use pm2)
      cd ~/MagicMirror
      npm start >>somefile.txt 2>&1
      run your test with 0.0.0.0
      please test both on system and remote browser access
      ctrl-c to stop
      change to localhost
      restart same command
      ctrl-c when done
      send me somefile.txt at my email sdetweil at gmail
      rafaelcotaR 1 Reply Last reply Reply Quote 0
      • rafaelcotaR Offline
        rafaelcota @sdetweil
        @sdetweil You’re great, man. You’ve been working with MyCovid19 to fix the bug, a weird and difficult one to identify; you’ve done tests, modifications, sent me instructions how to debug, and more modifications, and tests, and debugging; and files and emails went between us and finally, I can say IT WORKS just fine!
        Address is 0.0.0.0, so I can access it from any device at port 8080 and graphs are just the size I put in config.
        Thank you again for all your time, effort and concern.
        Stay safe
          sdetweil @rafaelcota
          @rafaelcota glad we found it… now I gotta fix another toughie…
          • H Offline
            humdinger44
            I’ve been keeping an eye on the NY data so i can compare it to my home state. Any idea whats happened there? It might be nice to have a 7 day rolling average option to smooth the data out. If that’s within the realm of “Not very difficult.”
              sdetweil @humdinger44
              @humdinger44 i see it too… will mess up the charts for a while… boooo
              from the data source
              **NEW:** Starting with data for May 6th, this data reports the total combined number of confirmed and
              probable Covid-19 cases and deaths where available. Many states and localities have started to report this
              data using criteria that were developed by states and the federal government.
              This will cause a spike in the cases and deaths data for some areas while we work to revise our historical data
               with those probable cases and deaths.
                sdetweil
                I posted an update to github today,
                supports displaying US state county data
                a little bit trickier on the data entry
                counties:[ { ‘county_name’ : ‘state_name’ }, { ‘county_name2’ : ‘state_name2’} ]
                on the chart only the county name is shown
                  darbos
                  HI guys, thanks for making this! I am trying to show daily totales, I was trying to make it easy to see the totals for each day. However the graph is starting extremly high, see below. Can someone see what I am doing wrong?
                  THanks !
                  			module:"MyCovid19",
                  			position:"bottom_center",
                  			config:{
                  				states:['Arizona','Michigan','California'],
                  				line_colors:['red','white','blue'],
                  				chart_type:"cases",
                  				chart_title:"COVID Cases Reported Daily",
                  				ranges:{min:0,max:000,stepSize:100},
                                  backgroundColor: "transparent",
                  			    width: 600,
                  			    height: 500,
                  			    debug: true,
                  			    startDate: '06/01/2020'
                  ![Screenshot_20200616_185855.png](/assets/uploads/files/1592359395744-screenshot_20200616_185855.png)
                    sdetweil @darbos
                    @darbos max is 0???
                    D 3 Replies Last reply Reply Quote 0
                      darbos @sdetweil
                      @sdetweil I had it set at a higher number but took that from an example I found on here. What should those be set at? Ty
                        darbos @sdetweil
                        @sdetweil my goal is really to be able to look and see the daily totals for the past few days.
                        • 6
                        • 7
                        • 8
                        • 9
                        • 7 / 9
